Rear diff shudders after changing fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoSeasoning500k, Sep 1, 2023.
  1. Sep 1, 2023 at 2:36 PM
    TacoSeasoning500k
    TacoSeasoning500k [OP] Member
    2008 Tacoma TRD Sport Prerunner V6 4x4
    I just changed my rear diff oil and now it shudders during slow sharp turns moving forward and in reverse. I used Valvoline FlexFill Full Synthetic SAE 75W-90 Gear Oil. I added 3 qts. Which brought it right up to the fill plug. Anyone know where I went wrong? What is causing this shudder?
  2. Sep 1, 2023 at 2:39 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    PreRunner?
  3. Sep 1, 2023 at 2:40 PM
    gilligoon
    gilligoon Well-Known Member
    Goon
    Watoosa Ridge, GA
    2017 Quicksand TRD OR DCSB
    Bilstein, ICON, Mobtown, Southern Style, Warn, SOS, Nitto, ARE, Northstar
    If you are sure it is only the rear diff, and you just changed fluid, and you ALSO added LS friction modifier... just drive it in circles in an empty parking lot. If you didn't add LS fluid... do that.
  4. Sep 1, 2023 at 3:39 PM
    TacoSeasoning500k
    I think it’sSR5
  5. Sep 1, 2023 at 3:41 PM
    TacoSeasoning500k
    I didn’t add LS fluid. The bottles of diff oil say it’s already in it. Does it need more?
  6. Sep 1, 2023 at 4:56 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    It should not need the additive but maybe your gears have tighter tolerance and needs it. I use the same gear oil in my 07 and it runs well without any additives.
  7. Sep 1, 2023 at 5:05 PM
    TacoSeasoning500k
    Ok. I might run it for another 20 miles or so and see if it loosens up. From what I’ve read on other threads some people with the LSD have good luck adding StaLube EquaTorque Friction Modifier. Might give that a try
  8. Sep 1, 2023 at 5:54 PM
    TacoSeasoning500k
    Final verdict: I ran it another 5 miles or so and now it’s smooth as butter. I let everything cool down to make sure it wasn’t just a result of warming up and it’s still good . I’m pretty sure it’s always used conventional so maybe it needed some time to work the synthetic into all the spaces.
  9. Sep 1, 2023 at 6:16 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Does the diff have a sticker on it that says “LSD oil”
