Rear diff, how much fluid?
Discussion in '1st Gen. Tacomas (1995-2004)' started by cheese7882, May 17, 2012.
  1. May 17, 2012 at 4:02 PM
    cheese7882
    cheese7882 [OP] Well-Known Member
    California
    2016 Tacoma TRD OR DCSB MT
    I bought 3qts of lucas oil for my rear diff. The first quart went in fine, but half way through adding the second, it started pouring out the fill hole as fast as it was going in. I assume its full, but before I call it good should I let the excess lube spill out the fill hole before capping it off or is it good how it is. In short, if I take off the filler screw, lube will flow out.
  2. May 17, 2012 at 4:14 PM
    cheese7882
    California
    Pretty level, and I'm replacing. I just drained it, and then filled it. There was also a bubbling sound when I first loosened the drain plug. Came out grey and somewhat thick
  3. May 17, 2012 at 4:21 PM
    cheese7882
    California
    Oh yeah, I know its been long over due. I cleaned the magnet and will probably drain and refill in another 3k. I was able to get about 2qts in, but in was coming out the fill hole pretty good. Think its good to call it done or should I raise the back end and get the other quart in there?
  4. May 17, 2012 at 4:28 PM
    cheese7882
    California
    Breather?
  5. May 17, 2012 at 4:36 PM
    cheese7882
    California
    So how would I check it? I saw a mental cap on top of the diff, it pops up and down when I pressure it with my finger
  6. May 17, 2012 at 4:43 PM
    cheese7882
    California
    Lol, I won't. You guys think its good though, got enough fluid in?
  7. May 17, 2012 at 4:45 PM
    cheese7882
    California
    Btw, its a small tacoma, 2wd, 4cyl 2.4l the rear diff isn't that big to begin with
  8. May 17, 2012 at 4:48 PM
    mcaaron
    mcaaron Member
    Aaron
    Fallon, Nevada
    06 Taco
    OME lift K&N Intake Flowmaster dual exhaust BFG MKII's
    I just changed out my fluid a few days ago, the manual calls for 2.8 quarts on the 4x4. I'm curious why yours didn't take more than that, something doesn't seem right. Mine took almost dead on the 2.8 to get fluid to come back out the refill cap. I would pop off the refill plug and try to top it off. I personally wouldn't run it without the proper amount of fluid in there..
  9. May 17, 2012 at 4:53 PM
    cheese7882
    California
    If I try to add more, it pours out as fast as I can pour it in.
  10. May 17, 2012 at 5:22 PM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    Look in the manual. 1.43 qts for that axle.
  11. May 17, 2012 at 5:29 PM
    mcaaron
    mcaaron Member
    Aaron
    Fallon, Nevada
    06 Taco
    My bad, didn't take the time to check which rear end you had, should be be good to go if it's at the top...
  12. May 17, 2012 at 5:44 PM
    cheese7882
    California
    Awesome, thanks everyone for the help.
