Rear diff whine...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ghost848, Nov 7, 2012.
  1. Nov 7, 2012 at 1:05 PM
    Ghost848
    Ghost848 [OP] Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    As the title says, after last weekends wheeling i was on my way home and started to hear a whine from my rear diff. It only does when under load (pressing gas) through gears 1-6. Is it my ring and pinion? Or is it possable that the diff oil has broken down? Has Lsd added to it.:confused:
  2. Nov 7, 2012 at 7:33 PM
    Ghost848
    Tony
    Alberta,Canada
    Nothing huh
  3. Nov 7, 2012 at 7:36 PM
    jandrews
    '09 FourDubDee TRD OR
    If it changes with acceleration it could definitely be the R + P. Start with a diff fluid change. If the sound gets worse, you'll want to have it checked out professionally.
    If you dragged the pinion flange or driveshaft while wheeling, it's possible you damaged the crush sleeve that sets pinion preload. If that's the case, you're looking at a new gear setup at a minimum.
  4. Nov 7, 2012 at 7:37 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    I had something similar to this that i noticed. After offroading when i let off of the gas around 50mph it sounded like a whine from the rear diff. Got home sprayed off the under carriage and took a quick look for any thing out of the ordinary. Took it for a drive again and no whine, never figured out what it was. Good luck with figuring it out.
  5. Nov 7, 2012 at 7:38 PM
    Ghost848
    Tony
    Alberta,Canada
    Dragged...?
  6. Nov 7, 2012 at 9:42 PM
    BradyT88
    BradyT88 Well-Known Member
    Mine started to whine to. Pretty sure it was the pinion bearing or the crush sleeve. Didn't exactly figure it out cuz I just regeared. It only happened when there was load on the diff. Either accelerating, or decelerating from engine braking. Made no noise at all in neutral. Put the rear on jack stands and had to set the ebrake while it was spinning the tires with the locker engaged to get enough load to produce the noise. It was crazy loud from the back of the diff.
    We pulled the diff and tried to diagnose it without pulling the gears apart but couldn't tell what it was. We did find a nick in the ring gear that was over the pinion pattern so that possibly could have caused the noise, but we doubted it.
    Mine sounded like this
    http://www.youtube.com/watch?v=RtmWvUPvS74
  7. Nov 7, 2012 at 11:53 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  8. Nov 8, 2012 at 4:42 AM
    jandrews
  9. Nov 8, 2012 at 5:44 AM
    Ghost848
    Tony
    Alberta,Canada
    K thanks guys maybe time to serch for a regear?
  10. Nov 8, 2012 at 8:31 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Possibly... then again your gears could last another xxxxx amount of miles!
  11. Nov 8, 2012 at 8:49 AM
    Ghost848
    Tony
    Alberta,Canada
    That is a horrable noise lol anyone knowof someone trying to sell arb equipped 4.56-4.88 front and rear?
  12. Nov 8, 2012 at 8:54 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Last I checked niwi had his rear arb still???
  13. Nov 8, 2012 at 9:08 AM
    Ghost848
    Tony
    Alberta,Canada
    Yeah i sent him a pm but nothin... Probly got 100s of pms with the price of the front
  14. Nov 8, 2012 at 10:04 AM
    Ghost848
    Tony
    Alberta,Canada
    Is it possible to do the rear in a differnt gear for a bit? As long as i dont engage 4x4?
  15. Nov 8, 2012 at 10:08 AM
    BradyT88
    Yes, you just make damn sure you don't engage 4wd. In fact, I would take the front driveline out until the gears matched.
  16. Nov 8, 2012 at 10:08 AM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Yes. The key being DO NOT ENGAGE 4x4.
  17. Nov 8, 2012 at 10:16 AM
    Ghost848
    Tony
    Alberta,Canada
    I would think so too but its only making the noise under acceleration not decel...like when i gear down
  18. Nov 8, 2012 at 11:42 AM
    Ghost848
    Tony
    Alberta,Canada
    Perfect ill start there thx for the help guys
  19. Nov 8, 2012 at 12:04 PM
    jandrews
    Typical pattern is noise under acceleration followed by noise under both accell and decell, followed by constant noise, followed by kablooie.
    8.4 rear diffs are solid. The elocker diffs are about as solid a potato chips.
  20. Nov 8, 2012 at 1:31 PM
    Ghost848
    Tony
    Alberta,Canada
    Ill start with ujoints... If it comes to it ill buy a new bag of potato chips
