Rear Diff problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by michaman, Mar 1, 2020.
  1. Mar 1, 2020 at 1:19 PM
    michaman
    michaman [OP] Active Member
    Michael
    2005 Desert sand mica Tacoma 4x4
    So i decided i would change some fluids today, starting with the rear differential. I could not get the fill bolt out, even with impact wrench. I put wrench on drain bolt just to see if would break loose, and in seconds, all the differential fluid was on my garage floor. And I still can't get the fill bolt loose. wth do i do now?
  2. Mar 1, 2020 at 1:21 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Socket wrench with a pipe. Or breaker bar if you have one and use a pipe if you need more leverage still.
    I do not reccomend using an impact gun on your differentials/ transfer case.
    DG92071 and R0dzilla75 like this.
  3. Mar 1, 2020 at 1:22 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Soak it in pb blaster and let it sit. With any luck, it'll be free in a day or so.
    Muddycoinwash and ryfox0276 like this.
  4. Mar 1, 2020 at 1:26 PM
    michaman
    Michael
    will do
  5. Mar 1, 2020 at 1:30 PM
    michaman
    Michael
    oh man, i really f'd up. the bolt is now stripped. can't get my socket to bite
    Jason TRD OR likes this.
  6. Mar 1, 2020 at 1:32 PM
    SpanishTaco
    SpanishTaco Well-Known Member
    CT
    2015 Blue DCSB TRD Sport
    After you soak it, hit gentky with mallet to get it into threads, then again just before trying to wrench off. Repeat if necessary.
  7. Mar 1, 2020 at 1:34 PM
    RobinDv
    RobinDv New Member
    Robin
    2019 Black Tacoma SR5
    Headlights and Grill
    Get a bolt extractor set. Use the one that’s the same size as the socket. Hammer the extractor socket on there and try that. It’ll bite better. For more leverage use a breaker bar. Soaking it with rust penetrate is good too before all this. Good luck
    Chris(NJ) likes this.
  8. Mar 1, 2020 at 1:39 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Turn the truck upside down and just fill it through the drain plug.
    This is why we always say to make sure that fill plug loosens up first. Sorry to hear. Go w/ what's been suggested already. Worst case, you might need to weld a bolt on there to try and remove it.
  9. Mar 1, 2020 at 2:26 PM
    ryfox0276
    Montana
    2013 RC 4x4
    This is what I had to do when my front diff wasn't cooperating. Granted I did not drain the oil out so I could drive it over to a buddy with a welder... Best of luck OP
    Chris(NJ)[QUOTED] likes this.
  10. Mar 1, 2020 at 2:30 PM
    michaman
    Michael
    whew, was able to get a good bite with a pipe wrench and pvc pipe extension and broke it loose. thanks for help
    DG92071, tcjacado and ryfox0276 like this.
  11. Mar 1, 2020 at 2:31 PM
    ryfox0276
    Montana
    2013 RC 4x4
    Woo hoo! I'd now suggest getting a new bolt so you won't have to deal with it the next time!
    DG92071 and Muddycoinwash like this.
  12. Mar 1, 2020 at 2:35 PM
    tcjacado
    tcjacado Well-Known Member
    NYCTaco52 and DG92071 like this.
  13. Mar 1, 2020 at 5:22 PM
    Halligan
    Halligan Old School
    Cam
    BC Canada
    2015 DCSB Gearjammer
    OME 887s, OME Dakar Heavys, 265/70/17's, Truetrac, 6sp manual
    HEAT. Next time heat it up with a torch, even a propane plumbers torch will do. Its a great trick for stubborn things.
    Glad you got it out, now go order a new one.
    DG92071 likes this.
  14. Mar 1, 2020 at 5:26 PM
    j_sav115
    j_sav115 Well-Known Member
    SC
    07 Silver TURD SPRT
    Getting to start all over :)
    DG92071 likes this.
  15. Mar 1, 2020 at 5:27 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This always ^
    TreeFortRichard likes this.
  16. Mar 1, 2020 at 5:29 PM
    tcjacado
    Should be as good as any of the other suggestions. I have never had a issue with mine.
    DG92071 and j_sav115[QUOTED] like this.
  17. Mar 1, 2020 at 5:35 PM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    DG92071 and tcjacado[QUOTED] like this.
  18. Mar 1, 2020 at 5:38 PM
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    The breaker bar with a pipe is always a winner in my book. Just be extra careful as the bolts are quite shallow and can be easily rounded compounding the issue. Good luck!
    DG92071 likes this.
  19. Mar 1, 2020 at 5:46 PM
    Clearwater Bill
    Billy
    Largo Florida
    Glad you got it out. But a pvc pipe? Wow.
    Proper size 6 point socket, a long handled ratchet or 18" breaker bar, a 2 - 3' metal pipe that will fit over the handle.
    Still stubborn? Position the cup of your floor jack under the pipe and use the weight of the truck to break the bolt free.
    DG92071 likes this.
  20. Mar 1, 2020 at 7:00 PM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    Wondering if you've every removed these bolts before now.....how long has it been or how old is your truck?
