Rear Diff Lock Anytime Mod 3rd Gen DEVELOPMENT
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BigWhiteTRD, Mar 8, 2018.
  1. Mar 19, 2019 at 6:40 PM
    #281
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Agreed, still waiting on quotes from a few of the places on Alibaba.
    That 12 pin connector is a good example of how big companies can use their power of the "P" word. That connector is 100% identical to an off the shelf Yazaki connector that is readily available. The only difference is that one rib you are referring to. I believe it is made by either a partner or sister company called Tokai Rika that likely only sells to OEMs in volume and is likely a Toyota specific proprietary connector. I don't know how that Rakuten seller is getting them, but I'm guessing they find their way out the back door. I'm still not sure how you ended up with the wrong one since my 2nd order came through perfectly, except for my f-up.
  2. Mar 20, 2019 at 12:24 PM
    #282
    BigWhiteTRD
    BigWhiteTRD [OP] Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Original Post Updated with some conclusions. Will add more as I think of stuff
  3. Aug 29, 2019 at 2:51 PM
    #283
    Reluctanse
    Reluctanse Granny shiftin, not double clutchin
    Sam
    Newberg, Oregon
    '17 Tacoma DCSB Inferno TRD OR 6MT
    OVTuned, Grabbers, 5100s, Bakflip VP
    Anyone touched this in a while? Thanks to OP for all your efforts here, understood you are now bowing out. The OVTune option appears off the table as well.
    Seems like someone was working on a PWM controlled discreet harness and switch that would bypass all the factory stuff, any luck?
  4. Aug 29, 2019 at 2:56 PM
    #284
    lapoltba
    CT - 06076
    I stopped looking into it because there is no nice way to also disable ABS and traction control. The electronics side is fairly trivial.
    Mikeybuck likes this.
  5. Aug 29, 2019 at 3:16 PM
    #285
    BigWhiteTRD
    Ted
    No work here
    Taking over manual control to lock it is pretty easy (and has been done).
    Spoofing the ECU (to try and have the ECU lock and disable ABS) proved to be beyond my attempts.
    (For now, time to prep for hurricane)
    perkj likes this.
  6. Sep 20, 2019 at 3:38 PM
    #286
    WVditchdiggin
    WVditchdiggin Well-Known Member
    2020 Quicksand dbcsb manual
    Duratrac 265 75 16 load c, cheap tonneau cover, total chaos bed stiffener, kicker tweeters (not really upgrade in 2020)
    I need this.....tgus is the problem with modern crap. I wish they would keep it simple, we all know they could and still have the same functionality. They dont like us fooking with thier systems and would make them easy to work on....like I said they dont want that so they make them as complicated as possible within reason. Makes me second guess trying to keep this truck for more than 10 years.
  7. Jun 27, 2020 at 9:24 PM
    #287
    Taco Guy11
    Taco Guy11 Well-Known Member
    Joe
    Western Maryland
    2020 Tacoma TRD off-road
    Well good thing I found this thread before I bought a 2020 off-road. I knew the locker only worked in 4lo but I was hoping you could modify it like the 2nd gen to work in 4hi. Well this makes me second guess my decision on buying and off-road and buying a sport or sr5 and doing an arb or something similar.
    MickeyB and yub like this.
  8. Jul 17, 2020 at 4:24 PM
    #288
    MickeyB
    MickeyB Well-Known Member
    '17 TRD OR 6MT 4x4
    Mobtown skids and sliders
    I had a Lock Right locker in my first gen and it was great having it all the time while off-road, not just in 4Lo.
  9. Jul 17, 2020 at 4:25 PM
    #289
    MickeyB
    '17 TRD OR 6MT 4x4
    And the 2WD OR models can lock in 2WD (obviously) Just a shame they don't allow the 4WD trucks to do it.
    RedWings44, SC4333 and doublethebass like this.
  10. Aug 22, 2020 at 9:05 PM
    #290
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Has anyone figured this out yet?
    @Shellshock , @tonered , is there anything in Techstream that could help us get a locker anytime mod? It was so simple on the first gen. Ground out the gray wire on the 4wd module, and you were set. Now this shit seems like rocket science! @OVTune, do you or your boys have the knowledge for something like this?
  11. Aug 22, 2020 at 9:44 PM
    #291
    lapoltba
    CT - 06076
    I know how to do it, two different ways. The first, I'm not sure I want to mass produce. The Second is awaiting my time to make a test harness.
    Techstream is of no use here unfortunately.
  12. Aug 23, 2020 at 5:16 AM
    #292
    Shellshock
    Iowa
    ^ this is your best hope
  13. Aug 23, 2020 at 6:11 AM
    #293
    Mooseditty17
    AJ
    WI
    Is there anything any of us can do to help?
  14. Aug 23, 2020 at 6:16 AM
    #294
    Shellshock
    Iowa
    Wait patiently while he works his magic. The 2lo kit he made was amazing.
    perkj, b3itz, iDrew and 4 others like this.
  15. Sep 6, 2020 at 5:44 PM
    #295
    lapoltba
    CT - 06076
    So I have revisited my thoughts on not being able to disable TRAC and ABS when using the locker anytime mod.
    I am drawing up a schematic now to have a PCB made up that will hold an Arduino, all the necessary power stuff, and the relays. It will include the 2LM functionality as well. I believe I can use the existing locker button and you would only need a 2Lo button (optional).
    The question is, what is it worth to people? With the custom fab and short runs of PCBs, I expect it will almost double the cost of the 2LM itself.
    antlab67, perkj, lilmike and 3 others like this.
  16. Sep 6, 2020 at 5:52 PM
    #296
    bodean
    bodean Well-Known Member
    Shawn
    Crowsnest Pass, AB
    02 Taco RCSB, 16 Taco AC6MT, 07 FJC, 22 Bronco
    Personally, just looking for the 2LM.
  17. Sep 6, 2020 at 6:09 PM
    #297
    Mooseditty17
    AJ
    WI
    How much is 2Lo mod? I'm seriously interested in the locker anytime mod!!!
    I'll take a survey on the FB Tacoma groups and see what the people have to say as well.
    antlab67 and lapoltba[QUOTED] like this.
  18. Sep 6, 2020 at 6:10 PM
    #298
    lapoltba
    CT - 06076
    $115 and $130 shipped USA/Canada. Sold out now, but I will be starting another GB.
    johntoyota likes this.
  19. Sep 6, 2020 at 6:11 PM
    #299
    Mooseditty17
    AJ
    WI
    So $250 for locker anytime? I'm in!!!
  20. Sep 6, 2020 at 6:12 PM
    #300
    lapoltba
    CT - 06076
    Yeah, that's probably in the ballpark. I won't know until I get it designed and have pricing from the vendor.
    perkj likes this.
