Rear diff info needed
Discussion in 'Suspension' started by kingN8, Dec 11, 2009.
  1. Dec 11, 2009 at 7:43 AM
    kingN8
    kingN8 [OP] Well-Known Member
    Southern Mississippi
    05 Impulse Red Corolla S
    What are some scenarios that i would need to use the rear diff in my tacoma? would it be used for going uphill on gravel roads or rough terrain?
  2. Dec 11, 2009 at 7:50 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Essentially.....
    You're using your rear diff every time you drive the truck. :D:D
    Not exactly sure what you're asking....and I don't want to make any assumptions.
  3. Dec 11, 2009 at 7:52 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    I am thinking he means his Diff lock. I know what ASSuming gets me though.
    Any time you may lose traction you can use your Diff lock.
  4. Dec 11, 2009 at 9:09 AM
    kingN8
    yea i meant the diff lock that comes with the trd off road package. so would going uphill on gravel result in loss of traction??
  5. Dec 11, 2009 at 9:10 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    Sure. No harm there just try to stay off of the blacktop and high traction areas.
  6. Dec 11, 2009 at 9:54 AM
    kingN8
    gotcha, i kinda had an idea of what it was used for but wanted to make sure
  7. Dec 11, 2009 at 11:54 AM
    Janster
    Jandy
    Lancaster, PA
    Maybe....
    Try it in 4WD and see if you make it. The 4WD in these trucks are pretty damn capable without lockers.
    Having the locker is nice for when you actually lose traction, you have that to help you get unstuck/gain traction.
  8. Dec 11, 2009 at 11:51 PM
    CJH9980
    CJH9980 Well-Known Member
    Clint
    Shreveport, LA
    2010 TRD OR 4x4
    5100's, Eibach springs, Toytec AAL, Total Chaos UCA's, MetalMiller Skid
    Are our trucks the only ones that come w/ a factory locker?
  9. Dec 11, 2009 at 11:59 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Well I know Nissan offers locker options in their Nismo package. Any Nissan with a H190 rear end has one I think. They also have a Salisbury-type limited-slip unit on them. Basically the same/similar setup to Toyota, which you'd expect given that the Titan and Forrester compete directly with Toyota models. And Nismo is their answer to TRD.
  10. Dec 12, 2009 at 12:00 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    kinda hard to use 4x in a prerunner... unless he uses the james3492 magic button.
    OP- If you cant make it the first time try again with it locked...
  11. Dec 12, 2009 at 12:03 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Pretty much what he said, Don't use it in snow or Ice, If you happen to need it, use it in snow only and dont make turns in snow while its on.
  12. Dec 12, 2009 at 12:04 AM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    The newest GMC sierra now come with a rear diff lock
  13. Dec 12, 2009 at 12:04 AM
    mountainwolfpup
    Vancouver, WA
    OK, without doing any modification the TRD rear locker only engages if the drivetrain is in 4WD low and you are traveling under 5mph (I think). So it's really unusable for driving down a dirt road, going up a hill, etc. Really it's only use is to assist the 4WD low in getting you out of a sticky situation.. like the time I buried my taco to the frame in deep sand, oh and I was pulling a trailer.
    The limited slip in the rear axle is far more useful and works in 2WD, 4WD, whatever. and it engages and disengages automatically. That is what helps you on dirt, gravel, snow, ice, and other loose roadways.
    That is until you do the mod to free your locker from the above mentioned constraints and engage it whenever you like :) I have heard that Prerunners have this ability already?
  14. Dec 12, 2009 at 12:05 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    I use my locker whenever i'm out in soft ddeep sand, thick mud and steep uphill stuff...gets me through 90% of the time...the other 10% is me being a dumb ass :laugh:
  15. Dec 12, 2009 at 12:05 AM
    Yoytoda
    Roland
    completely stock
    ??? why ??? Itll give you more traction, just dont stomp on the gas in snow. It will want to tend to fish tail but keep that in mind and youll be fine. If your in deep at a stop sign unlocked you wont move, lock it and youll get twice the traction.
  16. Dec 12, 2009 at 12:07 AM
    Yoytoda
    Roland
    completely stock
    The op has a 2wd Prerunner according to the info under his avatar.
  17. Dec 12, 2009 at 12:08 AM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    I was told not to use it in snow and Ice, because as the inside tire spins it wants to break loose and will cause you to fish tail.
    Edit, Well maybe snow is ok but definitely not ice
  18. Dec 12, 2009 at 12:10 AM
    mountainwolfpup
    Vancouver, WA
    Thanks Yoytoda I missed that. So he can use that thing like it's supposed to be used.. whenever he wants :)
  19. Dec 12, 2009 at 12:11 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    2 spinning wheels on ice = FAIL :p
  20. Dec 12, 2009 at 12:11 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    but it also states he has a TSS package that doesnt include a locker either
