rear diff locker 4cyl
Discussion in '4 Cylinder' started by jsosa, Nov 21, 2011.
  1. Nov 21, 2011 at 5:39 AM
    jsosa
    jsosa [OP] Member
    Julio
    Dominican Republic
    3 inch pro comp lift kit, Custom made 3/16" front winch bumper, 1.25" spidertrax wheel spacers, 10,000lb smittybilt x2o winch, propaine fuel kit.
    i didnt find it on the search option, so i am trying to get a locker for my 2gen 4cyl tacoma, and i havent find it, are the diffs the same on 4cyl tacoma and the V6 one?, so can i by a locker for v6 tacoma, will it fit mine?
    thanks a lot
  2. Nov 21, 2011 at 2:45 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I can't really give you any specific advise, but I know a lot of people recommend talking to the guys at Marlin Crawler, or East Coast Gear Supply, etc for reliable info. I'm also pretty sure a lot of people on this forum run Powertrax lockers/ no-slip setups. Sorry I can't be of more help.
  3. Nov 21, 2011 at 4:29 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Its also the most expensive... ARB locker and install will set you back $1500 or so... Powertax is around $300-$400 if you can do the install yourself. When installing Powertrax you don't need to set backlash on the gears... However ARB is selectable and powertrax is locked when you are on gas and unlocked when you are off the gas. Powertax is great for a trail rig, but would suck in daily driver...
  4. Nov 23, 2011 at 3:31 PM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    Detroit Locker is great although it is always locked (it does have some minute slip for around turns but not much)
  5. Nov 23, 2011 at 3:46 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    if its your daily driver don't put anything besides selectable in, just my advice.
  6. Nov 23, 2011 at 4:12 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    hells yeah
  7. Dec 4, 2011 at 10:26 AM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
  8. Dec 4, 2011 at 10:05 PM
    patpatpat
    patpatpat Well-Known Member
    '11 Prerunner SR5 4cyl 2WD DC
    Doesn't 2011 Prerunner have Auto LSD?
  9. Dec 5, 2011 at 8:30 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    ALL 2009+ Tacomas have TRAC & AUTO LSD... not at all the same as a locking differential, but better than nothing with the open differential.
  10. Jan 9, 2012 at 6:11 PM
    jsosa
    jsosa [OP] Member
    Julio
    Dominican Republic
    thaks for the info, know i have a confusion, if i get a rear 6 cyl diff with the OEM locker, will it work on my 4 cyl if i do the wiring?, is the diferential the same?
    thanks
  11. Jan 10, 2012 at 7:24 AM
    jsosa
    jsosa [OP] Member
    Julio
    Dominican Republic
    Why? I gess its the same just change the diff and its housing isnt it?.the axle , spline count and relation is the same i belive
  12. Jan 10, 2012 at 7:52 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN GEORGIA
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    arb is the best choice out there for a locker they are very well made and dependable.
    bjmoose is running arbs i think front and rear try asking him about them and how they perform iirc he raved about them.
  13. Jan 10, 2012 at 7:54 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    You'll see the difference the minute you unbolt the third member and try to fit the V6 lockable third on. Ain't gonna fit.
  14. Jan 10, 2012 at 8:02 AM
    05RedTaco
    Tony
    Scottsdale
    It "can" fit with modifications to the axle housing...
    http://www.4x4wire.com/toyota/tech/electric_locker/
  15. Jan 10, 2012 at 2:09 PM
    jsosa
    jsosa [OP] Member
    Julio
    Dominican Republic
    good thanks for all i think im gonna get ARB then because changing the whole axle wont be a good option, and either modifing it, i think TJM make e locker for that taco too ill check thanks! friends
