Rear Diff Lock Anytime Mod 3rd Gen DEVELOPMENT
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BigWhiteTRD, Mar 8, 2018.
  1. Oct 29, 2023 at 8:37 AM
    #501
    moon22
    moon22 :-|
    SW Mitten, for the moment..
    '12 TRD OR ACLB 6MT
    FJ AWD Swap & 3G Pro Suspension
    I put some double wall heat shrink and loom on it to snug the fit up but it was a bit much as far as added thickness so it doesn’t quite slip in now, but thought I would try it out before fiddling with it more. As it sits it actually points directly at the driver’s position though, so happy little accident there.
  2. Oct 29, 2023 at 12:31 PM
    #502
    bizarrocolin
    bizarrocolin Well-Known Member
    Colin
    SoCal
    Blue 2016 TRD OR 4x4 DCLB
    I reordered the harnesses this morning - the anytime diff lock in first, 2-lo in second.
    4-hi/lo functioned normally.
    2-lo seems to be functioning, i forced, and received the error message when rolling the dial back to 2 wd with the button still pressed.
    Anytime diff lock seems to be working as well. LED lit up, traction control turned off.
    It looks like these two products work together if connected in the right order (tho I freely admit there could be some installer error involved).
  3. Oct 29, 2023 at 1:31 PM
    #503
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    That is interesting, I have mine in the order you initially tried and it’s fine. Maybe a connection didn’t quite seat or something.
    BigWhiteTRD[OP] and bizarrocolin like this.
  4. Oct 29, 2023 at 1:56 PM
    #504
    bizarrocolin
    Colin
    SoCal
    Installer error for the win! I'm just happy they work together!
  5. Oct 29, 2023 at 4:26 PM
    #505
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    Agreed, they will be a handy duo - very glad people figured these things out!
    BigWhiteTRD[OP] likes this.
  6. Nov 15, 2023 at 5:18 PM
    #506
    Thegrassisalwaysgreener
    Thegrassisalwaysgreener Well-Known Member
    Manitoba
    Mine showed up and I got it installed without tapping into the traction control wire. Everything functions as it should, just have to turn off traction control with the button. I don't really understand why the wire to tap into traction is even included. That seems to be most people's hang up with this kit. Should be stated its optional on the site, I imagine alot more people would buy knowing that info.
    andthen, kas2828 and K9tacoma like this.
  7. Nov 15, 2023 at 5:35 PM
    #507
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    Mine also seems to work with traction control left on, but I've not used it a lot yet - does this eventually cause something to go off the rails?
  8. Nov 15, 2023 at 5:38 PM
    #508
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    Another thing is, at least on mine, I was able to snake my arm back behind everything, pop the blank out and install the switch/wire without having to remove the console.
  9. Nov 15, 2023 at 5:45 PM
    #509
    Manitoba
    I imagine if you have a trac on it could cause some issues if the brakes fight the locker. Though if your rear diff is locked a trac shouldn't be trying to assist the rear anyway. I'll only use mine with the traction control system completely shut off regardless. I just really don't like tapping into wires that are a pain in the ass to replace if they get messed up.
  10. Nov 15, 2023 at 5:49 PM
    #510
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    Well the times I have had it on for more than a second without TC off has been in 4HI, so A-Trac wasn't an issue there since it's 4LO only (isn't it?); and as I recall, 4LO turns TC off, does it not?
  11. Nov 15, 2023 at 5:54 PM
    #511
    Manitoba
    4 lo turns off everything including abs. A trac comes on with a short press of the tc button and you still have vsc on I believe. If you long hold the tc button it turns off trac a trac and vsc, abs is on unless your in 4lo. I would just long hold the tc button anytime your using the locker to be safe.
  12. Nov 15, 2023 at 5:58 PM
    #512
    Manitoba
    Maybe @ExperiMentaltaco wants to chime in as to the reason for tapping into the trac wire?
  13. Nov 15, 2023 at 6:17 PM
    #513
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    Sometimes...somtimes..............I forget things. :eek:
    Ultimately I'd like to hear from Mr. Mental as far as what he found that drove the need for tapping that wire before coming to any sort of speculation fueled conclusion. It may also be possible that they're just mimicking what OEM settings are in place when the locker is on and they figured out how to do it, but may not actually know if anything goes haywire if run with TC on..
  14. Nov 15, 2023 at 6:19 PM
    #514
    Manitoba
    I don't see any reason to run the locker with Tc on.
  15. Nov 15, 2023 at 6:23 PM
    #515
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    I don't either and I am not trying to for any reason, but I want to know if that wire is there just for convenience, or for the safety of the truck in some form or fashion. I can't think of what it would mess up, but hell hath no wrath like an onboard computer not seeing what it expects.
  16. Nov 15, 2023 at 8:12 PM
    #516
    BigWhiteTRD
    BigWhiteTRD [OP] Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    This is my GUESS....
    (And they haven't figured out how to easily shut off ABS, which OEM does as well as trac off.. )
    moon22[QUOTED] and ShimStack like this.
  17. Nov 16, 2023 at 6:22 AM
    #517
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Here is a view from a vehicle dynamicist. Don't forget we are talking about 2 different systems: VSC (stability control) and TRAC (traction control). My best guess is they just added this VSC/TRAC OFF function to the locker mod because it mimics what happens with the factory system. There's really no great reason to do it and only one specific situation where a locked rear may disrupt the action of the stock control systems.
    Traction Control
    2wd: In 2wd, the traction control systems (TRAC, autoLSD) are unaffected because these systems operate on rear wheel slip based on cross axle reference (autoLSD) or front axle reference. The corrective action is either individual wheel braking or engine cut. With the locker locked, there is never cross axle slip (both tires will always be rotating same speed) so autoLSD never even triggers. For traction control if one rear wheel slips then they both must be slipping so any corrective action (wheel braking or engine cut) will properly arrest the spin-up at the rear axle.
    4wd: Same thing here and since ATRAC and MTS are looking for cross axle slip there will never be any and the system will never trigger. For traction control it's also the same, if the truck detects forward wheel slip (front and rear must be spinning (4wd) and therefore both rears are slipping (rear locked)) then any corrective action (wheel braking, engine cut) will still properly address and arrest the slipping issue as intended.
    VSC:
    With VSC we are interested in keeping the vehicle under control and on its intended path based on speed and steering angle. In order to do this the vehicle will compare the actual state of the vehicle to the requested state. If there is a large or dangerous discrepancy the vehicle will attempt to correct the issue by cutting engine power or apply individual wheel brakes. The only issue here is if the diff is locked and the vehicle chooses to correct a stability error by applying *individual* braking to one of the rear wheels, then that corrective action may not have the intended effect. This is because applying a single wheel brake to a locked axle is effectively like applying braking to the entire axle and thus has a different effect on the dynamics of a vehicle than applying single wheel braking to a wheel that's coupled to the opposing wheel through an open differential. What the actual implications of this are in the real world with the stock Toyota control system, I don't know. But it's the only possible situation I can come up with where a locked rear could maybe interfere with any factory system.
    ABS:
    Locked rear should have zero effect and the system should operate like normal.
  18. Nov 16, 2023 at 6:43 AM
    #518
    Manitoba
    Well put sir, I'll just continue turning off everything before I use the locker.
  19. Nov 16, 2023 at 10:47 AM
    #519
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    So, who’s gonna go be the mad man who tries to go drifting with the locker and VSC still on? :D Short of some electrical demon, in my mind the worst that would happen is the ABS computer beating the snot out of the wheel it wants to slow down, and it sounds like someone (more qualified than myself) has the same hunch. And that would basically just be momentarily unless you’re just out doing the aforementioned drifting.
    And to re-iterate: this stems from wanting to be aware of potential damage from using this aftermarket system not quite as designed, not because I have some overwhelming desire to have a locked diff with all the systems active; is it just not ideal, or actually risks damage to the truck beyond a clearable error or something like that.
  20. Nov 16, 2023 at 10:58 AM
    #520
    Manitoba
    And this is the exact reason for the wire tapping into the traction system. To stop some poor uneducated fool from causing the systems to fight each other them blaming the company that made the mod lol. I was just out drifting in the snow we got this morning with everything off. Lots of fun, reminds me of my old truck.
