Rear diff fluid
Discussion in '4 Cylinder' started by dawgn86, Nov 21, 2019.
  1. Nov 21, 2019 at 5:53 PM
    dawgn86
    dawgn86 [OP] Well-Known Member
    2013 Toyota Tacoma
    Hey gang
    Going to change out my diff fluid soon. I have a 2013 per runner double cab automatic.
    What fluid should do you guys use? Any additives needed?
    Thanks
    BassAckwards likes this.
  2. Nov 21, 2019 at 5:55 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Youll need 3 qts of 75w90. No LSD additives necessary, yours is brake actuated
    i run Lucas 85w140 for a little more protection
  3. Nov 21, 2019 at 6:00 PM
    dawgn86
    2013 Toyota Tacoma
    Thanks
  4. Nov 21, 2019 at 6:03 PM
    BassAckwards
    Make sure you take the fill plug out first before you drain it, and i recommend using a 6pt socket. Its a 24mm
    Yodeville likes this.
  5. Nov 21, 2019 at 6:06 PM
    dawgn86
    2013 Toyota Tacoma
    Yep. Learned that the hard way many years ago :)
  6. Nov 21, 2019 at 6:09 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Suggest buying new crush washers (e.g., off Amazon).
  7. Nov 21, 2019 at 6:21 PM
    dawgn86
    2013 Toyota Tacoma
    Do you know the part number for the crush washer?
  8. Nov 22, 2019 at 12:27 PM
    96carboard
    96carboard Well-Known Member
    {anything}W90.
  9. Nov 22, 2019 at 12:28 PM
    96carboard
    Fixed 4 ya.
  10. Nov 22, 2019 at 12:57 PM
    BassAckwards
    :duh:
  11. Nov 23, 2019 at 9:16 AM
    iamroddy
    iamroddy Well-Known Member
    I guess I'm the odd man out...I use the viscosity listed in my owner's manual (75W85). Not many companies offer it, so I went with Redline's full synthetic formula.
    In all honesty, There's not much difference between 75W85 and 75W90...Toyota probably only uses/lists it for CAFE (Corporate Average Fuel Economy) reasons.
    wags and BillsSR5 like this.
  12. Nov 23, 2019 at 1:20 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    75W85 is a 3rd gen thing. 2nd gens call for 75W90. If you buy a diff from ECGS, they recommend using non-synthetic 85w140.
    The comment above about more fuel consumption is funny because bigger/heavier wheels/tires, lift kits, armor, and regearing are going to be more detrimental to fuel consumption than a thicker oil.
    agalloch07 and BassAckwards like this.
  13. Nov 23, 2019 at 1:33 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Search Amazon for 12 pack plug washers transfer, differential, transmission.
  14. Nov 23, 2019 at 4:29 PM
    iamroddy
    I could be wrong, but I'm pretty sure my 2011 is a 2nd gen...
    You're right though, next to a bunch of added weight, any difference gear oil makes will be pretty minimal.
  15. Nov 23, 2019 at 4:31 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    yep.
  16. Nov 26, 2019 at 8:08 AM
    CPA/MBA
    CPA/MBA Opinions Vary
    24mm = 15/16"
  17. Nov 26, 2019 at 8:13 AM
    BassAckwards
    24mm = metric
    15/16" = sae
    i wouldnt recommend using an SAE socket on our metric bolts.. they are similar sizes yes, but different enough to cause problems. A metric 6sided socket is the way to go:thumbsup:
    96carboard likes this.
  18. Nov 26, 2019 at 8:17 AM
    96carboard
    Well actually in this case, the metric size is marginally larger than the SAE size at 0.9449 inches vs 0.9375 inches. If the SAE size fits without being hammered, then it would actually be a better choice.
    When the opposite is true, i.e., the metric size is *smaller* than the SAE size, then the metric size should definitely be used.
    CPA/MBA likes this.
  19. Nov 26, 2019 at 8:51 AM
    dawgn86
    2013 Toyota Tacoma
    I have a Lisle low profile 24" mm six point socket
  20. Nov 26, 2019 at 8:58 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Or you could just use the right tool for the job.
    whatstcp likes this.
