Rear Diff. - removing free play in pinion bearing
Discussion in '1st Gen. Tacomas (1995-2004)' started by Actionjackson, May 19, 2023.
  1. May 19, 2023 at 8:31 AM
    Actionjackson
    Actionjackson [OP] Well-Known Member
    Jack
    MA
    2004 Tacoma
    Howdy,
    Have a lot of slop in the pinion bearing - hard to measure but alot. If I continue to unstake the pinion nut, and continue to tighten the nut to remove the slop, will the bearing wear out? Current no rear end bearing noises or issues and it feels smooth, just wondering how long I can remove the slop before I need to change out the bearing. Thanks to all who reply
  2. May 19, 2023 at 8:36 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    You should definitely not loosen or tighten the pinion nut without pulling the third and and being prepared to treat is as a standard gear installation. Messing with that will require resetting pinion depth and backlash and if you don't do that your ring and pinion may not be long for this world.
  3. May 19, 2023 at 10:48 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    ^ This is the only reply you need.
    Wulf and Bivouac like this.
