Rear diff fluid type ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Santa Cruzin, Apr 22, 2018.
  1. Apr 22, 2018 at 8:04 PM
    jessandjamie
    jessandjamie Well-Known Member
    Arizona
    Mine has the locker so I don't know that they're the same but mine takes just under 3. You could get 4 and return 1 if you don't end up needing it.
  2. Apr 22, 2018 at 8:39 PM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    No LSD sticker means you don’t need the additive but it won’t cause trouble. You do need a GL5 gear oil in your favorite weight range and brand. Three quarts should fill it with a little left over if you don’t spill any. Put it in until it just starts to run out. Stop and wait for a few minutes for it to run down the axles then top it off. You’re done! If you like spending money buy the really expensive stuff. If you’re a cheap ass buy the house brand at your nearest auto parts store. There are many choices in between that will work also. Change it regularly for good results.
    Santa Cruzin[OP] likes this.
  3. Apr 22, 2018 at 8:56 PM
    Santa Cruzin
    Santa Cruzin [OP] Well-Known Member
    NorCal
    05 Tacoma Prerunner SR5 4.0 DCSB
    Thanks for all the info guys, I think I’m going to get the royal purple, is 80-90 a good weight ?
  4. Apr 23, 2018 at 3:07 AM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    You should be fine with 80-90
  5. Apr 23, 2018 at 3:53 AM
    Santa Cruzin
    NorCal
    I’m pretty sure I’ve got an open diff, it says A04A in my door and I guess that’s the axel code for an open diff
  6. Apr 23, 2018 at 4:02 AM
    Santa Cruzin
    NorCal
    MolonLabeTaco, kimo and 1Shifter like this.
  7. Apr 23, 2018 at 4:03 AM
    Santa Cruzin
    NorCal
    Axel code will be in your door jam
  8. Apr 23, 2018 at 4:14 AM
    1Shifter
    Jeff
    09 PreRunner
  9. Apr 23, 2018 at 4:32 AM
    Santa Cruzin
    NorCal
    Yea my dealership wants 150$ to change the diff such a ripoff
    jross20 likes this.
  10. Apr 23, 2018 at 4:55 AM
    kimo
    kimo Well-Known Member
    Knuckle Head
    Kauai
    09 Super White TRD Sport DCLB 4X4! 2017 Silver 4Runner!
    Want a real laugh? Get a quote on having your cabin filter changed at the stealership..:rolleyes:
  11. Apr 23, 2018 at 8:30 AM
    1Shifter
    Jeff
    09 PreRunner
    Yeah I was quoted 90 bucks i just about pissed down both pant legs I laughed so hard
  12. Apr 23, 2018 at 1:45 PM
    1Shifter
    Jeff
    09 PreRunner
    So my truck went in today for the frame CRC and I asked the service writer to quote me a price to change the diff oil. My back is kinda sketchy and I really didn't want to crawl under my truck, two years ago they did it for 90 bucks. The cost this time was 238 bucks! They told me it's because they have to use a "special fluid additive". I'm presuming they mean the LSD additive, which my 09 PreRunner doesn't even need. Rather than argue with her I've just decided to either do it myself or buy some M1 or.RP and do it myself. What a rip off.
    kimo likes this.
  13. Apr 23, 2018 at 1:56 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    $90 bucks aint too bad, but for $238 you should have asked if that includes a free hand job.
    Biscuits, kimo, jross20 and 1 other person like this.
  14. Apr 23, 2018 at 3:57 PM
    1Shifter
    Jeff
    09 PreRunner
    Getting ready to pull the trigger on 3 quarts of Red Line 75W-90 (57904) from Amazon. I'll either change it this weekend or get my local mechanic to do it. Either way it ain't 238 bucks but I won't be getting the "special additive".
    Biscuits likes this.
  15. Apr 23, 2018 at 4:26 PM
    #35
    L J
    Illinois
    Mine has the mechanical LSD so I had to put in the “special additive” which was less than $8. I used non synthetic 75w90 Valvoline. Total cost was under $40 and it took three trips under the truck. Charging $238 is what gets dealerships a bad rep. Hope you get some help for your back issues.
    1Shifter[QUOTED] likes this.
  16. Apr 23, 2018 at 4:30 PM
    #36
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    Is there any advantage, if at all, of getting a heavier than required oil? I've heard that a heavier one is better for a higher mileage component.
    Also, so a 2011 PreRunner, does not have a mechanical limited slip diff? So I guess you don't need to worry about any special additives.
  17. Apr 23, 2018 at 4:49 PM
    #37
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    No advantage at all and it will actually hinder the economy of your truck. This stuff is mainly meant for big trucks consistently towing heavy loads. As it gets hotter it’ll get thicker than it is when you pour it out of the bottle.
    jross20[QUOTED] likes this.
  18. Apr 23, 2018 at 5:20 PM
    #38
    1Shifter
    Jeff
    09 PreRunner
    Thanks man, I've been fighting my sciatic nerve for the least few years, every once in awhile it likes to remind me it's still there. I'm gonna take the ticket in and show the service manager. Not sure if ill get an answer or if he even cares. The last time I had the diff oil changed was Sept 2016, the bill was 77 bucks and change. Maybe dick move but what the hell.
  19. Apr 23, 2018 at 5:27 PM
    #39
    Santa Cruzin
    NorCal
    I ended up getting the Lucas high performance 75-90 oil. The old stuff was still pretty clean and had a golden tint to it still, guessing the previous owner must have changed it not long ago so that’s good. But either way had to add the new stuff
    maxtherat and 1Shifter like this.
  20. Apr 23, 2018 at 5:39 PM
    #40
    maxtherat
    Inland Northwest
    Gear oil doesn’t get black like engine oil. It just usually stinks. Is the Lucas a conventional or synthetic? Guessing conventional?
    jross20 likes this.
