Rear diff stripped drain plug
Discussion in '1st Gen. Tacomas (1995-2004)' started by bellero, Dec 6, 2015.
  1. Dec 6, 2015 at 3:29 PM
    bellero
    bellero [OP] Well-Known Member
    Wainwright, Alberta
    Tacoma 2003
    I was doing maintenance on my Taco and when it came to changing the rear diff oïl, something weird happened. I removed the fill plug first, then tried to remove the drain plug but it won't come off.
    I have a good snug fit on the nut with my 24mm socket and it's not the nut who is stripped but rather what appears to be the treads either on the drain plug itself or the diff. All it does is turn without coming out!
    Anybody seen this before and know how to fix it.
  2. Dec 6, 2015 at 4:21 PM
    bellero
    Wainwright, Alberta
    Tacoma 2003
    Anybody?
  3. Dec 6, 2015 at 4:24 PM
    Clearwater Bill
    Billy
    Largo Florida
    Is it leaking? Can't quite imagine how this could be and it not be leaking.........
    Can you post a pic of the diff showing the plug area? Might help with some ideas.
  4. Dec 6, 2015 at 4:28 PM
    NM Lance
    NM Lance Well-Known Member
    Try wedging a small flat-blade screwdriver between the differential and the head of the drain plug as you turn it. A little outward force may be enough to get it moving. There is a lot of metal around the drain plug, I am sure you can tap it and put a larger diameter plug (or a cut-off bolt) in its place.
    Wulf likes this.
  5. Dec 7, 2015 at 12:46 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Rule of thumb always loosen the file plug first.
    I guess you never checked the fluid level either.
  6. Dec 7, 2015 at 3:17 AM
    Clearwater Bill
    Billy
    Largo Florida
    And you think he didn't because?
    RonJon31, Gunshot-6A and Wulf like this.
  7. Dec 7, 2015 at 8:06 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Another Rule of Thumb : completely read, and understand, entire original post :D
  8. Dec 8, 2015 at 12:38 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Sorry my 5th grade education shows at times!!
  9. Dec 8, 2015 at 9:20 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    If you can't get the socket to catch, you might need to use an angle grinder to carefully flatten the edges of the plug. If you can get another socket to fit, try that. If not, you can use an adjustable wrench on it. Make sure the wrench is a good quality one that doesn't have much slop in it. Once you get the plug out, buy a replacement. Don't put it back on there.
    Good luck,
  10. Dec 8, 2015 at 11:23 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
  11. Dec 8, 2015 at 11:26 AM
    Lumpskie
    New Hampshire
    Touche!
    The flat blade screw driver method might work to remove it. OP: can you get the plug to tighten again?
  12. Dec 8, 2015 at 11:26 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    ^THIS.
  13. Dec 8, 2015 at 11:32 AM
    bry838
    oregon
    Haha didnt mean to be a peckerhead! Couldnt resist.
  14. Dec 8, 2015 at 11:33 AM
    Lumpskie
    New Hampshire
    Haha, no offence taken!
  15. Mar 27, 2020 at 5:48 AM
    UOFan
    UOFan Well-Known Member
    Bryan
    NC
    1994 Single Cab DLX, 2013 TRD Sport, 1999 Dodge 2500 360 V8
    5100 Lift + AAL
    Paging OP. Any updates on the bolt removal?
    Bringing this thread back from the dead. This is the closest topic I could find to the same issue ive created with my 2nd Gen Rear diff drain plug. The bolt just spins and spins, wont get any tighter. Thinking its also the actual drain plug threads.
    I know once I get the bolt out, i'll have to tap the hole and get a larger drain plug bolt, just trying to figure out how to get this dang bolt out first.
  16. Mar 27, 2020 at 7:01 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Did you try the method that was suggested?
  17. Mar 27, 2020 at 7:31 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    OP logged out 5 years ago
    Try using a flat blade under plug while turning
    Gunshot-6A likes this.
  18. Mar 27, 2020 at 8:03 AM
    UOFan
    Bryan
    NC
    5100 Lift + AAL
    Thank you, i'll try that once i've bought a second bolt.
    I've been reading about tapping, and I saw a few people recommend using a thread restoration kit instead. Do you have any experience with these?
  19. Mar 27, 2020 at 8:04 AM
    UOFan
    Bryan
    NC
    5100 Lift + AAL
    Not yet, I don't have a replacement bolt yet (Just in case). Trying to get an idea of all the different ways to go about this, to make sure I have all the necessary tools before I start this project.
  20. Mar 27, 2020 at 8:19 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Wow, just took a quick look around McMaster Carr and this seems like an expensive project unfortunately.. Roughly $170 just for an M18 drill and tap (I think the stock size is M16). I would feel better with new threads, but an M16 helicoil may work just as well. Not any cheaper though.. Also getting all of the chips out of the diff before refilling would be a consideration
