Rear Diff Lock Anytime Mod 3rd Gen DEVELOPMENT
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BigWhiteTRD, Mar 8, 2018.
  1. Sep 7, 2023 at 8:41 PM
    #481
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Yeah, sorry about that.
    Technically, I’m a few years short of qualifying. But heck, it’s what all the whippersnappers call anyone over 45.
  2. Sep 12, 2023 at 3:33 PM
    #482
    BigWhiteTRD
    BigWhiteTRD [OP] Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Can you provide SOME detail on the passenger side wire function that (I assume) disables traction control... (does it replace pressing the button, transmit CAN messages, ground a signal, etc)
  3. Sep 12, 2023 at 4:31 PM
    #483
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I'm guessing CAN is involved somehow...
    Looks a lot like the Bud's Custom anytime locker(AUS), that's no longer available.
  4. Sep 12, 2023 at 4:44 PM
    #484
    ExperiMentaltaco
    ExperiMentaltaco Active Member
    Josh
    2023 Tacoma TRD Off-Road
    It is on the drivers side, It is for traction control and it just duplicates the ground signal just like the Trac off button. It doesn’t disable the button though.
  5. Sep 12, 2023 at 6:20 PM
    #485
    BigWhiteTRD
    Ted
    AHHHH you are right.
    I got confused because the pdf instructions PICTURE says IA5 Pin 15, and the text instructions in the pdf says IA5 Pin 19.
    As you said, this is the roof VSC switch line
    So I assume this installation will NOT disable ABS, unlike the Toyota installation.
    (not that I know WHY Toyota disables ABS when locking the rear).
  6. Sep 12, 2023 at 6:25 PM
    #486
    ExperiMentaltaco
    Josh
    I just used that connector because it’s the same throughout all the model years.
  7. Sep 12, 2023 at 6:26 PM
    #487
    ExperiMentaltaco
    Josh
    And it does not disable ABS
  8. Oct 1, 2023 at 6:26 AM
    #488
    sandfantom
    sandfantom Member
    Kansas
    2020 TRD Off Road
    DIY Skid Plate, Anytime Locker Mod
    I got this installed first of the week and so far everything seems to work fine. Took me about 45 minutes to get the main part of the unit put together to test it and another 45 minutes to run the 2 wires for the indicator light up to the overhead console including drilling the hole and changing the map lights to leds etc.
    I like the idea of a locker I can switch on at will. So far I am happy with it.
  9. Oct 12, 2023 at 6:02 PM
    #489
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    got kit installed earlier today. works great!
    Toy_Runner and RedLantern like this.
  10. Oct 17, 2023 at 4:20 PM
    #490
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Any word on compatibility with the 2wd-Low range harness?
    Locked 2wd lo would be very helpful for towing and at the boat ramp.
    wayupnort likes this.
  11. Oct 17, 2023 at 4:22 PM
    #491
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Isn’t that possible with just the 2lo harness?
  12. Oct 17, 2023 at 4:44 PM
    #492
    Toy_Runner
    99 4Runner SR5
    Yes, but only at low wheel speeds. For toght maneuvering and boat ramp use, that's fine. But occassionally you need some wheel speed.
  13. Oct 17, 2023 at 4:57 PM
    #493
    kona61
    kona61 Well-Known Member
    J
    LR 2022 Tacoma TRD OR
    RCI Skids
    So what would happen if I installed it without the T-tap and just manually pressed the traction control button?
    thecespedes and moon22 like this.
  14. Oct 26, 2023 at 4:59 AM
    #494
    QuikSand448
    QuikSand448 Member
    Jake
    2019 TRD OR 6MT
    Has anyone tried the compatibility with 2low mod yet ? Otherwise I might have to buy the experimental designs kit and EXPERIMENT
  15. Oct 28, 2023 at 9:28 AM
    #495
    moon22
    moon22 :-|
    SW Mitten, for the moment..
    '12 TRD OR ACLB 6MT
    FJ AWD Swap & 3G Pro Suspension
    I'm going in.
    Doing this and 2-LO at the same time. Didn't realize I would be piggybacking a piggyback harness; an all-in-one solution, while too late for me now, would be worthwhile..whole lotta connections going on there. Not sure if there's a preferred order to them but I will start with 2-LO first and the locker harness in to it..no particular reason. I am also going to try skipping the T-tap connection and see if manually disabling works before I button everything back up, I hate nicking up insulation and conductors with those taps.
    BigWhiteTRD[OP] and Toy_Runner like this.
  16. Oct 28, 2023 at 12:07 PM
    #496
    Thegrassisalwaysgreener
    Thegrassisalwaysgreener Well-Known Member
    Manitoba
    Just ordered mine, I'm so used to my zr2 where I could have the rear locker whenever I wanted. I miss that with my taco
  17. Oct 28, 2023 at 2:16 PM
    #497
    bizarrocolin
    bizarrocolin Well-Known Member
    Colin
    SoCal
    Blue 2016 TRD OR 4x4 DCLB
    I finally got around to installing mine, with an existing installed 2-lo harness. It doesn't seem like they work together, at least the way mine was configured - which was 2-lo harness into the 4wd ecu, and the anytime diff lock plugged into the back of that. Let anytime diff lock seemed to work, the LED lit up, and the traction control turned off. Additionally, the factory 4 hi/lo was functioning normally. But the 2-lo didn't seem to be working. After engaging the button, I could hear the transfer case click after switching from 2 to 4wd. Also, I tried to force an error, and disengage 4-lo while the 2-lo button was still on, and I did not receive the error message.
    I will dig back in tomorrow, and change the order of harnesses to see if that changes anything.
    BigWhiteTRD[OP] and QuikSand448 like this.
  18. Oct 28, 2023 at 2:23 PM
    #498
    Manitoba
    Keep us posted about skipping the tap method. I would like to know if that works. I feel the same way about tapping into wires. I usually cut them and solder the wire in then heat shrink them to avoid it
  19. Oct 28, 2023 at 2:33 PM
    #499
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    Caveat: I have not driven extensively since completion - driveway/yard test only.
    But, that said - all success here. Worst part was just jamming all the harness in to place to clear the glovebox. It seems to work independently of the ABS/TRAC state, I was able to turn the locker on, get a solid status light, and it definitely was locked up (gravel drive). Works with and without 2-LO on. I am aftermarket light averse but there's a little slot on the side of the glovebox that the supplied light slides perfectly in to, so I'll just have to open the glovebox to check locker status..no big deal I say.
    And 2LO is going to be freaking awesome, I can already tell...
  20. Oct 28, 2023 at 2:44 PM
    #500
    BigWhiteTRD
    Ted
    Request pics of the light, if you get a chance... was assuming I would omit it if I bothered doing the mod... but a stealth light is a good idea...
