Rear diff vent - just found out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tomrad, Nov 3, 2022.
  1. Nov 3, 2022 at 2:33 PM
    tomrad
    tomrad [OP] Well-Known Member
    2008 Tacoma Access cab, automatic 4x4
    ....the hard way. My rear differential vent is plugged solid. Found out when I drove 15 miles and had fluid dripping out of the left rear drum.
    My question - after reading horror stories, is it likely the wheel bearing is damaged from the fluid pushing through it, and/or, is my seal also ruined?
    Didn't leak a drop until today. I'm replacing my rear brake shoes this weekend anyway, but didn't expect this.
    Thanks for any advice.
  2. Nov 3, 2022 at 2:41 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Mine blew a seal at 74k
    I replaced the seal. Sprayed the shoes down with brake clean and slapped it back together.
    I am at 157k now. Still on the same bearing and shoes.
    This isn’t normal though. Typically the bearing fails not long after. I got lucky I guess?
  3. Nov 3, 2022 at 2:54 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Fix the breather, replace the seal, clean your bearings.
    You might be fine, you might not be.
    Idaholandho likes this.
  4. Nov 3, 2022 at 5:12 PM
    tomrad
    Thanks all for the replies.
    Is it possible my seal is ok, and the plugged vent is the only problem?
  5. Nov 3, 2022 at 5:14 PM
    TnShooter
    Deogee
    STOCK
    There is only one way to find out.
    Clear or replace the vent and see if the leak stops.
    I’d also check your fluid level and top it off.
    winkel and Dm93 like this.
  6. Nov 3, 2022 at 5:35 PM
    Family1st
    Family1st Thneeds?
    Upstate New York
    2010 DCSB 4x4 auto SR5 52,000 miles
    -All Pro dual swingout rear -AllPro Front Bumper -Lear topper -Prinsu CabRack w/Cali-raised lightbar -Rhino Rack Pioneer Rack for topper(sold) Rhino Rack tracks and Aero bars for topper -AluCab 270 Shadow awning -Roofnest Condor XL -Weathertech fronts/rears -ARB series II 50qt -Total Chaos bed supports -5 SCS RAY10’s Dark Matte Bronze w/285 75 16 Atturo M/T -FOX Performance Elite front coilovers with ICON tubular UCA -FOX Performance Elite rears riding on RXT (option 3) -Brand New Frame (dealer installed) -IN THE MARKET FOR Sliders, fridge slide, Considering decked system (in desperate need to organize), Electronics control center, as the list gets shorter it keeps getting longer.
    That reminds me, my driver side shoes and drum were a little moist when i did my recent suspension swap. I’ll have to check the breather. Seems like as much as i want to drive this truck, i can’t stop building/working on it.
    TnShooter likes this.
  7. Nov 3, 2022 at 5:53 PM
    tomrad
    :fingerscrossed:...thanks!
  8. Nov 5, 2022 at 7:56 AM
    tomrad
    An idea.....
    Since I did not drive very far with the leaking seal, I don't see why I can't regrease the (sealed) bearing. I have done that with similar bearings before and it works fine. Wonder if anyone else has tried that on a (still good) 2nd gen rear bearing?
  9. Nov 5, 2022 at 9:04 AM
    TnShooter
    Deogee
    STOCK
    I never heard of it.
    I didn’t look close at mine when I did the seal. I was more less in “get it done” mode. I didn’t even drain the differential.
    I just jacked the side up I was workin on higher that the other, that way diff fluid didn’t come out when I pulled the axle.
  10. Nov 5, 2022 at 9:40 AM
    tomrad
    I may do just as you say, I spend most of my life in 'get it done' mode.
  11. Nov 6, 2022 at 7:50 AM
    tomrad
    Update - only had time to top off the differential with some 75w90 and clean up the inside of the wheel. Drove for several miles, and all I found was a slight spatter, one or two drips of fluid. May be residual from inside the drum when I applied the brakes, not sure.
    So I wiped it dry again and will drive it later today. Maybe the seal survived? Will see and will post back.
    If all seems well, I'll pull the brake drum tomorrow and clean it thoroughly.
    TnShooter and Leomania like this.
  12. Nov 6, 2022 at 8:59 AM
    tomrad
    Just thought of this also.....removing the abs sensor would make a great inspection hole to see if the seal is leaking.
  13. Nov 6, 2022 at 10:34 AM
    TnShooter
    Deogee
    STOCK
    I choose to not pull the ABS Sensor unless I’ll have too. If it’s stuck and you break it off in there. You got more problems. The axle has to come out then. Because you’ll have to drill it out.
  14. Nov 6, 2022 at 10:41 AM
    tomrad
    Yeah, had this happen on a Mitsubishi. Tks for the reminder.
  15. Nov 6, 2022 at 4:22 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    I actually had GREAT luck drilling a pilot hole, gently driving in a wood screw (coarsest, deepest threads I could find), and pulling. Granted, it busted off just below the threaded portion, so the only thing holding it in was the swollen sensor body against the hole.
    TnShooter[QUOTED] likes this.
  16. Nov 6, 2022 at 4:24 PM
    TnShooter
    Deogee
    STOCK
    That’s an option. :thumbsup:
  17. Nov 6, 2022 at 5:53 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    That gear oil will ooze out of the axle housing for awhile even if the seal is good so clean the tube to backing plate with brake clean and may have to do a few times.
    If no active drips running down the backing plate you are probably OK. You can also check that the 4 bolts holding the axle in are tight as nuts show at backing plate and only a box or open end wrench will fit up there usually on the lower 2.
  18. Nov 7, 2022 at 5:37 AM
    tomrad
    Thanks, yeah, I have driven the truck probably 25 miles since opening the clogged vent on Thursday and getting a tiny bit of oil drip on the inside of the wheel.
    Going to clean it up well and see if the drip stops. Thanks!
  19. Nov 7, 2022 at 12:55 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Look for the link on breathers - I extended mine and replaced it with a two way - my brother in-law didn't and his blew the seal and is leaking. I'm sure there are details in a Sticky Thread post - If I can find it I'll post it.
  20. Nov 7, 2022 at 1:02 PM
    tomrad
    Thanks, that's a good idea. I've owned mostly Fords, and they all had a vent hose.
    Update also - just cleaned the brakes and drum, drove several miles, and no visible leak. Going out to pull the drum and check at the axle. Maybe I got lucky and my seal is ok, not sure yet. But I did buy a seal and o-ring, just in case,
