Rear diff mod: my truck is stuck?!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by madmanxing, Feb 25, 2017.
  1. Feb 25, 2017 at 10:12 PM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    I'm about 99% sure this isn't diff breather related if you indeed did the mod correctly. It sounds like you either goofed something running the hose or just something else that coincidently occurred after you did the mod (bad timing). Keep us posted. Best thing is to undo the mod, take it to the dealer, explain what its doing and play dumb.
    InfernoTonka and shakerhood like this.
  2. Feb 25, 2017 at 10:15 PM
    InfernoTonka
    InfernoTonka Infernal Order of Knights Templar of Inferno-ness
    TOD aka Toyota Onroad Development
    2016 Inferno SAF base model SR5 4x4
    The only time I had a tranny go out in any car it did not go in reverse at all.
  3. Feb 25, 2017 at 10:19 PM
    madmanxing
    madmanxing [OP] Well-Known Member
    2017 Cement Tacoma Trd Pro
    I will try this in the morning before i call a tow truck... Looks like my dealers service department isn't open sunday... God damnit.
  4. Feb 25, 2017 at 10:22 PM
    Wallbright
    Wallbright Well-Known Member
    2017 MGM DCSB SR5
    I was going to say that most dealerships if not all are closed Sundays. Sucks man.
    Spare Parts, tcjacado and shakerhood like this.
  5. Feb 25, 2017 at 10:24 PM
    madmanxing
    I was super delicate running the hose and putting my hands anywhere! My zip ties to the electrical harness heading to the back tail lights is so loose it still slides around... So that's why I'm unsure of what it was I could have done.
    And yes my only option is the dealer at this point.
    It's definitely diff/tranny related.
    At the dealer today for my 10k service I told them when I came to a stop quickly from 40mph slowed down to 10mph~0 quickly it felt like a clunk in the back sometimes. Like it was shifting down hard. So the dealer said they greased my drive shaft and my brakes were squeaking so they cleaned out the drums and lubricated them. Then today I washed the truck, took it up and down the street, dried it, then did the diff mod ( and no, no water dripped inside when I took off the stock breather, and I'm 100℅sure I didn't drop anything in there) I'm just trying to give the whole story in case it gives clues to anyone. Anyway it's off to the dealer tommorow until they can look at it Monday morning I guess... Going to be interesting how their going to manage to move it around :(
  6. Feb 25, 2017 at 10:49 PM
    Paterico
    Paterico Well-Known Member
    San Antonio, TX
    2017 DCSB TRD OR 4x4
    Jacking up the rear and trying to spin the wheels will tell a lot.
    I was thinking that maybe you jostled the locking diff actuator somehow and it engaged but unless you took a 90 degree turn and things bound up, I can't see how this would have caused the lockup.
    It sounds brake-related to me, especially since you just had had the rear brakes serviced.
    0210, bobrown14 and Spare Parts like this.
  7. Feb 25, 2017 at 11:06 PM
    avitaco
    avitaco Well-Known Member
    A
    2017 DCSB 4x4
    the brakes wouldnt stop him from shifting gears though and I think he said he cant get it into reverse...
  8. Feb 25, 2017 at 11:09 PM
    Paterico
    San Antonio, TX
    Didn't think he said that he couldn't shift into reverse. As far as I can tell, he just said that it varies on how much he can move while in reverse and drive
    Toyko Joe likes this.
  9. Feb 25, 2017 at 11:16 PM
    avitaco
    A
    2017 DCSB 4x4
    he says it here that he may or may not go into reverse.... Sounds like the tranny....
    Heres my thought... Try messing with your 4x4 and putting it into 4 low and playing with your locker... maybe you had it bound up. Cant hurt to try before you have to take it in for a new tranny anyways
  10. Feb 26, 2017 at 12:06 AM
    Paterico
    San Antonio, TX
    Yeah looks like I didn't read that one post closely enough. Definitely strange that it won't go into neutral anymore.
  11. Feb 26, 2017 at 6:37 AM
    madmanxing
    Bump
    Am gonna jack the rear up once the rain stops....
    :ballchain: <--- me in my truck. :confused::(:annoyed:
  12. Feb 26, 2017 at 6:51 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    :rofl::rofl:
    Sounds like something with the transmission.
  13. Feb 26, 2017 at 6:56 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm subbed for the outcome
    shakerhood likes this.
  14. Feb 26, 2017 at 6:56 AM
    Taco16LB
    Taco16LB Well-Known Member
    OP do you have a manual trans ?
  15. Feb 26, 2017 at 7:00 AM
    #35
    madmanxing
    No it's auto.
  16. Feb 26, 2017 at 7:07 AM
    #36
    nwroam
    nwroam New Member
    2009 PreRunner
    It does sound to me as if it could be the transmission, especially if you are unable to select gears. However, I have also seen drum shoes come apart internally and bind things up like this. You may try pulling the drum cover and making sure everything looks ok in there.
  17. Feb 26, 2017 at 7:09 AM
    #37
    PintSize
    PintSize Crossthreaded & torqued down
    Texas
    2011 2.7L 5 spd RC 4x4
    Strange. My drums had locked up on me once with after sitting a week unwashed mud. Put it in 1st gear and let up on clutch and almost stalled - rear drums were locked up with e brake off. Ended up having to press the brake petal a few times and that seemed to free it up. Might be something else. Subd for answer...
  18. Feb 26, 2017 at 7:11 AM
    #38
    Hondah
    Hondah Revelations 6:8
    Newnan, Ga
    '13 RC 4x4
    My vote is they jacked something up in your drum brakes.
    0210 and tinker_troy like this.
  19. Feb 26, 2017 at 7:13 AM
    #39
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    I wouldn't screw with anything at this point, get it to the dealership, play dumb, think it's must be the brakes as they serviced them the other day. Let them figure out if it's not the brakes and is the tranny.
  20. Feb 26, 2017 at 7:14 AM
    #40
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
