Rear diff locker will not engage (bad actuator?) - Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by pt law, Jan 22, 2012.
  1. Mar 15, 2018 at 11:31 AM
    #61
    tony2018
    tony2018 Well-Known Member
    What about the grease that goes on the gears of the motor?
  2. Mar 15, 2018 at 6:58 PM
    #62
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Same thing. Toyota uses their crap dielectric grease on the gears. Using permatex on them would simply be an upgrade as the Toyota grease dries out.
    Area51Runner likes this.
  3. Mar 15, 2018 at 9:41 PM
    #63
    tony2018
    thanks
  4. Jun 21, 2018 at 8:48 PM
    #64
    gfhynes
    gfhynes Member
    Calgary, AB
    09 Access Cab TRD
    Hey guys, I have a similar problem with my locker but a little different. My locker engaged but now won’t disengage even though I come out of 4 low and 4 high. Anyone experience this? The weird thing is that when I engaged the diff lock the red light kept flashing so I though it didn’t lock. Unfortunate part is that it did but won’t come out. Tried lots of figure 8’s in 4wd and 2wd but won’t release. Would it be a similar situation to many described here - the actuator needs a clean? Thanks
  5. Jun 22, 2018 at 9:35 AM
    #65
    mightytacoman
    Kel
    4.5L 1grfe
    probably corrosion at a different part inside the locker motor if I had to guess... take the locker off the truck and clean up the internals. bench test. Then try again.
  6. Apr 28, 2019 at 5:29 PM
    #66
    Icepuck72
    Icepuck72 Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
  7. Apr 28, 2019 at 5:48 PM
    #67
    jeg0005
    jeg0005 Well-Known Member
    Jon
    BHM, AL
    2001 Tacoma SR5 double cab
    Full OME 883s, SPC UCAs, 33" STT Pros
    I'm about to put a locker actuator back on a 3rd member, should I use gasket maker to seal it to the body of the 3rd or were you talking about just using it for putting the actuator body back together?
  8. Apr 28, 2019 at 5:51 PM
    #68
    mightytacoman
    Kel
    4.5L 1grfe
    Both.
  9. Apr 28, 2019 at 6:05 PM
    #69
    jeg0005
    Jon
    BHM, AL
    any recs on a particular type?
  10. Apr 28, 2019 at 6:08 PM
    #70
    Icepuck72
    Mark
    Richmond, VA
    2006 DC TRD
  11. May 21, 2019 at 11:06 AM
    #71
    mightytacoman
    Kel
    4.5L 1grfe
    permatex makes quality stuff
