Rear Diff Options
Discussion in '1st Gen. Tacomas (1995-2004)' started by DigB, Aug 3, 2010.
  1. Aug 3, 2010 at 10:17 PM
    DigB
    DigB [OP] Go Jets GO!!!!!!
    Winnipeg
    DCLB TRD Sport
    Air Freshener mod
    I am starting to look at some different options to replace my wonderfull open differential in my 03 Tacoma, I have found a few different types and I am looking for some opinions.
    1. Auburn ECTED - E locker
    2. Powertrax No Slip
    3. rear diff from TRD Taco
    4. ARB Air Locker
    5. other
    These are some of the different options I have found. I am not made of money unfortunately, if I was I would go for the ARB in the front and rear.
    So basically I am looking for something cheap, reliable and won't get me into trouble on icy snow packed roads as I have to deal with them for 5-6 months a year as I hear the Powertrax No Slip and others that are the same can be a little squirly on ice and snow covered roads.
    At first I was looking at the Powertrax but then I found the ECTED from Auburn and that has me interested as it's a LSD/E-Locker all in one. If you have and ideas or you would recommend one of the four, I appreciate the help and feedback!
  2. Aug 3, 2010 at 10:18 PM
    YeahYeah
    YeahYeah Well-Known Member
    Thomas
    (My Home - Murrieta, CA) Now, Alexandria, VA
    07 Tacoma Pre-Runner
    mud flaps gone, second air-filter gone, DTRL, fog light whenever and work with hi-beams, cut exhaust (was wicked flow), flat black stock rims, ABS switch, cup holder led's (with switch), turning signal mod #45, Bilstien 5100's, grill mesh
  3. Aug 3, 2010 at 10:34 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Just installed a powertrax no-slip this past weekend. AWSOME!! and CHEAP!! (price).
  4. Aug 3, 2010 at 10:35 PM
    YeahYeah
    Thomas
    how do you like it?
  5. Aug 3, 2010 at 10:40 PM
    Matic
    Tricky Dick
    Easley, SC
    Very nice ! Even with my 4 cyl I have to watch my "side slip" on rocks and mud.
    Full time locked under acceleration. No noise, cant even tell it's there. And was only about $400.
    However to the OP. I can see how it might become a problem for you on the ice and the snow. We dont get that much here in SC so thats why I chose a full time locker.
  6. Aug 3, 2010 at 10:41 PM
    YeahYeah
    Thomas
    does it work good on offroad trails and stuff like the elocker does?
  7. Aug 3, 2010 at 10:46 PM
    Matic
    Tricky Dick
    Easley, SC
    Here's a small write up. I will be taking back apart in 2 weeks to check everything and retorque.
    http://www.tacomaworld.com/forum/4-cylinder/106320-ring-gear-torgue-specs.html
  8. Aug 4, 2010 at 11:27 AM
    DigB
    Winnipeg
    DCLB TRD Sport
    Air Freshener mod
    Thanks for the help,
    Has anyone heard anything about the Auburn ECTED? I am starting to like that option as you can unlock it when you don't need it, IE when we have snow and ice and sub zero temps for 5-6 months of the year so I don't spin out on the highway when I come across black ice or snow cover!
  9. Aug 4, 2010 at 11:50 AM
    98tacoma27
    Ben
    Not Beech Creek
    Pretty sure the ECTED doesn't exist for Yota's yet.
  10. Aug 4, 2010 at 12:03 PM
    DigB
    Winnipeg
    DCLB TRD Sport
    Air Freshener mod
  11. Aug 4, 2010 at 12:12 PM
    98tacoma27
    Ben
    Not Beech Creek
  12. Aug 4, 2010 at 12:17 PM
    98tacoma27
    Ben
    Not Beech Creek
  13. Aug 4, 2010 at 2:49 PM
    98fourbangertaco
    98fourbangertaco Well-Known Member
    Taylorsville, NC
    98 toyota tacoma, 4wd, SR5, 2.7L, 5-speed
    daystar 2.5in suspension lift kit, detroit truetrac in rear, custom transfer case skidplate, deckplate mod, green high-performance drop in filter, Huskyliner floor mats, 31x10.50 wild country radial mtx tires, yakima roof rack, load warrior basket, stubbs welding rock sliders, arb front bumper with warn 9,000lb winch and procomp black series 100w offroad lights, trail-gear rear bumper, borla exhaust, blacked out factory wheels, shovel mounted on roof rack, de-mudflaped
    I would recomend the detroit truetrac, don't know how it would do in the front in the snow but I have it in the rear and I love it, its a worm gear type lsd (no clutch packs) so even though its a lsd there is no clutches to overpass each other so no matter what both wheels will alway pull but its sort of like a 60%-40% pull, I can't even tell mine is there when i am on the highway, its bout 500 bucks for rear
  14. Aug 4, 2010 at 2:52 PM
    DigB
    Winnipeg
    DCLB TRD Sport
    Air Freshener mod
    Ok well scratch that one from the list right now, not sure how the powertrax would preform on the ice and snow and thats what worries me the most, I really don't want to kill myself on the highway for extra off road ability but it seems I either have to find a Diff out of a wrecked TRD or install an ARB air locker both of which are too expensive right now, I don't know of any other options.
  15. Aug 4, 2010 at 3:02 PM
    DigB
    Winnipeg
    DCLB TRD Sport
    Air Freshener mod
    Have you had the Truetrac in the snow and Ice?
  16. Aug 4, 2010 at 3:46 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    You are right to be concerned about automatic lockers in snow and icy conditions. The real value of the selectable locker, like the TRD e-locker, is the ability to turn it off when you don't want it. my 2 cents.....
  17. Aug 4, 2010 at 3:51 PM
    DigB
    Winnipeg
    DCLB TRD Sport
    Air Freshener mod
    So the cheapest/safest route would be an LSD at this point due to budget? and when I go to trade up obviously make sure its TRD Off Road!!
  18. Aug 5, 2010 at 7:39 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    theres an article in 4wd toyota about yukon grizzly e lockers and they seem to get a great review they tackled some pretty ridiculous terrain with it i believe they go for around 485
