Rear diff howl update.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gfenza89, Apr 10, 2023.
  1. Apr 10, 2023 at 12:53 PM
    Gfenza89
    Gfenza89 [OP] Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Took my 2023 taco to a third dealership today to address the rear howling diff and gear noise coming from the rear at all variations of speeds. It’s not resonance like people are saying(at least on my truck) if you open the windows you can hear the rear diff making all kinds noises and humming. Anyway top tech put my truck on the lift and ran it while listening to the rear. He came back to tell me the diff is screaming and grinding internally . They ordered a new carrier assembly today and will start the job on Wednesday. Thank god at least one dealership took the time to investigate this for me.
    Squirt, stftaco, Gatafly and 12 others like this.
  2. Apr 10, 2023 at 5:17 PM
    FLAK-TAC
    FLAK-TAC Only banned twice…so far
    SW Florida
    2022 TRD OR LB
    Hopefully the new one won’t start howling on you…mine did
  3. Apr 10, 2023 at 5:27 PM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    One of the reasons I didn't trade up when I had the chance. Mine doesn't howl.
    zoo truck, Gfenza89[OP] and bulalo like this.
  4. Apr 10, 2023 at 5:35 PM
    Gfenza89
    How soon did it start howling?
  5. Apr 10, 2023 at 5:37 PM
    Gfenza89
    Starting to think these trucks suck honestly lol
    kahanabob likes this.
  6. Apr 10, 2023 at 6:00 PM
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    You should hear my 4.88s.
    Darkice likes this.
  7. Apr 10, 2023 at 6:04 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    My 2021 had a howl. It was the automatic with 3.90's. My 2022 has a faint ringing/howl to it, a whole lot less than the '21 though. It has the 4.30 gears being a 6MT. Weird. They all do it in some form.
    Gfenza89[OP] likes this.
  8. Apr 10, 2023 at 6:04 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    I don’t see how there could be grinding while it’s still happily driving down the road. It would also have very dirty fluid.
    Obviously I can’t listen IRL but I’d make a small suggestion that too big a deal is being made out of this, but I suppose if the dealer is willing to swap the diff then it’s worth a shot if it won’t inconvenience you too badly.
    I will say my stock 4.30s made no more or less noise than any other truck I’ve ever owned. Same for my now 5.29s, no more or less noise than anything else.
    jsinnard, Chew, Gfenza89[OP] and 2 others like this.
  9. Apr 10, 2023 at 6:21 PM
    Halloween
    Halloween Well-Known Member
    Toyotas a plenty
    Sounds like a good excuse to just re-gear :)
  10. Apr 10, 2023 at 6:50 PM
    FLAK-TAC
    SW Florida
    2022 TRD OR LB
    Within 500 miles
  11. Apr 10, 2023 at 6:51 PM
    Cushmaat
    Cushmaat Well-known wiseass.
    SE AZ
    2022 TRD OR 4x4 DCLB MGM
    My '22 Taco sounds identical to my '06 T4R. The '06 whined since new, and has never gotten louder. Only from 45 to 50 mph, both vehicles. Not before, and not after...but always between those speeds. It is part of the charm! I actually listen for it. I'd be concerned if it suddenly stopped!
  12. Apr 10, 2023 at 9:03 PM
    GBourne
    GBourne Just a regular guy
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    Dumped the Tacoma, that's all it needed.
    Mine howls a bit at all speeds.
    it’s under warranty and will be for a while. I’ll drive it until it explodes or until they notice it at service time.
  13. Apr 11, 2023 at 3:44 AM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    op, sounds like your issue is something other than the common rear diff whine many of us have. it'll be interesting how this turns out, keep us posted.
    the rear diff on my truck whines a bit in the 50-60 MPH range. seems to occur more going downhill when coasting as opposed to pressing the gas pedal. changing the fluid to amsoil SG 75W-90 had no effect whatsoever. the noise is fairly low and for now, i plan to live with it and as long as it does not get worse, i will leave it as-is.
  14. Apr 11, 2023 at 4:02 AM
    Gfenza89
    I’ll deff let you guys know. Mine is LOUD
  15. Apr 11, 2023 at 4:17 AM
    Gfenza89
    Can you describe your howl to me ? I’m curious what you’ll say. Mine sounds like wind noise at lower speeds but it’s actually the diff, roll windows down and you can hear coming from under the truck in the rear
  16. Apr 11, 2023 at 4:33 AM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    As perfect as Toyota is (according to TW) it amazes me that they have so much trouble setting pinion depth at the factory.
  17. Apr 11, 2023 at 4:40 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    No howling here either. Is it mostly related to one trim line, or the entire tacoma line?
  18. Apr 11, 2023 at 5:15 AM
    Gfenza89
    Entire line I think. It’s the first tacoma I had that hummed
  19. Apr 11, 2023 at 6:41 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Mountains of evidence indicate.... that ain't it.
  20. Apr 11, 2023 at 6:50 AM
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    Is the diff howl a 4x4 thing or are 2wd getting it too? I hear nothing out of the ordinary with my 2wd other than pretty obviously the engine humming along while cruising. Then again I fly them and lived life around jets for years and my ears aren’t what they were.
