Rear diff getting replaced
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Charlie Marlow, Feb 3, 2020.
  1. Feb 3, 2020 at 5:37 PM
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
    So I guess we have to wait til it explodes before they change anything....
  2. Feb 3, 2020 at 5:41 PM
    19taco4x4
    19taco4x4 Well-Known Member
    Jesse
    21 Silver SR
    They replaced it once, but something In the rear has been popping/clicking for awhile now. Going to ask about it again at my next service coming up. I’ll have to see if I still have a video and post it up here.
    MGtaco2.7[QUOTED] likes this.
  3. Feb 3, 2020 at 5:53 PM
    tedNugent
    tedNugent Well-Known Member
    ted
    2019 trd Sport
    Yikes i'm at almost 4k miles and haven't had any whining or anything on mine. Is that common? Hoping mine doesn't do it because I feel the cabin is already loud enough as it is.
  4. Feb 3, 2020 at 6:30 PM
    ryan760
    ryan760 Well-Known Member
    It would actually be uncommon to not have the noise. Some configurations of the truck (i.e. dual cab, access cab, sport, OR, etc.) seem to be more affected than others, and suspension mods or lifts can affect it too.
  5. Feb 3, 2020 at 6:33 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    My '16 had the diff whine for pretty much the entire time I had it (4yrs). Nothing bad happened, it was just annoying at times. I didn't "qualify" for the TSB as my truck was an Access Cab OR.
    My '19 Sport DCSB has it too, but it's much less pronounced. Toyota has managed to dampen the sound somewhat.
    ryan760 likes this.
  6. Feb 3, 2020 at 6:37 PM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    I feel like at least 50% of the rear diff whine we all hear comes from reading about it on TW forums.
  7. Feb 3, 2020 at 6:38 PM
    MOC221_
    Frank
    No it doesn't.
    AKGSD and Lt. Dangle like this.
  8. Feb 3, 2020 at 6:46 PM
    ryan760
    How did they manage to dampen the noise on your 19? I didn't think the TSB applied to our trucks.
    MOC221_[QUOTED] likes this.
  9. Feb 3, 2020 at 6:53 PM
    MOC221_
    Frank
    I'm assuming Toyota made a production change after they "engineered" the dampening solution to this noise via TSB. I have read however, that it (the TSB) was not always successful.
    I guess I got lucky this time around :notsure:
    AKGSD likes this.
  10. Feb 3, 2020 at 6:57 PM
    ryan760
    Nice man! Glad you got a good-er one lol.
    My truck doesn't appear to have the revised cab mounts which were part of the TSB so im wondering if it even has any "dampening solution".
  11. Feb 3, 2020 at 6:59 PM
    ksJoe
    ksJoe Well-Known Member
    Joe
    Kansas
    2020 TRD Off-Road
    For those of you living with the noise:
    I've read people claim Valvoline Synpower gear oil makes their diff noisy, so they have to use Mobile 1. And I've read people claim exactly the opposite. It appears there are suble differences in the oils that either supress the noise, or don't, and different oils work for different difs.
    If it was me, I'd pick up a few bottles of different brands, and change the oil a few times. Maybe one of them will be quieter.
    Big tall dave likes this.
  12. Feb 4, 2020 at 2:12 AM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    Are there no aftermarket dampers that can be installed on the driveshaft or yoke for persistent noises like that? Similar to the ones on GM’s?
    How about changing the fluid weight (something heavier) or some kind of additive?
    I don’t have the howl, but i’m pretty sure it would drive me nuts so i’m just curious.......
  13. Feb 4, 2020 at 5:02 PM
    jetfishn
    jetfishn Well-Known Member
    Sounds like cheap foreign made ring/pinion with improper heat treatment. Especially since some are on their second ring/pinion fix, and the noise comes back by 1K.
    Be interesting to see someone add an aftermarket quality brand name rear ring/pinion with professional setup and see if noise persists.
    AKGSD likes this.
  14. Feb 4, 2020 at 5:07 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    How hard is it to make something correctly that has been manufactured for over 100 years?
    No 1911 jokes please.:rimshot:
    tedNugent, jetfishn and AKGSD like this.
  15. Feb 4, 2020 at 6:21 PM
    #35
    jrshaw91450
    jrshaw91450 Well-Known Member
    Maui
    2019 Cement Tacoma TRD OR 4x4
    TRD Cat back & Skid plate
    Any chance someone has examined the noise is being transferred up the driveline and distributed to the frame and cab from the barring carrier mount? Its it seems like a direct contact with the noise source and frame. 5 years later Im sure someone has tried messing with this, but thought I would through it out there.
    Some guys that get leveling kits done have said the noise goes away afterwards. I would assume it’s from the spacer blocks on the leaf-springs, but maybe it’s subsided from spacers being added to the bearing carrier mount to avoid the driveline vibration. Or a combination of both. Or their new AT tires hum enough to drowned it out.
  16. Feb 4, 2020 at 8:11 PM
    #36
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    Installing the revised cab mount from the TSB quieted things down slightly. Installing the cab insulation foam listed within the tsb made no difference.
    AKGSD likes this.
  17. Feb 4, 2020 at 9:54 PM
    #37
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    Probably the only real solution will be installing a better made differential from another marque
    jetfishn likes this.
  18. Feb 4, 2020 at 10:22 PM
    #38
    nomnomtaco
    nomnomtaco Well-Known Member
    2019 Black Tacoma Limited
    Hot Stock
    I owe you a beer.
  19. Feb 5, 2020 at 6:46 AM
    #39
    Charlie Marlow
    Charlie Marlow [OP] Well-Known Member
    Georgia
    19 TRD OR
    Well,I picked it up this morning and, so far, it's much quieter. They diagnosed the problem as a scored bearing and replaced the differential part 41110-0K650.
    There's still a hum from it under certain conditions, but it's nowhere near what it was. They told me it it'll make some noise because I, "have a manual transmission." Uh huh, okay... For now, though, I'm happy with it and hope it holds.
    AKGSD, ryan760 and Big tall dave like this.
  20. Feb 5, 2020 at 7:36 AM
    #40
    ryan760
    Scored bearing now?? Not really a fan of Toyota being all over the map with this stupid thing...
    AKGSD likes this.
