Rear diff locker will not engage (bad actuator?) - Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by pt law, Jan 22, 2012.
  1. Oct 21, 2013 at 9:57 AM
    #41
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    So not trying to revive a dead thread, but my locker stopped working about 6 months ago. I ended up taking it off the truck and rebuilding it. followed a link on page one for disassembly/reassembly. It was frozen up solid with corrosion. Works great now. saved some coin thanks to you guys. Plus one to you all and thanks.
  2. Oct 21, 2013 at 3:38 PM
    #42
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    That's why this :)yay:TW) is here. I have done two now, one on my '99 and just recently my '05.
  3. Oct 28, 2013 at 5:06 PM
    #43
    07terry
    07terry Active Member
    north carolina
    07 4x4 trd
    can anyone help a wounded warrior with a problem with my last post[​IMG]
  4. Oct 28, 2013 at 5:11 PM
    #44
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Say what?
  5. Oct 28, 2013 at 5:32 PM
    #45
    07terry
    north carolina
    07 4x4 trd
    I had my actuator assembly out put locker fork in lock position aligned all the gears put in motor got in trk locker light was on and abs switched to off and it stayed in lock also in 2wd any answers or questions to help as I said im a wounded warrior and it takes me a while to get back to anyone who responds as it takes me awhile to perform work
  6. Oct 29, 2013 at 10:50 AM
    #46
    mightytacoman
    Kel
    4.5L 1grfe
    my rear locker sometimes doesnt want to turn off sometimes too. i kept driving in figure 8's with it on and couldn't get it to turn off all the while turning the diff locker on and off. finally when i was driving straight and hit the button on/off it kicked off. this all happened while in 4 Lo.. worth a shot. good luck wounded warrior
  7. Oct 30, 2013 at 5:17 AM
    #47
    07terry
    north carolina
    07 4x4 trd
    thx so much will try
  8. Oct 30, 2013 at 5:56 AM
    #48
    07terry
    north carolina
    07 4x4 trd
    hey I was told to replace it I would have to match up the gear ratio how does that matter im pretty mechanical savy but im not all knowing ???
  9. Oct 30, 2013 at 6:14 AM
    #49
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    match gear ratio? What? Never heard that one before.
  10. Oct 31, 2013 at 4:00 AM
    #50
    mightytacoman
    Kel
    4.5L 1grfe
    Don't know anything about gear ratio. I know toyota claims the part is non serviceable so if it doesn't work - there going to say replace it. I serviced mine and it works now. The part goes for around 500- 700$$. To me it was worth tearing off and tinkering with before I played that kinda cash (a how to link is on page 1 I think). Sorry i can't help more
  11. May 18, 2014 at 10:58 AM
    #51
    jitenshakun
    jitenshakun New Member
    Taco
    I have a '07 6spd Tacoma and I tried engaging my locker for the first time yesterday. I can get 4H and 4L without any problem but the locker light just flashes. I've tried backing up with it, turing the wheels and both at the same time.
    With the windows down I'm not hearing any sounds.
    Electrical? Mechanical? Both?
    tia.
  12. May 20, 2014 at 9:15 AM
    #52
    mightytacoman
    Kel
    4.5L 1grfe
    In 4 lo. Have a friend hit the locker button while you get right down near it and listen. I couldn't hear it click from inside the cab either. If it clicks then its not electrical. You said its the first time you turned it on so I'm betting it's mechanically froze up. You should hittheswitch monthly to keep it free. A use it or loose it thing for sure
  13. May 20, 2014 at 10:05 AM
    #53
    jitenshakun
    Taco
    Thanks. I didn't know what I was listening for so this is helpful.
    I had no idea it was a "use it or lose it" feature on the Tacoma.
  14. May 20, 2014 at 10:15 AM
    #54
    scocar
    scocar Patron of the Farts
    Anything electrical is especially.
  15. May 24, 2014 at 12:50 PM
    #55
    jitenshakun
    Taco
    Got under and had a look and I think I have it figured out. The e-locker looks good, but the female side of the electrical plug is cracked and at the crack the pin broke off in the female side. The means the male side (e-locker side) plug is also broken.
    I'll sort out the plugs hopefully it'll solve the problem. The e-locker shaft itself has a bit of wiggle to it so I don't think it is stuck.
  16. Jul 20, 2015 at 8:53 PM
    #56
    r45d
    r45d Well-Known Member
    Georgia
    01 DC 4WD
    Edit: Damn google... after much searching found this on pirate4x4, front locker but looks the same. http://www.pirate4x4.com/forum/toyota-truck-4runner/698966-e-locker-actuator-rebuild.html
    Well my locker froze and I need help; I have had the truck since october of 2013. Since that time at least once a month I would cycle the locker. Well I went to Kansas to help some family move and during some dirt road/creek crossing/ muddy road riding the locker froze in place. Found the link posted here for service and dropped the locker, cleaned it up. I think the motor that turns the gear to lock the diff is frozen. When we were working on locker it spun once or twice but would not spin the outside gear every time. I unlocked the diff reinstalled and drove home to GA ( i hope this didnt fry anything). Anywho long story short I need a thread about actuator motor rebuild... the ttora wiki thread is toast... anyone got a tip or thread saved in the archives?
    pics cause it happened
    929d3e76-559f-4bab-819d-276463713477_2ee7119282ad5665b1e67cc14827deeaa9b6b237.jpg 81eaa0ac-b5c7-4444-acfa-1f3a97c4be79_a2537ea7a9468994aaa83a116a1aadf6712ec80d.jpg e7307ce6-5bae-4497-86fe-52d92a625eeb_e5e05e6b7e421166c4edfd8add3d4748461d1986.jpg locker201_508b857bf4c088cfccadb212f14375b74ff848be.jpg
    TL: DR... froze my locker, motor in actuator is frozen(i think), need guidance rebuilding the motor under the black cap.
  17. Jul 20, 2015 at 10:32 PM
    #57
    mightytacoman
    Kel
    4.5L 1grfe
    I could probably walk you through it. I recommend getting some permatex dieclectic grease and getting rid of that cramp yellow grease that dries out. Also get some gasket maker and reseal everything upon reassembly. It should loosen up after liberal use of pb blaster and working it back and forth with pliers or whatever. Also you can bend your 3 brass contacts downward for a better connection. Pm me if you have any other questions. It's really a stupid simple design after you study it some. I have some pics kicking around to if needed
  18. Jul 30, 2015 at 12:09 PM
    #58
    r45d
    Georgia
    01 DC 4WD
    Got the locker running again. Had to glue all 4 magnets back in place, polarity during reassembly does matter if anyone else see this and is trying to rebuild locker. North poles across from each other and south poles across from each other. I used a compass to figure out which was which. Thanks for all the help tacomaworld.
    n
    s s <--- magnet arrangement
    n
    I found this link helpful even though it is for an 80 series, pretty good detail in the pdf. http://forum.ih8mud.com/threads/repairing-differential-e-lockers.570087/
  19. Mar 15, 2018 at 11:27 AM
    #59
    tony2018
    tony2018 Well-Known Member
    Bump on old thread, what grease is recommended here?
  20. Mar 15, 2018 at 11:28 AM
    #60
    mightytacoman
    Kel
    4.5L 1grfe
    permatex di-electric
