Rear diff vent - just found out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tomrad, Nov 3, 2022.
  1. Nov 7, 2022 at 1:26 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  2. Nov 7, 2022 at 1:31 PM
    tomrad
    tomrad [OP] Well-Known Member
    2008 Tacoma Access cab, automatic 4x4
    Thanks George!
    Second update - I need to install that seal, just pulled the drum and the brake shoes are saturated again. Oh well, no free lunch, as they say.:D
    TnShooter likes this.
  3. Nov 8, 2022 at 4:08 PM
    tomrad
    Final update (I hope)........
    Replaced the left seal today, truck is back together. I see now what happens with these: the vent clogs, the lip of the inner seal is pressed harder against the sealing surface causing premature wear. Eventually, the seal lip is so thin that it comes off (along with the spring). Then you get the sudden leak.
    Planning to replace the right side also, seeing how it's a ticking time bomb.
    Hoping my bearing survives. I caught the leak right away.
    TnShooter and Steves104x4 like this.
  4. Nov 8, 2022 at 5:52 PM
    george3
    New Jersey
    Could do a write up with pictures when you do the right side. Thanks.
    steelcity2 likes this.
  5. Nov 9, 2022 at 1:28 PM
    tomrad
    Actually, I found a write-up on Tacoma World from 2013, really good information. I'll look for the link.
  6. Nov 10, 2022 at 6:21 AM
    tomrad
