Rear Diff Lock Anytime Mod 3rd Gen DEVELOPMENT
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BigWhiteTRD, Mar 8, 2018.
  1. Nov 16, 2023 at 1:19 PM
    #521
    moon22
    moon22 :-|
    SW Mitten, for the moment..
    '12 TRD OR ACLB 6MT
    FJ AWD Swap & 3G Pro Suspension
    I am just trying to get a deeper understanding of why the wire mod is there since it seems to be an unnecessary step all together; did they find a problem that prompted figuring that out, or simply copying Toyota’s setting configuration? If I leave it like this and loan my truck out, do I specifically need to have a “don’t get curious and push this button or the truck’s computers will all simultaneously explode” talk?
    We’ll just have to speculate until someone involved in development of this mod chimes in, cause even if the programmers at Toyota and/or their suppliers who make this stuff sure aren’t going to say anything.
  2. Nov 16, 2023 at 1:41 PM
    #522
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    its a single ground wire tap in the cab not affected by the elements. not seeing what the big deal is anyways?
  3. Nov 16, 2023 at 1:57 PM
    #523
    Thegrassisalwaysgreener
    Thegrassisalwaysgreener Well-Known Member
    Manitoba
    It really isn't. I just wanted to test to see if it works without it, then it's 100 percent plug and play. If it works which it seems to then I'll just turn off traction myself no need to touch any factory wiring. Win win
    BigJosh likes this.
  4. Nov 16, 2023 at 2:48 PM
    #524
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    Yeah, but breaking the insulation means you run a risk of an electron leak. Then I would REALLY have a lot of questions.
  5. Jan 19, 2024 at 6:56 PM
    #525
    Tacotim12345
    Tacotim12345 Well-Known Member
    I know im late to the fourm but did you find anyone in the LA area that made your locker an anytime locker
  6. Feb 3, 2024 at 6:12 PM
    #526
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Somewhere on this thread someone asked for confirmation of the duty cycle of the Pulse Width Modulation to the locker coil. According to TechStream, my readings were 77% to lock and ~50% (46-54%) after lock at ~10VDC.
  7. Mar 14, 2025 at 9:58 AM
    #527
    Thatv8.naks
    Thatv8.naks New Member
    David
    4th gen v8 4RNR
    I have been following this post for a while and just been going over all the information that has been provided. It does seem pretty complex, but there’s gotta be a way that can simplify turning it on and off. I’m looking at my pigtail that goes onto the diff there’s literally just four wires is there something that we are overlooking or looking too hard into but I definitely invested a lot of time on my own, trying to figure it out and all your information is truly God sent, and I really think we can make it happen because as these trucks become older, these parts are gonna become more available and more people are gonna want to do this mod That’s my opinion
  8. Mar 14, 2025 at 10:00 AM
    #528
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    on my truck I deleted abs/add actuator/got rid of the electronic transfer case, so I just totally ditched the factory wiring and hooked up power/ground to the locker. Worked great, so you can do that if you delete everything else :rofl:
    eurowner likes this.
  9. Mar 14, 2025 at 10:03 AM
    #529
    Thatv8.naks
    David
    4th gen v8 4RNR
    so I’m taking all my notes down from this whole thread. And when you say you ditch the factory wiring, are you still keeping the pigtail that comes out of the diff and if so, how did you wire it up with just power and ground because from my understanding in this thread the actual actuator can’t take 12 to 14 V so I’m definitely interested in how you did yours because if that’s the case I can have this done today lol
