Rear Diff Upgrade Question
Discussion in '4 Cylinder' started by VTDave, Apr 14, 2009.
  1. Apr 14, 2009 at 2:10 PM
    VTDave
    VTDave [OP] Well-Known Member
    Vermont, USA
    05 Access Cab 4x4 Base 5sp Man, 16 DCSB 4x4 Sport 6sp Man
    From reading other posts, it seems you couldn't get the factory limited-slip differential with the 2.7L engine (2005+ Tacomas). You had to get the V6 and add-on SR5/TRD. I have the 2.7L, but I'd like to have a limited slip on my truck's rear end.
    I haven't heard much about 4cyl guys doing aftermarket diff swaps. So, a couple of questions:
    1. Has anyone done this?
    2. We have the 8.4" rear end, right?
    3. What do you think of this diff?
    http://www.drivetrainspecialists.com/categories/trutrac/products/product-5410.html
    Mainly I'm looking for a diff that will hold-up to a little snowplowing and off-roading, but will have decent street manners.
    Thanks,
    Dave
  2. Apr 14, 2009 at 2:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yes, you have the 8.4", and Yes, thats a good diff. :)
  3. Apr 15, 2009 at 7:31 AM
    VTDave
    Vermont, USA
    i think i'll be ordering one of those. thanks.
  4. Apr 16, 2009 at 6:03 AM
    VTDave
    Vermont, USA
    New Mexico Taco: I think you're right with respect to the '08s. I have an '05 and I couldn't find a 2.7L with a limited slip. My method was to look for the "LSD Oil Only" sticker on the underside of all the Tacomas on a given dealer's lot. My informal survey at the time, based upon the underside of ~50 trucks, indicated that you had to get the V6 with SR5/TRD.
    But glad to see that Toyota is giving us more options now.
  5. Apr 16, 2009 at 6:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They dont. Some are an open diff.
  6. Apr 16, 2009 at 6:47 AM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    I have a limited slip diff. I would like a diff locker though.
  7. Apr 16, 2009 at 7:26 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
  8. Apr 16, 2009 at 9:52 AM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    Also I think the Dana LSD is a mechanical unit where as the Toyota unit uses clutch discs. I would prefer a mechanical unit over a clutch based unit any day.
  9. Apr 16, 2009 at 11:29 AM
    VTDave
    Vermont, USA
    Big Red Toy: I figure I'll go with the Dana mechanical LSD since the clutch packs in others tend to wear out over ~50-100k mi, slowly turning into an open diff
    NM Taco: Easy way to tell if you have a rear LSD. Get on some smooth pavement. Stop the truck. Floor it. Look back. If you see two black tire marks back there, you probably have LSD. To make sure, try it again a few more times. :)
    Easier method: get under the truck and look for the "LSD Oil" sticker on your rear diff. They put one there so the guys at Jiffy Lube know that you need gear oil with a non-slip additive.
  10. Apr 16, 2009 at 11:37 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Jack the rear end up off the ground with the truck in neutral. Be sure to block your front wheels for safety and what not. Rotate either wheel forward. If the opposing wheel turns in the opposite direction you have an open differential. If the wheel on the other side turns in the same direction you have a mechanical LSD.
  11. Apr 16, 2009 at 12:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Normally, I would agree with this, BUT, last summer, I had a frieds truck off the ground, and both tire spun the same direction, and he had an open diff. I theink the best way would be (other than opening it up), Look for the "LS Diff fluid" sticker, or run your vin thru Toyota.
  12. Apr 16, 2009 at 4:01 PM
    SC4333
    Grant
    FL
    Thats really strange, I have never seen such a thing. It goes against the principle of how an open diff works, although, I am not saying it didn't happen because you witnessed it yourself. Maybe there was some trash caught up in the spider gears?? :confused:
    Did you have the parking break engaged? If so this would be the cause of only one wheel spinning.
    If all else fails, the idea Chris mentioned of checking out the sticker above your fill plug would be a good indication of whether or not you have an LSD.
  13. Apr 16, 2009 at 4:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I actually asked if he installed a locker. I had the third member out, and saw that it was, indeed, open. Im thinking it "may" have been due to a thicker oil, but I know there was nothing else in the diff. Now, it IS the only time I have seen that happen, so I just thought I would throw it out there.
  14. Apr 17, 2009 at 7:50 AM
    wawireguy
    wawireguy Well-Known Member
    Not sure why your wanting to upgrade your diff.. Stock diff should be fine for what you're wanting to do.
  15. Apr 17, 2009 at 4:28 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Was that to the OP?? Cause an open diff like he said he has is totally useable for offroad and snow- but the LSD would be much better and a locker might be even better depending on how much and where he is going offroad and plowing...
  16. Apr 17, 2009 at 6:05 PM
    burhead
    burhead Member
    Craig
    Thunder Bay
    2009 Tacoma 2.7 - 4x4
    Timbrens added to suspension Custom made boat racks
    Hey VTDave how did that diff work out I may do just the same thing on my 2009 Tacoma.
  17. Apr 20, 2009 at 8:53 AM
    VTDave
    Vermont, USA
    The True Trac arrives at my house on Wednesday. It goes in this weekend.
    For the poster who asked why I'm bothering to get one: my driveway is hardpack (dirt/gravel) with some switchbacks and a 17% grade. I'd like to get up in 2WD without tons of wheelspin. Also, for plowing on slippery surfaces, it's nice to have both wheels in back hook-up consistently.
    I'd like to go the air locker route, but that's some serious $$$.
  18. Apr 22, 2009 at 5:21 PM
    wawireguy
    It is so hard to stop. Put it in 4wd and start driving.. My vote is for the ARB! : )
  19. Apr 23, 2009 at 9:40 AM
    burhead
    burhead Member
    Craig
    Thunder Bay
    where did you find the best price for your new diff????
  20. Apr 23, 2009 at 10:15 AM
    VTDave
    Vermont, USA
    I stuck with drivetrainspecialists.com since they patiently answered all my questions and didn't hose me on shipping. Yeah, you could do better on Ebay or Yotatech classifieds, but I decided to give the sale to the people who took the time to tell me everything I needed to know...
