Rear Diff whine again
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TTtaco, Apr 24, 2019.
  1. Sep 1, 2020 at 9:25 PM
    #41
    Mountainmike87
    Mountainmike87 Well-Known Member
    2017 silver TRDOR
    my truck makes the exact same noise and it’s now regeared. It’s definitely something weird, but probably not the gears
  2. Sep 2, 2020 at 6:03 AM
    #42
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Beginning to think its some sort of harmonics to, or wind noise at a certain speed. Some seem hear it others don't. I would think if harmonics coating various chassis components like the leafs may stop whatever it is. I can tell you after coating the undercarriage on my truck the road noise got quieter in the cab, but i never had the howling to begin with....at least yet.
  3. Sep 29, 2020 at 2:57 PM
    #43
    ARMYCA
    ARMYCA Member
    Oleksii
    2018 Toyota Tacoma, TRD OFF ROAD
  4. Sep 29, 2020 at 3:07 PM
    #44
    binderline
    binderline Well-Known Member
    2019 TRD OR MT Cement
    Somebody get this guy the Grammarly app. j/k ;) In all seriousness, good luck with the new diff! :fingerscrossed:
  5. Sep 29, 2020 at 5:07 PM
    #45
    zoo truck
    None
    Truck sounds haunted....weirdest sound i've heard in any truck.
  6. Sep 29, 2020 at 5:20 PM
    #46
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    been around a while.............ivv seen many a hot rodder seek the advantage of a gear set
    way back when the ' Rock Crusher ' /whine in camaroz
    the Detroit Lockers rear diffs were clunking /bangin .......................even tho set up correctly
    very few mechanics know how to set the ' Lash ' on any rear end
    so the line mechanics at Ur local dealer are going to be inept & reluctant
    *******. long run whine is NOT good
    no less there are MANY New Stock vehicles sitting on showroom floors that DONT need
    Special rear diff ' Break Ins '....................that DO NOT Make Noise !!!!
    3/4 .......1 ton ........ service trucks ........right up to 20000lb single axle specialty vehicles
    whinging .....clunking......bangin ......slipping is Unacceptable
    what makes matters worse is the guy U r talking to more than likely CANT Help U !!!
  7. Sep 29, 2020 at 5:28 PM
    #47
    ARMYCA
    ARMYCA Member
    Oleksii
    Any idea what can it be?)
  8. Sep 29, 2020 at 5:33 PM
    #48
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    17 second video? really what noise
  9. Sep 29, 2020 at 5:52 PM
    #49
    ARMYCA
    ARMYCA Member
    Oleksii
    Too short or what?
    BillsSR5[QUOTED] likes this.
  10. Sep 29, 2020 at 8:03 PM
    #50
    BillsSR5
    bill
    2014 SR5
    didn't have a chance to hear anything but road noise
  11. Sep 29, 2020 at 9:26 PM
    #51
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    My 20 does this when i Feather the throttle . Let off the gas the Harmonic noise goes away .I have got used to it . I learned to let off the gas pedal when it does it and it seems to go away .
  12. Sep 29, 2020 at 9:32 PM
    #52
    Tacoma1997White4x4
    Tacoma1997White4x4 America First
    West Covina, California
    1997 white 4x4 auto 4cylinder Singlecab, 2001 auto rwd 2.4l single cab flatbed
    Km3’s 31’s,Lift,Sliders,rear ARB air locker,on board air, armor, hi shell
    Go in with a camera, start a ruckus, then hold a sign outside, protest, watch how fast theyll accept your truck for a trade
  13. Sep 29, 2020 at 11:50 PM
    #53
    jrshaw91450
    jrshaw91450 Well-Known Member
    Maui
    2019 Cement Tacoma TRD OR 4x4
    TRD Cat back & Skid plate
    My 19 whines horrible between 55 & 58. I hate the sound it so much and nearing my wits end with it. No one has seemed to find a fix and Toyota doesn’t care anymore. I have come close to lifts and/or MT’s but then find it ridiculous that I need to alter a $40k truck to try and get rid of a sound that should not be there.
    jetfishn and wmjchastain like this.
  14. Sep 30, 2020 at 1:42 AM
    #54
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    My '17 did this around 50-45 MPH when letting off the gas. The howl was obvious. My '20 doesn't appear to make these sounds like the '17 did. I was never concerned that it was a serious issue because nobody has found any bad signs with wear and tear causing the sounds. Harmonics? Oh well, turn up the music and problem goes away!
  15. Sep 30, 2020 at 3:59 AM
    #55
    jetspeed
    jetspeed Well-Known Member
    MD
    19 TRD Sport DCSB 4x4 Manual Taco
    2019 Sport did it day 1 when new and still does. There will never be a fix. Toyota does not care because we keep buying Taco's in record numbers.
    jetfishn likes this.
  16. Sep 30, 2020 at 5:54 AM
    #56
    zoo truck
    None
    Really haven't any idea. I had a drag car back in the 70's that after we setup the rear gear ratio with 4.56 zoom gears in a posi unit, it howled like s.o.b. Imo, i think it was either the gear hardness, and type of steel used manufacturing them, or the actual cut. As far as the taco's it may not even be the gears, maybe something related though. I have not heard anything like it yet in my 2020 v6 access cab, its a very quiet truck, so my guess is as good as yours.
    cryptolyme likes this.
  17. Sep 30, 2020 at 11:17 AM
    #57
    acupunk
    acupunk Well-Known Member
    '19 4x4 TRD OR DCSB
    I think I'm dealing with this but mine kinda sounds like a mix, like the annoying oscillating vibrations when you have a single window rolled down on the highway, but containing a higher pitch whine clearly coming from the rear end- is that about right? Though I could be hearing what I want to, the video above by @ARMYCA seems to reflect what I have going. Mine gets really noticeable around 45mph- and became clearer after I put a cap on my truck.
    Correct me if the following isn't true: seems the consensus is that its NOT an indication of an imminent blowup of the rear diff, that trying to get a dealership to fix it is like trying to win the lottery, that maybe spraying/ messing with leafsprings will help, maybe checking/ changing rear diff fluid will help, changing the rear diff out completely might work but it's possible it'll come back after a few thousand miles.
    Man- it's frustrating, but really I just want to know its not going to become a bigger problem down the road (does anyone actually know that?)
  18. Sep 30, 2020 at 12:42 PM
    #58
    zoo truck
    None
    Toyota engineers need to take a perfectly good gen3 truck that has some miles that doesn't howl, and examine it carefully against one that does. I can't believe they already haven't figured it out. Imo, must be too costly to redesign something, but they'd rather leave it alone as long as no damage to the vehicle occurs.
    acupunk[QUOTED] likes this.
  19. Sep 30, 2020 at 12:48 PM
    #59
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    probably just the resonator. they are designed to match the harmonics of the intake...so that could be what you are hearing. you could remove it, but it would probably reduce power.
    https://itstillruns.com/air-intake-resonator-do-12156112.html
  20. Sep 30, 2020 at 7:05 PM
    #60
    ROAD DOG
    FEW
    all gear sets are NOT the same ( Dana ..... Spicer..... Detroit...... Richmond )
    from inceprtion to completion there is a decided difference
    the 351 Cleveland vs windsor are diff in some areas.......not in others
    Not like FORD ordered 2 Diff engines
    most manufacturers have more than One ( 1!! ) line o manufacturer & assembly
    at General Motors many of the Olds V8s were ' Balanced ' ...................
    in that parts were more closely matched le
    nth & weight
    if U stand at the end of 2 lines making rods measure & weigh over several batches
    U will find a variance between rods from diff lines to those on same line
    some sanctions require the rods be ' Production ' ( randomly selected )...... essentially ' Numbered '
    as opposed to special batch runs ( hand picked few from the many )
    still askilled builder will attempt to run near same length & weight
    point im attempting to make on 70s GTO is there was NO aftermarket match
    some of the complaints are NOT confined to the SAME criteria
    same oil
    same tyres
    same lift
    same assembly
    void o ANY modifications
    not possible to expect or obtain SAME results
    Taylor21554 likes this.
