Rear Diff. Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mtcarrio, Oct 17, 2014.
  1. Oct 17, 2014 at 11:11 PM
    mtcarrio
    mtcarrio [OP] Active Member
    New Orleans
    2007 TRD Sport
    Skid plate, debadged
    I changed my rear LSD diff tonight. i found these washers in the drain pan after i filled the diff. i didn't add any washers when i tightened the drain bolt...
    Does anyone know if i have to have washers??
    I also added a 6 oz bolt of additive. with the additive i only got 2.6-2.7 quarts of diff oil before over flowing ( i waited an hour and still couldnt add anymore).
    Does anyone know if this is normal?
  2. Oct 18, 2014 at 12:06 AM
    rpking
    rpking Well-Known Member
    Roger
    Ohio
    Tacoma 4x4 TRD off road
    painted engine cover, bed cover, color match door handles, window tint, seat covers, weather gaurd floor mats, TRD stainless steel cat back exhaust, front skid pan, bug deflector, custom holster mount in center console, OME 884X springs and shocks, 2" AAL, OME shocks
    Looks like the sealing washers from your fill and drain plugs.
    You should have noticed it leaking by now unless your very very lucky
  3. Oct 18, 2014 at 12:21 AM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    Definitely looks like the sealing washers! With the diff cold and a second set of hands around you can pull the drain plug and put your thumb on it while someone else puts the washer on the plug...reverse the process to put the plug back in and you should not lose much gear oil. You definitely need to have those washers in there!
  4. Oct 18, 2014 at 12:24 AM
    TacoMitch93
    TacoMitch93 Tasty Taco
    Mitch
    Nova Scotia, Canada eh
    09 Tacoma SR5
    I'm gonna say seal washers aswell.
  5. Oct 18, 2014 at 4:26 AM
    Supramacy
    Supramacy Well-Known Member
    The drain plug will most likely leak without the crush washer in place.
  6. Oct 18, 2014 at 8:43 AM
    jsi
    jsi Well-Known Member
    native earthling
    Why 2 washers? I've only ever seen or used one crush washer on my cars/trucks.
  7. Oct 19, 2014 at 8:15 PM
    mtcarrio
    New Orleans
    2007 TRD Sport
    Update:
    I went ahead and changed the crank case and front diff. I made sure to keep track of the washers for both. I noticed the front diff has a copper washer for the drain plug and the fill plug had washers like the pic i posted. Any thoughts?
    I havent replaced the rear diff washers, keeping an eye out for leaks.
  8. Oct 19, 2014 at 8:19 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    .... put the washers back in place.... dont just "keep an eye out". thats the only spot those 2 washers can come from.
  9. Oct 19, 2014 at 8:43 PM
    DocD
    DocD Well-Known Member
    Mn./SoCal
    09 access cab
    Yes,, those are the crush washers, I would put them back on!!!,, the rear diff. Should take about 100 oz of oil. Jmop
  10. Oct 20, 2014 at 8:42 AM
    Supramacy
    Just catch the oil that comes out when you remove the drain plug, change the washers and put the oil back in. You will lose a lot more oil while driving, because it heats up. I wouldn't take the risk.
