Rear DIFF LOCK or NOT??
Discussion in '1st Gen. Tacomas (1995-2004)' started by 97widerider, Mar 10, 2009.
  1. Mar 10, 2009 at 5:15 AM
    97widerider
    97widerider [OP] Well-Known Member
    Indiana
    02 Tacoma SR5 Prerunner
    I have a 02 Toyota Tacoma SR5, PreRunner with the TRD package, 4 cyl, 2.7, 2WD. I am unusure if mine has the diff lock or not. I thought all TRDs did but after reading some posts, I am unsure. Should there be a DIFF LOCK button on my dash somewhere because I am sure there isn't? Maybe it is only in the V6? Thanks in advance.
  2. Mar 10, 2009 at 6:28 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    The locking differential was *NOT* included in the TRD Off Road Package on 4-cylinder automatics.
  3. Mar 10, 2009 at 9:10 AM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
  4. Mar 10, 2009 at 10:01 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Those pictures are from the 2005+ Tacoma's. The switch for the pre 2005 Tacoma's looks like this. Now this is only a pic of the switch I believe it is taken from a pre Tacoma so never mind the instrument panel. On the Tacoma's it is located to the left of the steering wheel on the dash.
  5. Mar 10, 2009 at 2:37 PM
    97widerider
    Indiana
    Thanks all, I finally found a comphrensive web site and got my answer but thanks for your replies. Kind of bummed now. That locker would come in handy up in the snowy north.
  6. Mar 23, 2009 at 8:06 AM
    thenrie
    thenrie Well-Known Member
    Stafford, VA
    2000 Tacoma, SR5, TRD, 2.7L (LEV), 4wd, 5sp m
    Magnaflow cat and cat-back exhaust, AFE Stage 2 cold-air intake system, 2.5" lift via Skyjacker leaf packs, Bilstein 5100s.
    Maybe, maybe not. With 2wd, locking your rear in the snow might just make it so you can't turn. It's good in mud and deep wet snow, but not all that good on packed snow unless you have 4wd. Both rear wheels turning with power at the same speed makes the truck want to go straight and if your front wheels don't have enough grab to turn (as on a snow-packed road), you will just keep going straight. I'm careful about it even in 4wd on packed snow. In that case I only use it to get unstuck or up a steep grade.:cool:
