Rear diff lock button missing???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Acermcgraw, Mar 18, 2013.
  1. Mar 18, 2013 at 1:08 PM
    Acermcgraw
    Acermcgraw [OP] Member
    00 prerunner sr5 stock
    The 2000 prerunner i just got has an open spot where the rear diff lock switch should be, just a hole straight through in to the dash. cant see the button in there but i see an empty connector. Im wondering if the switch is plain old missing or it was never equipped with one in the first place. is there any other way that i can tell if i have a locker in the back before i buy a button, like the vin or something or a physical difference ? thanks guys
  2. Mar 18, 2013 at 1:18 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    u can just look at the rear diff and look for the locker, front side of diff. c if I can pull up a pic...
  3. Mar 18, 2013 at 1:19 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Look at the rear axle. There should be actuator bolted to it. Its boled to the side of third member. if its not there you dotn have elocker.
  4. Mar 18, 2013 at 1:23 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    x2
  5. Mar 18, 2013 at 1:24 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    The actuator will be on the drivers side of the diff if it has one.
  6. Mar 18, 2013 at 1:27 PM
    TIPICOTACO
    Tyler
    nw nj
  7. Mar 18, 2013 at 1:27 PM
    Acermcgraw
    a pic would be awesome since i dont know exactly what im looking for, also i did hit the gas hard and both of my rear wheels spun
  8. Mar 18, 2013 at 1:28 PM
    Acermcgraw
    also if i have a switch and its gone and im locked in the rear, would that be a bad thing. i do get some weird noises and some wheel hop going around tight corners?
  9. Mar 18, 2013 at 1:34 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    if you have a locked or live axle at road and highway speeds....
    it would be hard to steer on dry pavement, wear the crap out of your tires,
    and cause enough steering issues on corners that there is a real risk of flipping the vehicle in a ditch
    so hopefully it is not locked 24x7 or that would be sort of bad
  10. Mar 18, 2013 at 1:35 PM
    Acermcgraw
    thanks for the pic ill go look on my lunch
  11. Mar 18, 2013 at 1:37 PM
    Acermcgraw
    ok i d better figure it out then, is it noisier with the rear locked is it something you can hear
  12. Mar 18, 2013 at 1:40 PM
    Max-4_Yota
    Michael
    South Carolina
    Squattin'
    No, the tires will chirp in tight corners though.
  13. Mar 18, 2013 at 1:44 PM
    Acermcgraw
    alright thanks man really helpfull
  14. Mar 18, 2013 at 1:47 PM
    Acermcgraw
    both of my rear wheels spin when i hit the gas but according to the forum posts here, it doesn't appear that i have a LSD
  15. Mar 18, 2013 at 2:01 PM
    TIPICOTACO
    Tyler
    nw nj
    jack up the truck in the rear and hit the gas (in drive and not 4wd obv.). if both tires spin u r locked
  16. Mar 18, 2013 at 2:18 PM
    bellassaiw10
    Currituck NC
    If your tires chirp or you can feel them grab as you turn then your diff is locked in
  17. Mar 18, 2013 at 3:09 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    I am adding more words here, to help Acermcgraw:
    The locker is a small motor on the top, front, driver's side of the differential... and a wire goes to it (what the switch does)... as it is an E (electronic) -locker.
    When locked, both rear tires are 'locked' together... for extra traction off road. When you turn/ steer and drive, all tires must rotate at different speeds (the outside tires in a turn, rotate more). A differential allows the tires on the drive (rear) axle to turn at different speeds and power is biased to the tire that turns the easiest.
    Off road, or on slippery roads, one tire may spin, and you go nowhere. Locking the differential shares the power equally... both spin the same... less chance you will be stuck.
    On road, or dry pavement, if locked, steering will be hard and sharp turns, parking, etc, will be near impossible without 'chirping' the tires as they slide free in order to rotate more than the other tire... this is called 'binding' and could damage your truck!
  18. Mar 18, 2013 at 3:14 PM
    Conman117
    Conman117 AWESOME MEMBER
    Nathan
    BC, Canada
    98 Brap-coma
    Blue LED dash lights
    My '98 has a connecter behind where the button would be, but I don't have a locker. I'm sure they just have the extra wires in the harness because its easier to have the wiring all the same.
  19. Mar 18, 2013 at 3:16 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    power will be evenly distributed with both tires off the ground.....................................................................
  20. Mar 18, 2013 at 3:28 PM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    *Flashback to Marisa Tomei on trial in My Cousin Vinny*
