Rear Diff Oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GreyWolf66, Oct 5, 2024.
  1. Oct 5, 2024 at 5:44 PM
    GreyWolf66
    GreyWolf66 [OP] Member
    2013 Tacoma PreRunner
    Leer Camper Shell
    I changed my rear diff fluid today and it smelled really burnt! It was a strong burnt smell. My Tacoma is a 2013 2.7L 2x4. I last changed my diff fluid 38k miles ago and I used redline 75w-85. I will change my fluid around 20k miles next time. For now, should I use a different weight, additive, etc? I do have a constant load of around 4-500 lbs. I use my truck for pest control. Thanks!
  2. Oct 5, 2024 at 5:47 PM
    Bishop84
    Bishop84 Well-Known Member
    Gear oil stinks, as long as there wasnt large chunks of metal, dont sweat it.
    Stick to what you've been using, its top shelf, the fluid doesnt really matter but it may give you peace of mind.
  3. Oct 5, 2024 at 5:54 PM
    O'DubhGhaill
    O'DubhGhaill Well-Known Member
    2008 Tacoma TRD Sport Access Cab 4.0L V6 VVT-i6spd manual
    This. I use Redline 75w90 in front and rear diff, MT90 in manual tranny and transfer and life is good. Increase your change interval if pulling the loads you state.
    GreyWolf66[OP] likes this.
  4. Oct 5, 2024 at 8:43 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    If you are truly worried you can have the old oil sampled by a company like Blackstone and they'll tell you the true condition of the oil.
  5. Oct 6, 2024 at 8:00 AM
    GreyWolf66
    Leer Camper Shell
    Awesome! I had no idea.
  6. Oct 6, 2024 at 8:01 AM
    GreyWolf66
    Leer Camper Shell
    Another thing to add. I was about a quarter to maybe a half a qt short from filling up the diff. I didn't realize stores didn't stock 75w-85. I can either wait until tomorrow morning and see if Toyota has some, or top off with 75w-90. What's the better move?
  7. Oct 6, 2024 at 8:19 AM
    GreyWolf66
    Leer Camper Shell
    Scratch that. There is an O'Reilly that has a bottle in stock.
  8. Oct 6, 2024 at 11:56 AM
    TacoTuesday1
    FL
    I put whatever is recommended in my rear diff. Pretty straightforward.
  9. Oct 6, 2024 at 12:53 PM
    Taxx
    Taxx Well-Known Member
    Gear oil smells bad. You can put your fingers in the fluid and see if there’s any debris.
    Pretty hard to burn diff fluid unless you have a limited slip.
