rear diff leak??
Discussion in '1st Gen. Tacomas (1995-2004)' started by shell waster, May 14, 2013.
  1. May 14, 2013 at 4:07 PM
    shell waster
    shell waster [OP] Member
    Sport
    Long bed
    So my pumpkin housing is leaking trans fluid. Mechanic can't find rebuilt/used so buying a new housing. Leaving in 2 weeks on trip hauling 2 ATVs about 500 miles. Dumb ? If my rear trans acts up or burns up, can I just disconnect the rear axel and drive in 4wd for temporary fix if stranded
  2. May 14, 2013 at 5:09 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    yeah... but no worse then this thread
    wtf is rear trans ?
    trans fluid in the axle housing ?
    I give up
    If yer going on a 500 mile trip with a leaky axle housing...
    be sure to check it and keep that topped off.
    Only you know how rapid that leak is.
    You should make it, if it's not leaking too fast.
    [SIZE=2]good luck with it.
    [SIZE=2]AAA[SIZE=2] wo[SIZE=2]rks great [SIZE=2]when[/SIZE] y[SIZE=2]er[/SIZE] luck runs out [/SIZE][/SIZE]:D[/SIZE][/SIZE]
  3. May 14, 2013 at 5:12 PM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    If your "DIFF" is leaking then follow ^^^^^ advice... would not suggest the 4wd to get home if rear grenades. but do what you gotta do. And if your mechanic cant find reseal kit go to a new mechanic you can buy em from ECGS....
  4. May 14, 2013 at 5:14 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Sounds like youre being scamed.
  5. May 14, 2013 at 5:33 PM
    shell waster
    Sport
    Long bed
    Obviously I am no mechanic but where the rear Axel meets the drive shaft, that big metal housing rusted out and is leaking. Sorry not a gear head so if using wrong terms don't get ....
  6. May 14, 2013 at 5:44 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    so yer now referring to the the third member ?
    leaking from the pinion bearing or seal of the 3rd to the axle housing ?
    the 3rd member housing is purdy stout... can't see that leaking of itself.
    and yer mechanic says you need a new axle housing ?
    something isn't right here...
    and you need to learn more about yer junk
    so you don't get shafted by others.
    start by reading thru your model year's factory service manual
  7. May 14, 2013 at 5:45 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    answer is YES, if you have a 4x4 and the rear end goes dog shit,
    you can drop driveshaft and drive in 2wd front drive, as an emergency
    measure. it is not ideal to do so, but hell, drive 350 miles or 1000 nothing
    should break*
    *as long as the rear wheels rotating do not further
    destroy or chew up the rear diff and actually cause it to break open
    or destroy a rear axle or the housing
  8. May 14, 2013 at 6:01 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    ^ sometimes ya get lucky... sometimes not
    if the differential grenades...
    little chunks of gear teeth and other metal fragments
    could effectively lock/seize the differential to the carrier.
    ^ this could effectively lock the axles up.
    low or zero oil level... could cause metal weld
    but that would be better then fragmentation.
  9. May 14, 2013 at 6:08 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    post pictures of said leak. so we can help you make the riht choice.
  10. May 14, 2013 at 6:34 PM
    Ghost848
    Tony
    Alberta,Canada
    ^^^X2 well help you out best we can..
  11. May 14, 2013 at 8:22 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Personnaly, I would just make sure that the diff is full of oil before your trip. Use something thick like 90-130 gear oil. That is unless oils is just pooring out of your diff but I doubt that.
