Rear Diff. Fluid Change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TunaTaco52, Jan 19, 2020.
  1. Jan 19, 2020 at 12:15 PM
    TunaTaco52
    TunaTaco52 [OP] New Member
    Kyle
    2013 Tacoma, Pre-Runner/SR5, i4
    3in lift, push bar w/ 30in light bar & PA speaker.
    I’ve been wanting to change out the rear differential fluid on my tacoma (2013 2WD Prerunner) for some time now, but after searching the internet for a couple weeks I can’t find much that would help.
    I’m very far from being a mechanic, just a guy trying to swap out some taco sauce by myself. Owner’s manual says 75W-85 GL-5, but in terms of what specific fluid/how much fluid/LSD or not, I am basically clueless on what I need in terms of fluid.
  2. Jan 19, 2020 at 12:18 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Welcome, do your google search with tacoma in it and it will bring you back here with all the post.
    TunaTaco52[OP] likes this.
  3. Jan 19, 2020 at 12:24 PM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
  4. Jan 19, 2020 at 12:38 PM
    wmb67
    wmb67 Well-Known Member
    Boston
    09 Dbl Cab Off Road MGM
    Very easy to do... just make sure the fill plug will come off before removing drain plug.
  5. Jan 19, 2020 at 12:42 PM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    https://www.redlineoil.com/motor-oil
    I use Redline full synthetic oil in my differential and transmission, and have those on a 30K fluid change interval. Recommend entering your vehicle data into the "Find products for my vehicle" section in the above weblink. It will tell you what weight oil and how much you need to buy. You can then purchase it from a local shop or through Amazon. You'll need a hand pump to pump the oil from the bottle into the differential, and you can buy one of those from any auto parts store.
    If you've never changed it before, I highly recommend you remove the "fill plug" before you remove the drain plug. That way if the fill plug has seized, you won be stuck with no oil in your differential and no way to refill it.
  6. Jan 19, 2020 at 12:46 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    im a big fan REDLINE products
    they have several weights
    buy what U need
    if everyday transport ( work , mall , home ) U need not get the heavy duty stuff
    good luck
  7. Jan 19, 2020 at 4:15 PM
    jet speed
    jet speed Well-Known Member
    Ohio
    2017 TRD OR DCSB
    The importance of this cannot be overstated, make sure this is step #1!
    EdgemanVA and tacomarandy like this.
  8. Jan 19, 2020 at 4:21 PM
    dawgn86
    dawgn86 Well-Known Member
    2013 Toyota Tacoma
    Plain Jane Taco likes this.
  9. Jan 19, 2020 at 6:07 PM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
  10. Jan 29, 2025 at 11:16 AM
    bmg88201
    bmg88201 Well-Known Member
    Brian
    Quitman, AR
    2022 Tacoma Limited
    Just changed mine at 30,000. I used Valvoline 75-90 synthetic. I got new crush washers too. I drained a little less than 3 qts. I put in a hair more than 3 qts but not till it over flowed but abut an 1/8 inch below the threads. I read somewhere that the level should be 5 mm below coming out the hole. Anyway that level will just fine. There was some shavings on the drain plug magnet. The oil looked fairly clean. This seems a bit early to do this but did it anyway. I won’t do it again till I put an additional 50 or 60,000 on the truck. All other vehicles I’ve owned I always did it 100,000 miles. Oh, I kept the old crush washer on the fill plug and drove it a few miles and checked the level and then I used the new crush washer on the fill plug.
  11. Jan 29, 2025 at 1:37 PM
    el_smurfo
    el_smurfo Well-Known Member
    Good to hear I'm not the only one that hasn't gotten around to changing their fluids until 100k miles. So far, minimal sparklies and sludge in all the fluids I've changed.
    bmg88201[QUOTED] likes this.
  12. Jan 29, 2025 at 1:45 PM
    EdgemanVA
    Virginia Beach
    2008 X-Runner
    Several
    I think the trucks that need more frequent diff oil changes are the 05-08 Tacomas with the "clutch type" LSD. Toyota recommends those fluid changes every 30K miles.
  13. Jan 29, 2025 at 4:59 PM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    dawgn86 likes this.
  14. Jan 29, 2025 at 5:12 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  15. Jan 29, 2025 at 5:39 PM
    TacosyBurritos
    TacosyBurritos Well-Known Member
    2021 TRDS AC 4x4 MT
    Meh, diff oil is good for at least 3-400k.
