rear diff locker will not disengage
Discussion in '1st Gen. Tacomas (1995-2004)' started by rusty c, Jun 16, 2012.
  1. Jun 16, 2012 at 5:40 PM
    rusty c
    rusty c [OP] Member
    Rusty
    Galliano,la
    99' SR5 Prerunner
    5" susp. lift ,K&N FIPK, air aid throttle body spacer,true dual super 40 flowmasters
    i checked the switch, its good. but hen i push the buttin to disengage, nothing happens...wtf?
  2. Jun 16, 2012 at 5:59 PM
    scocar
    scocar Patron of the Farts
    Brock's right. In first gear, turn your steering wheel a little and begin moving forward slowly so the rear wheels want to rotate at different speeds. You should get a clunk when it unlocks, and that is it.
  3. Jun 16, 2012 at 7:45 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    It also states to drive the truck a minimum of 16 miles per month in 4WD.
    In my experience, there are 3 things that if a person doesn't use them frequently (as in all the time) they will eventually have failures because of a lack of use rather than over-use:
    1) Air conditioning systems
    2) Emergency brakes
    3) 4WD components
  4. Jun 16, 2012 at 11:07 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    This may not even be close but sometimes (especially with older trucks)
    if the solenoid/acuator goes out they'll fail in a "closed" position or part way in a neither here nor there position & if disengaging is the issue, this may apply. Also I've found that you may or may not have power to the switch as a result of bad solenoid.. weird shit...
  5. Jun 16, 2012 at 11:30 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    HA! .. Dodge too, happened twice on my '72 Power Wagon, eletric solenoid for switching valve for gas tanks. fuckers would fail in closed (half way ) position every time
  6. Jun 17, 2012 at 8:41 AM
    rusty c
    rusty c [OP] Member
    Rusty
    Galliano,la
    99' SR5 Prerunner
    Thanks guys...I found the problem.I pull the cap off of the rear end to expose the locker pin. And found that the channel was clogged with a little trash.so it was creating a suction on the cap witch wasn't letting the pin shift...problem solved
  7. Jun 17, 2012 at 10:08 PM
    scocar
    Cool. Gotta love the simple fix.
  8. Jun 17, 2012 at 10:12 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    HA! No shit, ya dodged a bullet for sure....;)
