Rear Diff Lock Anytime Mod 3rd Gen DEVELOPMENT
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BigWhiteTRD, Mar 8, 2018.
  1. Dec 11, 2018 at 2:13 PM
    #241
    BigWhiteTRD
    BigWhiteTRD [OP] Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Schematic certainly shows it as a direct connection, although it goes from the switch to connector R44, then to connector IN1, before going to the ECU or ground...
    I havent wrung out that section
    Dragracer_Art[QUOTED] likes this.
  2. Dec 12, 2018 at 6:04 AM
    #242
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    Maybe this relay would be more appropriate. Single trigger to latch and unlatch.
    https://www.amazon.com/FUXU-Flip-Fl...544623337&sr=8-1&keywords=flip+flop+relay+12v
  3. Dec 12, 2018 at 6:33 AM
    #243
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Just a thought locked rears are a bad thing on dry pavement, locked diffs will drive ABS nuts and will break things much quicker in high range.
  4. Dec 12, 2018 at 7:07 AM
    #244
    Dragracer_Art
    Dragracer_Art Tundra for the win
    GA
    2020 Tundra Crewmax 4x4
  5. Dec 12, 2018 at 1:05 PM
    #245
    Pyrotech
    Pyrotech Well-Known Member
    Some parts where dropped off earlier today.
    johntoyota likes this.
  6. Dec 12, 2018 at 1:55 PM
    #246
    Dragracer_Art
    GA
    Wow !
    Looks like somebody is going "all-in" :thumbsup:
  7. Jan 4, 2019 at 12:48 PM
    #247
    luminous
    luminous Well-Known Member
    Has anyone been able to confirm that the 10 pin and 40 pin connectors actually fit? Id love to do this for the 2low mod but only if I can make a removable harness.
  8. Jan 4, 2019 at 12:51 PM
    #248
    BigWhiteTRD
    Ted
    Nobody I know of.
    I have started wiring a set up, ASSUMING they fit.
  9. Jan 4, 2019 at 12:53 PM
    #249
    luminous
    Do you plan on test fitting anytime soon? If not I might just order and hope for the best lol
  10. Jan 4, 2019 at 1:00 PM
    #250
    BigWhiteTRD
    Ted
    The way life is working, it isnt looking good anytime soon. (On a layover enroute to Peru at the moment)
    Visually it looks really good, I would go for it.
    I bet it works, or worst case works with a little trimming... but not sure.
  11. Jan 4, 2019 at 1:02 PM
    #251
    luminous
    Haha, well enjoy the view at least! Thank you. Gonna get everything I need listed out and order it this weekend.
  12. Jan 4, 2019 at 1:52 PM
    #252
    Pyrotech
    have not tried the connectors yet as I have been waiting on parts to arrive. My plan is to make the 2 low mod first with the removal harness. and then add in the rear lock anytime mod.
    fredgoodsell likes this.
  13. Jan 4, 2019 at 8:04 PM
    #253
    soggyBottom
    soggyBottom Well-Known Member
    Anyone have any concerns about turning on the diff lock when it should not be? Like driving down the freeway. It's unlikely but sooner or later it would happen.
    :::Edit:::
    Maybe use the vsc switch to arm it?
  14. Jan 4, 2019 at 10:00 PM
    #254
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    Thanks for all your hard work on this mod. Looking forward to It!
    magnus 15 likes this.
  15. Jan 5, 2019 at 6:55 AM
    #255
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    yes it is a possibility. Same as the old "grey wire mod" on the gen1 Tacoma's. This will definitely be up to the driver be aware and make good decision. I'm willing to take that responsibility with my truck.
  16. Jan 5, 2019 at 8:11 AM
    #256
    Dragracer_Art
    GA
    One of my biggest concerns after seeing pictures of the elocker on a workbench... is the speed factor.
    The sticker on the doorjamb says not to exceed 5mph.
    I believe this is because part of the locker remains stationary within the diff... so that means the rest of it turns with the carrier.
    I have no idea how its otherwise constructed (bearings/bushings/etc) so its entirely possible that it could self destruct at what may seem like safe speeds of 25-35mph.
    I think before I start hotwiring mine... id like to see more of how its constructed and possibly get an opinion from one of our diff builders/vendors here.
    Id love to be able to run up a snow covered hill with the diff locked at 25mph... but not if its gonna smoke the locker.
    Odi412 likes this.
  17. Jan 5, 2019 at 8:18 AM
    #257
    fatboyfirebass
    I have been following the 5.29 Mega Thread.. and based on the build that is shown on pages 15 through 17, I believ @ZUK would be able to shed some insight to the inner workings of this mechanism.
  18. Jan 5, 2019 at 9:05 AM
    #258
    TS7xTaco
    TS7xTaco Warlock
    Charles
    New Mexico
    16 Super White TRD-OR DCSB
    ARB Locked, Nitro 5.29's, Cooper 315's, 16x8 Methods, Cab mount hacked, Firewall Hammered, OME Suspension, Camburg UCA's, ARB OBA, RCI skids and sliders, WarFab Front Bumper, Home Brew Rear Bumper, Orange Virus Tuned, Dobinson Snorkel, Cobra Comms...
    You dont know me, so you shouldn't trust what I say, but the locker will not self destruct if driven 25 mph. The 5mph limit is for your safety, not the lockers safety. The locking carrier will spin as fast as you can drive your truck, not that you should... On the other hand you should gain experience in how the truck drives with the rear locker engaged because it will be more likely to want to swap ends. Having the locker engaged will also put more strain on a hand full of parts, but if you're locking axles you are probably out having fun and should know that your chances of breaking shit is probably less than probable but still you're taking chances with every obstacle. Take off the foil hats, and have fun.
    Odi412 and Pyrotech like this.
  19. Jan 5, 2019 at 11:18 AM
    #259
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Truth. The 5mph warning is CYA lawyer speak. It's fine to drive over that, just should be done with some thought and caution.
  20. Jan 5, 2019 at 12:25 PM
    #260
    traumahawk
    traumahawk Well-Known Member
    2017 Tacoma TRD Sport manual, quad cab, short bed
    Icon stage 4 +3in with spring pack, OV Tuned, total chaos UCAs, Victory 4x4 strike front and rear bumper, Warn 9.5ti winch, full CBI underbody armor, AP kick out sliders, softtopper canopy, method wheels, BFG AT KO2, leather seat kit, Safari snorkel, 4.88 gears, MBRP cat back exhaust.
    Very similar locker is used in the first and second gen Ford raptor. Those will stay locked to 99mph. The only failure I saw in those was from locked burnouts.
    Odi412 and Dragracer_Art[QUOTED] like this.
