Rear Diff oil, Synthetic or conventional?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by n2wind2000, May 28, 2024.
  1. May 28, 2024 at 4:53 PM
    n2wind2000
    n2wind2000 [OP] New Member
    Patrick
    2019 Magnetic Grey Metalflake Tacoma 4x2 DC
    Just light stuff
    Is there a consensus on using synthetic over conventional rear diff oil? Its nearly twice as much. Getting ready for 1st change in my 2019.
  2. May 28, 2024 at 5:04 PM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    I would use synthetic, why risk using a lesser quality oil? The price of a new differential is expensive
  3. May 28, 2024 at 5:05 PM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    Synthetic all day
    Anton338, Kolohe07 and Stevie17 like this.
  4. May 28, 2024 at 5:05 PM
    M85
    M85 Well-Known Member
    Colorado
    2019 SR ACLB
  5. May 28, 2024 at 5:07 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    When I see synthetic gear oil on sale I buy it to have on my shelf. I always change fluids sooner than later.
    Gfenza89 and Stevie17 like this.
  6. May 28, 2024 at 5:08 PM
    Clearwater Bill
    Billy
    Largo Florida
    Use syn if you work the diff hard or you're willing to double your OCI in normal use
    If you are a low stress driver, dino and recommended OCIs are just fine
  7. May 28, 2024 at 7:59 PM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    abou824 likes this.
  8. May 28, 2024 at 8:16 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I don’t ever use synthetic. My diffs have not blown. The gear companies tend to suggest thicker conventional oil so that is what I use.
    Not on the Tacoma, but on other vehicles (with Dana 44 rears especially), I have definitely had pesky pinion and axle seal leaks that would just not stop with synthetic (even with new seals), and as soon as I went back to conventional, they would stop. Maybe the conventional stuff conditioned the seals a bit better, I don’t know. Issues like that are mostly unheard of on Tacomas so it doesn’t matter that much, but I still run conventional just because.
    turbosnail and n2wind2000[OP] like this.
  9. May 28, 2024 at 11:58 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    I'm sure conventional would be fine but synthetic is a superior lube. Synthetic will cling to the metal along with kind of ball up under pressure acting like a little bearing on the surface whereas conventional will just squeeze out unless you go thick enough.
    Typically gear oil isn't changed often (if at all) so unless you water cross often and end up changing your gear oil like once a month, I would just take the hit in price and run synthetic.
    I don't believe in doing this but tbh many people run a gear lube from factory until the vehicle is in the scrapyard with no issues so in my opinion if you're gonna change it, may aswell use a quality synthetic
  10. May 29, 2024 at 12:13 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    Don't be a square, use synthetic. Set it & forget it :)
    herecomesace likes this.
  11. May 29, 2024 at 3:47 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
  12. May 29, 2024 at 4:19 AM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    BigCountry762x39 likes this.
  13. May 29, 2024 at 4:21 AM
    abou824
    abou824 Well-Known Member
    Aidan
    Central PA
    '21 TRDOR Army Green 6MT, '13 Lexus RX350
    TRD Lift (Toyota 5100's) LT265/75 AT4W Method MR305 16x8 Bronze ARB Diff Breather Subaru Tweeters Garmin Dash Cam Clutch accumulator delete plate Vibration dampers on MT driveshaft shield
    This is the way. Advanced only had 2 squeeze pouches and one larger bottle, holy shit are the squeeze pouches easier. Would have saved myself lots of swearing if I'd went someplace else and only gotten the pouches.
  14. May 29, 2024 at 4:58 AM
    999 Well-Known Member
    Texas
    Could have poured the bottle into one of the empty bag.
  15. May 29, 2024 at 5:00 AM
    abou824
    Aidan
    Central PA
    :annoyed:
  16. May 29, 2024 at 5:12 AM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    I put Super tech 75w90 synthetic in mine a few months ago
    n2wind2000[OP] likes this.
  17. May 29, 2024 at 6:41 AM
    2013logan
    2013logan Active Member
    New Mexico
    2019 Tacoma TRD pro
    icon add a leaf, KD max tune,RSG sliders, Falken 33inch MT, eibach spring, arb front locking diff,ARB air compressor.baja designs squadron fog lights non dot comliiant.
    East coast gear supply has written a extensive article and done a ton of research on the topic all they do is GEARS and diffs I 100 percent trust there advise. to sum it up if you use conventional they spec a lucas gear oil i forget the weight the article is specific and the ams oil is second not because of quality but they didnt see much benefit over lucas for the additional cost
  18. May 29, 2024 at 10:52 AM
    n2wind2000
    Patrick
    Just light stuff
    I was actually looking for that brand when I bought synthetic engine oil. They have it back in stock now, thanks for the reminder.
  19. May 29, 2024 at 10:57 AM
    Taco_mike73
    York, PA
    I could never find it or enough for the front and rear at my local Walmart. What I did was order 6 quarts for curbside pick up because online they said it was in stock. When they went to fill the order they then offered to ship it to me for free when they didn't have enough to fill the order. at about $10 a quart it was a deal.
  20. May 29, 2024 at 11:18 AM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    Redline 75w140 in anything I've owned over the years, I'm 41 now, and started using it when i was 18... though working in shops in my late teens early 20's access to stuff like that probably is why my hard use things have lasted and always seem to be a solid shape.
