Rear diff oil weight?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gfenza89, Mar 21, 2023.
  1. Mar 21, 2023 at 5:48 PM
    Gfenza89
    Gfenza89 [OP] Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    What rear diff oil weight are you guys running? Especially for rears that have the slight howling noise.
  2. Mar 21, 2023 at 5:51 PM
    hwntaco20
    hwntaco20 Well-Known Member
    2020 Tacoma TRD Offroad 2wd
    From the maintenance thread
    3-4qts LT 75W-85 GL-5
    DRAIN PLUG GASKET 12157-10010
    FILL PLUG GASKER 12157-10010
    Tacospike and Gfenza89[OP] like this.
  3. Mar 21, 2023 at 5:54 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    There are like 2 new diff oil threads every day!
  4. Mar 21, 2023 at 5:55 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    You ain't getting rid of that howl no matter what unicorn tears you put in there...
    jsinnard, Lt. Dangle, bbartol and 3 others like this.
  5. Mar 21, 2023 at 5:56 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    A howling noise in a 2023 truck?
    I’m not sure I’d worry about the fluid weight.
    I’d let the dealership worry about it?
    Rusty66 and Stevie17 like this.
  6. Mar 21, 2023 at 6:03 PM
    Gfenza89
    Already been deemed normal by engineers and dealerships
  7. Mar 21, 2023 at 6:04 PM
    Gfenza89
    Yup…. Already been deemed normal by engineers and corporate and 2 different shop foreman’s
    Delta09[QUOTED] likes this.
  8. Mar 21, 2023 at 6:06 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    My 2014 and current 2021 both howl. Just a thing. I just turn the radio up louder.
    My 2009 did not ironically.
    Gfenza89[QUOTED][OP] likes this.
  9. Mar 21, 2023 at 6:11 PM
    TnShooter
    Deogee
    STOCK
    I wouldn’t go anything more than 90 weight.
    Honestly, I’d leave it alone and do fluid changes every 30k if not towing, or 15k if towing.
  10. Mar 21, 2023 at 6:11 PM
    Gfenza89
    Guess it’s hit or miss in just trying to accept it as normal. I installed the old 16-18 dynamic frame dampners from that tsb years ago and it helped also installed sound deadner pads behind rear seat trim and that helped too. Seems as the weather warms up noise is also slightly going away I wonder if the diff just needs broken in
  11. Mar 21, 2023 at 6:13 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Nah, my truck is almost at 25K and the tone has not changed one bit. Fluid level is still good (checked by me, not just the dealer). Almost due for the differential changes, but I doubt anything will change.
    Keep on motoring and enjoy it for many years! :fistbump:
  12. Mar 21, 2023 at 6:15 PM
    Gfenza89
    What the hell is causing the noise? Just a diff that’s not setup properly? So weird
  13. Mar 21, 2023 at 6:23 PM
    FLAK-TAC
    FLAK-TAC Only banned twice…so far
    SW Florida
    2022 TRD OR LB
    Resonance…
  14. Mar 21, 2023 at 6:23 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I’ve ridden in my buddy’s 2022 4x4 DCLB. His is quiet compared to my 07. Probably due to my AT tires but I didn't perceive his to be loud.
    Gfenza89[OP] likes this.
  15. Mar 21, 2023 at 6:26 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Nothing you can put in to fix that because... It is a resonance that causes the noise, not the rear diff itself. Meaning, the rear diff works with the springs which works with the shocks which causes the noise. Best you can do is insulate.
    Run what the manual tells you to run.
  16. Mar 21, 2023 at 6:49 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    6MTPro, danny15l and Gfenza89[OP] like this.
  17. Mar 21, 2023 at 6:58 PM
    Tacospike
    Two Trucks
    This. I used redline brand
    Good price and seems to be working as well as OEM. I’m not repping the brand and or all mighty as the best. Just my personal experience with a fair priced product I decided to use.
  18. Mar 21, 2023 at 6:58 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    It has nothing to do with it. There is a thread with 300 pages that proves it does not matter. It has non, it has a little or it has a lot. No rhyme or reason. Toyota fix was to insulate and isolate. Resonance is tough to fix.
  19. Mar 21, 2023 at 7:20 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Curious if there are any statistics on the noise complaints between the access and double cabs, or the 3.91 (auto) vs 4.30 (manual) ratios?
  20. Mar 21, 2023 at 7:34 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    If I remember, the double cab was much more suspectable to the noise.
