Rear Diff Oil Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by QChawks, Aug 26, 2017.
  1. Aug 26, 2017 at 1:18 PM
    QChawks
    QChawks [OP] Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    I've searched the site up and down but cannot find answers to these questions.
    I have a 09 4WD Sport and the manual states to use 75w-85 for the rear diff, can I...
    1. Sub Mobil 1 75w-90 instead?
    2. Do I need to add a LS additive? (manual says nothing about that)
    3. Will 3 quarts fill it up or do I need to purchase 4? (Manual say 3.12 capacity)
    I was about to pull the trigger of Purchasing Redline 75w-85 but thought I would double check.
    Thanks!
  2. Aug 26, 2017 at 6:25 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    yes
    no
    yes
    TRDSport10 likes this.
  3. Aug 26, 2017 at 8:34 PM
    QChawks
    Davenport, IA
    2009 TRD Sport DCLB
    Great, thank you
  4. Aug 27, 2017 at 5:23 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    24mm socket...make sure you crack open the upper bolt (fill) before you drain from the lower bolt.
  5. Aug 27, 2017 at 7:18 AM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    When I went to my local dealer, he said it takes 3.2qts, but that's new and dry. Said they just use 3qts and it's fine.
