Rear Diff Fluid Freezing?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ZachOR, Dec 28, 2017.
  1. Dec 28, 2017 at 2:29 PM
    ZachOR
    ZachOR [OP] Well-Known Member
    Zach
    2016 Quicksand DCSB Off-Road
    Hey Guys,
    Currently sitting in a VA parking garage and it’s 20 degrees out. Just started the truck (2016 off-road manual) and when I try to take off it feels like I’m tied to a tree or the rear diff just does not want to turn. I’ve had the feeling prior in the cold but not this cold or this bad.
    In normal temps when I try to switch from 4h to 4l and back it can take minutes of rocking back and forth. I’m wondering if it’s possible water could have gotten in from submerging the rear and mixed with the fluid and that it’s now freezing? Anything you could think of that could cause this? I tried searching to no avail.
    Thanks!
  2. Dec 28, 2017 at 2:31 PM
    ZachOR
    Zach
    Also it will not engage from 2wd to 4wd at all currently.
  3. Dec 28, 2017 at 2:32 PM
    Kinsail48
    Kinsail48 Well-Known Member
    Josh
    Rockland, ME
    2019 Tundra TRD Off-road
    Brand new so nothing yet.
    Idk if it’s water or not but my truck gen 3 auto is extremely sluggish when she’s cold. My old gen 2 manual was even worse in anything under 20 until they warm up a bit.
  4. Dec 28, 2017 at 2:32 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Rear brake drums are most likely siezed.
    Move the truck forward and backwards to free them up.
    It's common
  5. Dec 28, 2017 at 2:35 PM
    Kinsail48
    Josh
    Rockland, ME
    Mine clunk every morning when taking off.
  6. Dec 28, 2017 at 2:38 PM
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    20 degrees!! Lol no the diff oil is not freezing.
  7. Dec 28, 2017 at 2:39 PM
    Kinsail48
    Josh
    Rockland, ME
  8. Dec 28, 2017 at 2:40 PM
    ZachOR
    Zach
    Haha I didn’t think the oil itself would be freezing but I submerge it often with no breather so thought water mixed in could be possible.
    The drums seem more likely. It physically won’t move when trying and there is a click when trying. Having someone listen to the brakes in a minute to see if that’s the sound.
  9. Dec 28, 2017 at 2:41 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    If you have that much condensation and water in your gear oil you need to flush and refill it.
    But I've personally never heard of diff actually having so much moisture in it that it would seize. It's conceivable that moisture would freeze into ice but then you'd have ice floating in the the lube.
    Around here you usually has to start getting really cold for me to notice it, I mean sub zero. Even then it's more like you're dragging a tire for a few minutes until the lube moves from the thick honey state to something less viscous.
    I like @koditten's suggestion.
    Kinsail48 likes this.
  10. Dec 28, 2017 at 2:54 PM
    koditten
    Kirk
    Central Michigan
    I've switched to 4low to make this easier.
  11. Dec 28, 2017 at 2:54 PM
    ZachOR
    Zach
    Pretty set on it being the drums. Going to come back with something to heat them up with. Thanks all!
  12. Dec 28, 2017 at 2:56 PM
    koditten
    Kirk
    Central Michigan
    Be easier to just swat the inside of the backing plate with a hammer.
    DaveInDenver likes this.
  13. Dec 28, 2017 at 2:58 PM
    ZachOR
    Zach
    Will give that a try now!
  14. Dec 28, 2017 at 3:21 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    Yup, if this is the issue then with a smack with a rubber mallet you'll hear them release.
    I'd proceed with caution using heat, it's possible to literally cook your brakes, like the flaming shoe liners or brake fluid. Use a heat gun and go slowish. Or just set the parking brake at one or so clicks to warm them and evap the moisture.
