Rear diff lock light stays on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sirius heavy, Jun 20, 2019.
  1. Jun 20, 2019 at 11:29 AM
    sirius heavy
    sirius heavy [OP] New Member
    Ontario Canada
    Red 06 Tacoma trd off road
    Arb deluxe bull bar Titan winch Upgrade led head and tail light Front and rear light bars +1 tires 3”lift Rear bumper upgrade Sceptre cold air intake
    Hello
    I saw A thread about this on for them already, but didn’t see the answer to my question.
    I am in Canada, and up and told the switch on the diff is an assembly that will cost $1700. Does anybody know where I can get this cheaper, maybe in the US?
    Is anyone know if we can be purchased as a separate peace? Thanks
  2. Jun 20, 2019 at 11:47 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Is just the light staying on or is the diff actually staying locked?
  3. Jun 20, 2019 at 12:06 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Find the position switch back on the diff housing, it looks similar to a reverse light switch on a manual trans. Pull it out, clean it and work the plunger up and down with your thumb. Mine did the same thing and just working it in and out freed it up and made the light go out
  4. Jun 20, 2019 at 1:27 PM
    DeathCougar
    DeathCougar Active Member
    Josh
    Marysville, WA
    Hoping for a 2012-2015 Tacoma!
    If it is staying locked you can try lightly tapping on the housing with a soft hammer, that will often times get the motor to spin. At least enough to unlock it so you can rebuild/replace the motor
  5. Jun 20, 2019 at 2:00 PM
    sirius heavy
    Ontario Canada
    The diff is not locked, Just the light and ABS light associated with it are lit.
    I will Try to remove The switch and see. Any tips on the removal?
  6. Jun 20, 2019 at 2:35 PM
    RN923
    RN923 Well-Known Member
    Quebec Canada
    08 Tacoma TRD Off Road 6-MT
    Up in Canada, I’m assuming the under side of your truck looks similar to mine, soak that sucker in some penetrating fluid maybe a few times to hopefully let it work into the threads. Sensors like that are usually fine thread and it be really shitty if it snaps off on you
