Rear diff mod: my truck is stuck?!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by madmanxing, Feb 25, 2017.
  1. Feb 26, 2017 at 7:17 AM
    #41
    InfernoTonka
    InfernoTonka Infernal Order of Knights Templar of Inferno-ness
    TOD aka Toyota Onroad Development
    2016 Inferno SAF base model SR5 4x4
    Rear drums stuck in my Ranger a couple of times. When I put it in reverse it just sat there so I gunned the accellerator a little bit while in reverse until it unstuck itself. Might be worth a try.
  2. Feb 26, 2017 at 7:23 AM
    #42
    madmanxing
    madmanxing [OP] Well-Known Member
    2017 Cement Tacoma Trd Pro
    I did try but only like 500 ish rpm and I'm too afraid to break shit.. it's :really: stuck when it hits the spot.
    Also I can select gears the selector moves normally it's just when I select reverse let's say it will roll a few feet back then lock as if my e brake is on. Then if I put it in drive same thing. Then even if I go into reverse and while it is still rolling freely, I stop myself and shift to neutral, it's still as if my e brake is on.
    The more reading I do the more I feel like it's the drums... It definitely happened when my truck was on a small incline reversing.
  3. Feb 26, 2017 at 7:26 AM
    #43
    InfernoTonka
    I wonder if brake fluid is low? Just throwing ideas out. Probably worth checking.
  4. Feb 26, 2017 at 7:26 AM
    #44
    TRDinOhio
    TRDinOhio Well-Known Member
    Andrew
    Lima
    16 Trd Pro 4Runner
    No more Turd-gen :)
    Inspect every inch of your breather mod work. If you don't find anything wrong get in the truck and mash the god damn gas. It will break free or break shit. Either way it's under warranty and if it's nothing you did its covered.
    Camel89 likes this.
  5. Feb 26, 2017 at 7:26 AM
    #45
    PintSize
    PintSize Crossthreaded & torqued down
    Texas
    2011 2.7L 5 spd RC 4x4
    o_O
  6. Feb 26, 2017 at 7:29 AM
    #46
    madmanxing
    I've checked everything over 6 times but that's the last thing I want to do lmao. Even if it means being late to work on Monday to have to sort this out getting it to the dealer.
    I payed too much for this thing to treat it like that. If I have to mash the gas over 1000 RPM to break it free... Something is wrong and is gonna break... Lol
    InfernoTonka likes this.
  7. Feb 26, 2017 at 7:29 AM
    #47
    InfernoTonka
    I know...another Ranger story :annoyed:
  8. Feb 26, 2017 at 7:30 AM
    #48
    madmanxing
    Th
    The just did the 10k service so it should have been checked, and besides that brakes work fine when I apply them and release they release although feel off...
    InfernoTonka[QUOTED] likes this.
  9. Feb 26, 2017 at 7:32 AM
    #49
    PintSize
    Texas
    Oh I have a few too!!! My old man had a 84' Ranger. E brake locked up all the time. I recall there was a trick to it freeing it up, but I've slept since then.
  10. Feb 26, 2017 at 7:33 AM
    #50
    Taco16LB
    Taco16LB Well-Known Member
    When the truck is in the mid point (not locked up when reversing or locked when going forward) at that free point try the emergency brake . Notice how far the lever comes up then release it.
    Now do the backing up until it locks up , Now at that point try the emergency brake lever again . If it was the brakes , I would think the emergency brake lever would not come up as far if the rear brakes had pressure on them from being locked up.
    shakerhood and InfernoTonka like this.
  11. Feb 26, 2017 at 7:37 AM
    #51
    madmanxing
    I feel like I tried this last night but will be sure to try again this morning.
    I feel like the emergency brake felt weird yesterday but I was an hour and a half into losing my mind so not sure :confused::annoyed::rolleyes:
    Thanks.
  12. Feb 26, 2017 at 7:39 AM
    #52
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Crappy luck man. Subd for the diagnosis...
  13. Feb 26, 2017 at 7:40 AM
    #53
    InfernoTonka
    It would be great to get it to the point that you could drive it in to the dealership instead of getting it towed.
    tomwil likes this.
  14. Feb 26, 2017 at 7:43 AM
    #54
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Wrong.
    Don't post stupid shit.
    Nfarrall, 0210, Rashnu and 6 others like this.
  15. Feb 26, 2017 at 7:45 AM
    #55
    PintSize
    Texas
    :rofl:
    bobrown14 likes this.
  16. Feb 26, 2017 at 7:53 AM
    #56
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    I've never heard of anything like this.
  17. Feb 26, 2017 at 7:55 AM
    #57
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Some of these suggestions are downright stupid.
    For the OP:
    The breather mod ain't going to cause this.
    Low brake fluid won't cause this.
    If you want to know lift the rear of the truck, chock the front wheels, support on Jack stands, place in neutral and see if the wheels spin.
    If it won't go in neutral, disconnect the drive shaft at the rear. No need to pull it out, just set the loose end aside. Wheels should spin. If not, it's brakes or rear. If so, it's the transmission.
    When you reinstall the driveshaft, make sure you torque the bolts properly.
  18. Feb 26, 2017 at 8:01 AM
    #58
    Mountain Minstrel
    Mountain Minstrel Well-Known Member
    Prather, CA
    '17 DCSB MT INFERNO
    I'm not sure why everyone is suggesting that you do all the diagnosis on the truck. The great benefit of buying new is the warranty so arrange to have it towed to the dealer and find another way to work. problem solved.
    outlawtacoma, Toyko Joe, ajm and 5 others like this.
  19. Feb 26, 2017 at 8:02 AM
    #59
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
  20. Feb 26, 2017 at 8:02 AM
    #60
    i_cappi
    i_cappi Well Known Membhair
    Canton, Oh
    2011 TX TuRD Pyrite DCSB
    Ya I dunno F all that diagnosis. Use your warranty. Play the game.
    TRDinOhio and Spare Parts like this.
