Rear Diff Service
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SamSter0077, Aug 18, 2008.
  1. Aug 18, 2008 at 10:05 AM
    SamSter0077
    SamSter0077 [OP] Happy Camper
    Katy, TX
    09 Tacoma 4x4 TRD OR
    OME 886 Coils, and Struts, Rear Toytec TSB AAL/ OME shock absorbers, Fog Lamp anytime mod, Voyager Brake Controller.
    I am brand new to this site, and have been unable to read many threads on the rear diff. I Tow about every other week around 4000lbs. I do not have the tow package, and it tows well. My question is.. The scheduled maintenance calls for a Diff Fuild change at 15k... Am I reading it correctly, opinions please!
    -Sam
    07 Taco DC, 5spd auto, SR5, suspension TSB
  2. Aug 18, 2008 at 10:13 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i think the manual calls for diff service every 30k, sooner if you tow, and in your case, 15k is probably a good limit for you. do you have and open diff, or the lsd??
  3. Aug 18, 2008 at 10:18 AM
    SamSter0077
    Katy, TX
    Well, I didn't pay for LSD.. so I am guessing I do not. I have Very little slip, even when attempting to make one wheel spin.. is it possible that it is LSD, and they didn't tell me? Are there part numbers on the diff, that I can Identify it with?
    What oil should be used? Should I buy it from Toyota, or is there something better available?
    Thanks!
    Sam
  4. Aug 18, 2008 at 10:27 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    crawl under the truck and look on the rear diff........there should be an lsd sticker if in fact it is an lad diff. if it is, you can get the oil from the dealer, or you can use and 80w90 and a bottle of limited slip additive, if its an open diff.......you can use 75w90 or 80w90. if you want something good in there, if its an lsd......use some royal purple 75w90 synthetic and a little lsd additive. synthetic makes a good difference on these diffs.
  5. Aug 18, 2008 at 10:30 AM
    SamSter0077
    Katy, TX
    that easy huh.. just an LSD sticker? Ok, will look after work today. It's 3 quarts right?
    Thanks Again.
    -Sam
  6. Aug 18, 2008 at 10:46 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah, should be right about 3 quarts. if its the lsd......you WILL HAVE TO HAVE THE RIGHT OIL/ADDITIVE, or the rear end will grind and squeal. after you look under the truck.....let us know what the sticker says.
  7. Aug 18, 2008 at 10:50 AM
    rangejeep
    rangejeep Well-Known Member
    Charlotte, NC
    05 Tacoma 4x4 TRD Off Road
    What about a locker diff? Still use 3 quarts of Purple 70/90?
  8. Aug 18, 2008 at 10:51 AM
    SamSter0077
    Katy, TX
    Will do, thanks.
    -Sam
  9. Aug 18, 2008 at 10:53 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah......rp 75w90 works well in the rear locker, as does the mobil1 75w90.
  10. Aug 19, 2008 at 11:31 AM
    SamSter0077
    Katy, TX
    Sticker on Diff was C3 052 Sky and some other stuff.. on the door jam was A04A Looks, like it's 7.5", not sure on ratio (I thought all new Tacoma's were 4.10), and Open Diff.. no LSD. I read several post with different ideas on the rear Axle ratio, but I could swear I read somewhere it was a 4.10... ideas?
    -Sam
    PS- wonder if it's easy to upgrade to LSD, or Locking..??
  11. Aug 19, 2008 at 11:50 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hmmmmm.....sounds like its an open diff then. you can swap out the fluid with 75w90 mobil1 or royal purple then(or a non synthetic 80w90) if you want too. the synthetic is really good for the diff.
    not exactly sure what the ratio is.....but im pretty sure the rear end is either an 8 inch or and 8.4......pretty sure anyway.
    not sure how hard an lsd swap in would be.
  12. Aug 19, 2008 at 11:53 AM
    SamSter0077
    Katy, TX
    Cool Thanks, will get the Synthetic..
    -Sam
  13. Aug 19, 2008 at 4:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You have the 8.4" axel
    3.73 ratio and Limited slip diff.
  14. Aug 19, 2008 at 5:47 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if this is the case.....he will definitely need the lsd additive, since the mobil1 doesnt have enough in it. either that....or royal purple.
  15. Aug 19, 2008 at 6:30 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    OOPS! I guess I should change mine, 92,000 miles & I have never changed it. :eek:
    The dealer never has suggested it either, when trying to con/get me to do other services.
    I did do an oil change today with Mobil 1 Syn 0W30. Thanks Tacomaman for suggesting it. I bought it at Walmart like you suggested. Just FYI: I was in Advanced auto parts the other day getting irridium plugs. Mobil 1 syn was cheaper there than Wally world. I was shocked! I checked Costco today & 6 bottles was way too exspensive, about $6 more than Advanced.
  16. Aug 19, 2008 at 6:39 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    sweet!!!
  17. Aug 20, 2008 at 5:19 AM
    SamSter0077
    Katy, TX
    How in the world do you know that? I have looked everywhere online, and NOT been able find the same information.. It's an 07 model, sr5 DC, 2wd. According to the link below, it's open (look at chart on the bottom). I am coming to the conclusion, no one "really" knows.. I wish it was an 8.4", LSD. Can you let me in on your Source Chris4x4? And Thanks for your Input.
    http://www.off-road.com/trucks4x4/article/articleDetail.jsp?id=274535
    Thanks,
    Sam
  18. Aug 20, 2008 at 10:27 AM
    SamSter0077
    Katy, TX
    Located an 06 FSM here : looks like it's got 4 pinions for sure, and the First letter in the Tranny code denotes the LSD or non-LSD.. bottom of this link: http://www.geocities.com/jonnyr_1973/diffcodes.html
    A = non LSD
    B = LSD
    still not sure about the Ring Gear Size..
    -Sam
  19. Aug 20, 2008 at 10:33 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    There is some great info on those links!!! Sticky?
  20. Aug 20, 2008 at 10:36 AM
    SamSter0077
    Katy, TX
    Sticky? What's that?
    -Sam
