Rear diff oil?
Discussion in '1st Gen. Tacomas (1995-2004)' started by G59, Feb 2, 2017.
  1. Feb 2, 2017 at 9:48 AM
    G59
    G59 [OP] Stock af
    Torres
    SoCal
    03’ Long Travel DC
    Does anyone know what weight of gear oil to put in the rear diff (w/o locker) of an 03 tacoma?
    Thanks in advance!
  2. Feb 2, 2017 at 9:49 AM
    JonathanH
    JonathanH Well-Known Member
    Jonathan
    Southern Maryland
    11' DCLB
  3. Feb 2, 2017 at 9:56 AM
    G59
    G59 [OP] Stock af
    Torres
    SoCal
    03’ Long Travel DC
    thanks bro :thumbsup:
  4. Feb 2, 2017 at 9:56 AM
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
  5. Feb 2, 2017 at 9:59 AM
    JonathanH
    Jonathan
    Southern Maryland
    11' DCLB
    TACOMA Truck
    ASM/PARTS COUNTER REFERENCE GUIDE
    2001 TRUCK
    Auto
    Engine Trans Differential
    Trans Oil w / — 4WD
    Gears Filter Drain Transfer Manual Coolant Fuel
    USA Engine & Change & Fill Case Trans Capacity Front Rear Tank
    Model Body Style Cyl Type (qts.) (qts.) (qts.) (qts.) (qts.) (qts.) (qts.) (gal.)
    4x2
    7103 Reg Cab 4 5M 5.8 ---- ---- 2.7 8.5 1.4 ---- 16.0
    7104 Reg Cab 4 4A 5.8 2.5 ---- ---- 8.2 1.4 ---- 16.0
    7113 Xtracab 4 5M 5.8 ---- ---- 2.7 8.5 1.4 ---- 16.0
    7114 Xtracab 4 4A 5.8 2.5 ---- ---- 8.2 1.4 ---- 16.0
    Xtracab
    7153 S-Runner 6 5M 5.7 ---- ---- 2.7 10.3 2.7 ---- 16.0
    4x2 PreRunner
    PreRunner
    7132 Reg Cab 4 4A 5.8 1.7 ---- ---- 8.7 1.2 ---- 18.5
    PreRunner
    7162 Xtracab 4 4A 5.8 1.7 ---- ---- 8.7 1.2 ---- 18.5
    PreRunner
    7164 Xtracab 6 4A 5.7 1.7 ---- ---- 10.5 1.2 ---- 18.5
    PreRunner
    7186 Double Cab 4 4A 5.8 1.7 ---- ---- 8.7 1.2 ---- 18.5
    PreRunner
    7188 Double Cab 6 4A 5.7 1.7 ---- ---- 10.5 1.2 ---- 18.5
    4x4
    7503 Reg Cab 4x4 4 5M 5.7 ---- 1.1 2.6 8.8 1.2 2.8 18.5
    7504 Reg Cab 4x4 4 4A 5.7 2.1 1.1 ---- 8.7 1.2 2.8 18.5
    7513 Xtracab 4x4 4 5M 5.7 ---- 1.1 2.6 8.8 1.2 2.8 18.5
    7514 Xtracab 4x4 4 4A 5.7 2.1 1.1 ---- 8.7 1.2 2.8 18.5
    7553 Xtracab 4x4 6 5M 5.5 ---- 1.1 2.3 10.7 1.2 2.8 18.5
    7554 Xtracab 4x4 6 4A 5.5 2.1 1.1 ---- 10.5 1.2 2.8 18.5
    7594 Double Cab 4x4 6 4A 5.5 2.1 1.1 ---- 10.5 1.2 2.8 18.5
    Recommended Fluids:
    Engine Oil SAE 5W-30
    Automatic Transmission Toyota Genuine ATF DEXRON II/ III
    Transfer Case SAE 75W-90
    Manual Transmission SAE 75W-90
    Coolant Toyota Super Long Life Coolant with Ethylene-Glycol Type
    Differential (REAR) SAE 80W-90 Below 0F, SAE 90 Above 0F (FRONT) SAE 75W-90
    Fuel Unleaded Gasoline, Octane Rating 87 or Higher
    Power Steering DEXRON II or III
    Brakes DOT 3
    G59[OP] likes this.
  6. Feb 2, 2017 at 10:20 AM
    elnip
    LC,NM
    I don't think it gets below 0F in Ontario CA to say 80W-90 according to what you posted.
    "Differential (REAR) SAE 80W-90 Below 0F, SAE 90 Above 0F"
    I stand corrected for the 03 per Toyota to use straight 90, I wonder why that spec changed.
    G59[OP] likes this.
  7. Feb 2, 2017 at 10:23 AM
    JonathanH
    Jonathan
    Southern Maryland
    11' DCLB
    Thank you for pointing that out, I should have read the whole thing first.
  8. Feb 2, 2017 at 10:24 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I dunno, that is odd. I'd have a hard time, myself, running straight 90w in the diffs. 75w-90 synthetic for me, because I don't wanna have to change it every 30k or whatever the fsm maintenance plan says.
  9. Feb 2, 2017 at 10:25 AM
    elnip
    LC,NM
  10. Feb 2, 2017 at 10:27 AM
    elnip
    LC,NM
  11. Feb 2, 2017 at 10:28 AM
    cruiserguy
    Elijah
    SEKS
    Dammit, but it's really bugging my brain. What did they find to cause them to change that spec?
    Maybe just a typo? Not likely. Huh.
  12. Feb 2, 2017 at 9:19 PM
    G59
    G59 [OP] Stock af
    Torres
    SoCal
    03’ Long Travel DC
    Yeah I ended up throwing in 75w90.. but genuine buffoonery has struck again. Of course my ass forgot to put the washer on the drain bolt. :frusty: How important is that washer??
  13. Feb 3, 2017 at 12:12 AM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    I'd play it safe. I'd rather pay for a bottle of 75W90 than a new rear diff.
    G59[QUOTED][OP] likes this.
  14. Feb 3, 2017 at 3:19 AM
    cruiserguy
    Elijah
    SEKS
    It's a gasket. Without it, it should weep diff oil. I guess if it doesn't leak, I don't know how it wouldn't, then run it until it does start weeping. And then put the plug gasket on. But of course, it really should be there.
  15. Feb 3, 2017 at 7:50 AM
    G59
    G59 [OP] Stock af
    Torres
    SoCal
    03’ Long Travel DC
    SOB! Well I got a lot of time on my hands for the next few days. I'll probably drain it and throw it back on then
  16. Feb 3, 2017 at 7:57 AM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Run 80w-90 for 15000 miles no issue
  17. Feb 3, 2017 at 8:59 AM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    http://www.pylebros.com
    FYI,,, take it for what it cost you ,,, these guys here are professionals,, they say nothing but dino oil in the diffs'.
  18. Feb 3, 2017 at 11:50 AM
    cruiserguy
    Elijah
    SEKS
    Lol, and Mobil 1 isn't a professional company? I've been running it in Yota diffs for 15+ years. Never had a problem. I'm not buying that dino oil stuff man, old school minds need to get with the times. I'm not aware of a single application on these tacos where it would actually be better to run dino oil. Now you can argue well synthetic is bad, a waste, etc. But to actually say dino performs better than synthetic??? C'mon.
    drr likes this.
  19. Feb 3, 2017 at 12:00 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Agreed, no reason not to run synthetic. I use dino oil to break in new gears, which is what most diff shops recommend, mostly because it's cheaper.
    I have mobil1 75-90 in both diffs and the transfer case, works great.
    G59[OP], cruiserguy and QMEDJoe like this.
  20. Feb 3, 2017 at 12:05 PM
    QMEDJoe
    Joe
    Has anyone ever used the Redline MT-90 in their diffs? I'm about to change out all my oils again and going with the Redline MT-90 for my trans and wondering if I can just use it for my diffs and transfer case too. Wondering if Toyota suggests GL-4/GL-5 oils with the trans vs the diffs-transfer case?
