Rear diff oil level issue!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by joncure, Oct 18, 2022.
  1. Oct 18, 2022 at 8:47 PM
    lbhsbz
    lbhsbz Well-Known Member
    I wouldn't worry too much about it...the rear diff holds about 4 quarts.
  2. Oct 19, 2022 at 7:08 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    let us know if the front diff is low. haven't checked mine yet.
    Carrot Top likes this.
  3. Oct 19, 2022 at 7:08 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    those multi-point inspections are BS. they absolutely don't check everything in order to save time.
  4. Oct 19, 2022 at 8:19 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    The point is moot as you filled the axle so it is now your word against theirs.
    Kind of disappointing however as "quality workmanship" and "trust" are in bold in the first section of the brochure. :(
    Right from the official website, they state fluids 2x. I suppose there is implied plausible deniability as they specifically didn't state axles (or transfer case).
    Multi-Point Inspection
    Proper maintenance helps your Toyota last longer and deliver more dependable, economical performance. With our multi-point inspection, we check your Toyota's fluids and perform a visual check of all major systems.
    Fluid Inspection
    During your multi-point inspection, all your vehicle's fluids (coolant, brake, power steering, windshield washer and transmission) will be checked and replenished at no additional charge.
    https://www.toyota.com/owners/parts-service/express-maintenance
  5. Oct 19, 2022 at 8:22 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    SR-71A likes this.
  6. Oct 19, 2022 at 9:19 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    most 3rd gens are a little low on atf from the factory. i added a quart.
  7. Oct 19, 2022 at 9:31 AM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    It about $100 to do both differentials and transfer case for the DIY’r. For me, I’d rather spend the $100 and do it myself. Free is sometimes much more expensive.
  8. Oct 19, 2022 at 1:21 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Im going to bet, that somewhere along the line, for whatever reason the assembly line was never changed to fill the rear axles with the proper amount of fluid from the 2nd gen spec of ~ 3.1ish quarts. Hence the quart + low from the factory on the rear axles.
    That stated, you should really always change main drive axle gear oil on any car at somewhere between 2.5-5k miles from new, lots of break in junk will be in that fluid that you dont want circulating around in everything for the next 30-60k miles (especially if its low to begin with).
    I dont blame you for going to the dealer to document stuff like this on a new vehicle, but ALWAYS inspect their work and tread lightly with easy to do stuff like oil changes which could be detrimental if an oil change monkey messes up.
    gForceDude and mquibble like this.
  9. Nov 15, 2022 at 8:06 PM
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    I bought my offroad new in March of 2016. After a few miles, the rear diff detonated because it didn't have any gear oil, so some come a little low from the factory :)
  10. Nov 16, 2022 at 4:55 AM
    joncure
    joncure [OP] Well-Known Member
    VA
    2021 TRD Sport Access Cab manual
    Yikes!!
    I took my truck to dealership for inspection and to have it all officially documented. I even got it in writing from the service advisor that they acknowledged the possibility of it coming low from the factory.
