Rear diff Regear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ghost848, Nov 17, 2012.
  1. Sep 4, 2013 at 7:53 AM
    #101
    Ghost848
    Ghost848 [OP] Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    Proper torque anyways is my guess. I'm not mad cause lets face it humans are humans and we all make mistakes I'm just glad they are willing to help. All I know is it was torqued and the nut was punched into place so from that moment on something happened or wasn't right.
    By pin your bearing what you mean? That's a new one for me. When I was on the phone they were saying something along the lines of the bearing size use isn't enough bearing to handle the load/ torque of these trucks.... In the mean time I decided to take the time to fix everything rear end related. Removed those stupid balance beads out of my tires and shimed my leafs at two degrees to fix driveline angle. Much smoother ride! But now I have a noisy diff :( lol
  2. Sep 4, 2013 at 10:19 AM
    #102
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Oh I may have that backward
  3. Sep 4, 2013 at 1:09 PM
    #103
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    What I was told in regards to pining bearings is that the Toyota and suzuki bearings do not fit as tight as other truck diffs and are undersized as they said. This can lead to the bearing wearing down and spinning. To fix it they drill a small hole through the bearing and put a pin in to stop it. You could have a bad bearing that's not sitting tight, causing slop.
  4. Sep 4, 2013 at 5:34 PM
    #104
    Ghost848
    Tony
    Alberta,Canada
    Hmm that's a weird one, drilling through the bearing sounds like a horrible idea in my eyes but what do I know lol, thanks for explaining.
  5. Sep 4, 2013 at 7:20 PM
    #105
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    ehhh yeah, I'm going to say no.
  6. Sep 4, 2013 at 8:33 PM
    #106
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Agreed, and if you're really skating bearings well either your bearing or your shaft is fucked and you could always try using retaining compound (green loctite).
  7. Sep 4, 2013 at 9:28 PM
    #107
    VanCity4x
    AB
    05 Tacoma
    3link on tons
    I looked back at what they did, was under the impretion they did something else and didnt even explain it right so scratch what I said earlier but what they did is took a punch and made a small indentation/dimple around the race so that it wont spin in the carrier. Less chance of spinning as my origional was partialy spun and the bearing was in bad shape, not unheard of with toyota diffs and could be the problem with Ghost's, a bad pinion bearing. Loctite has a retainer that does the same thing, keeps the bearing from spinning.
  8. Sep 4, 2013 at 10:01 PM
    #108
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    After reading this thread one can get headache.
    If you use correct bearings you need the press to get races and bearings on. Spinning them is quite impossible unless somebody run them with out oil and they welded themselves together.
  9. Sep 4, 2013 at 10:05 PM
    #109
    Spoonman
    Jamie
    Alberta
    I've never ever heard of a pinion bearing spinning. They're pressed in hard. There's zero reason for it to spin.
