Rear diff mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Btp001, Mar 12, 2015.
  1. Mar 12, 2015 at 9:14 PM
    Btp001
    Btp001 [OP] New Member
    Ben
    Georgia
    13 tacoma trd off-road 4x4
    Toytec suspension lift, 285 toyo a/t much more to come
    Alright so I'm new here and this is my first tacoma, coming from a Chevy.. So I'm trying to do this rear diff mod because I was in wet grass the other day and had to put it in 4wd just to get out when it would've pulled right out if the rear locked.. At the time I wasn't aware the locker only worked in 4lo.. But anyways I was going to do the relay mod but all the radioshacks around here are goin outta business and have literally nothing in them.. So no relays unless I order it online, but I found an "alternative" as they call it where you put a switch in and fool the 4wd ecu into thinking its in 4lo.. Well I tried the switch mod because I like it better than having to cut so many wires but I couldnt get it to work..I'm sure im doing it right, I just don't know if something changed for the 2013 models.. So if anyone with a 2013 has done this mod or the relay mod and it works please let me know.. And how you done it..I know there are threads on here showing how to do them but I haven't seen anyone with a 2013 post and say it works..so basically if you have a 2013 and have done the rear diff lock mod please let me know how you did it..
  2. Mar 13, 2015 at 12:45 PM
    Jerryjc
    Jerryjc Well-Known Member
    New Jersey
    2012 TRD Off Road Barcelona Red 4x4 DCSB
    Tonno Pro soft Tri Fold bed cover
  3. Mar 13, 2015 at 4:45 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    the one wire mod for diff lock works. It will throw a code after like a quater mile of use though.
    works fine on my 2013.
  4. Mar 13, 2015 at 8:44 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
  5. Mar 14, 2015 at 5:39 AM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    link to one wire diff mod please
  6. Mar 14, 2015 at 1:12 PM
    ChiefManyWrenches
    ChiefManyWrenches Well-Known Member
    Florida
    '11 Silver DCSB TRD Off Road 4WD
    It won't throw a code from distance, only if you go over a certain MPH. I just use my ultragauge to clear the code.
  7. Mar 14, 2015 at 1:17 PM
    ChiefManyWrenches
    Florida
  8. Mar 16, 2015 at 7:39 AM
    boomer6
    TN
    Tacoma TRD Offroad
    Thanks nd4spdbh and ChiefManyWrenchs . Approx . how many mph when it throws a code ?
  9. Mar 16, 2015 at 1:56 PM
    ChiefManyWrenches
    Florida
    Like 25 or so I think, I can find out for sure later if you want.
  10. Mar 16, 2015 at 3:07 PM
    ChiefManyWrenches
    Florida
    So yes, it is at 25 mph but not just with the locker on. When I flick my switch even if I don't engage the locker the truck thinks it is in 4-lo and it will throw the code.
  11. Mar 16, 2015 at 5:02 PM
    nd4spdbh
    SoCal
    but allows you to activate the locker at any speed.... which can be bad.
  12. Mar 16, 2015 at 5:53 PM
    nd4spdbh
    SoCal
    true.... but there have been a time or two when i went to tap one of the buttons by feel and accidentally hit the locker button.
  13. Mar 16, 2015 at 6:54 PM
    nd4spdbh
    SoCal
    i love fondling my dash... pushing the right buttons and turning the right knobs.... :D
  14. Mar 17, 2015 at 10:17 AM
    boomer6
    TN
    Tacoma TRD Offroad
