Rear Diff going bad?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SinisterDexter, Dec 10, 2018.
  1. Dec 10, 2018 at 4:00 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Nothing to crazy then.
    Well I'm fresh out of answer for ya. Especially with the sideways kick thing.
    Sorry good luck
  2. Dec 10, 2018 at 8:49 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Is that oil all over the spring perch? Where is that coming from?
  3. Dec 10, 2018 at 9:53 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Just tighten your UBolts to 75+ lbs, as you know you cannot “see” how tight they are
    Pigpen likes this.
  4. Dec 11, 2018 at 5:28 AM
    nasaengr
    nasaengr Well-Known Member
    Red15 DC OR
    Jack the rear end up by the center diff and give the tires a good shaking up/down & in/out. Anything loose? From all the oil that appears to be on the spare, spring perch and frame you might have a bad wheel bearing or axle seal.
  5. Dec 11, 2018 at 3:07 PM
    SinisterDexter
    SinisterDexter [OP] Active Member
    Tennessee
    No, it has been raining a ton, that is just water. The only thing under there now that the rain has stopped is just dried mud film from the weekend with no evidence of oil of any kind.
    I tightened them down as was suggested. A couple were a few quarter turns too loose.
    Jumped in it to test it out....no luck with that being the culprit.
    Since it was getting progressively worse/more frequent I finally threw in the towel and took it to the shop. As they say in these parts "I done tore the rear end out of it". Rear diff was bad...spider gears were toast. Soooo...if it seems like something heavy in the back of the truck is sliding and slamming into the side of the bed when you turn under power...check the spider gears.
    I guess the truck wanted ARB air lockers more than Dakars lol...
  6. Dec 11, 2018 at 3:34 PM
    Pigpen
    Dan
    Northwest Montana
    Fixed it for ya
  7. Dec 11, 2018 at 3:36 PM
    SinisterDexter
    Tennessee
    If I ever run for office I want you to be my speech writer...
  8. Dec 11, 2018 at 3:37 PM
    Pigpen
    Dan
    Northwest Montana
    Deal
  9. Dec 11, 2018 at 3:39 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    blown rear shock
  10. Jan 16, 2019 at 10:31 AM
    SinisterDexter
    Tennessee
    Nope, shredded spider gears...
    An ARB locker fixed it right up...lol
