Rear diff
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sonnfish, Nov 23, 2020.
  1. Nov 24, 2020 at 12:10 PM
    sonnfish
    sonnfish [OP] Member
    sonnfish
    06 Tacoma TRD 4x4
    lifted
    Sigh. They were on ground, but it was more likely hardpack/caliche than soft.
    The fact that I never used the diff lock has been brought up as being the potential cause.
    I don't think water intrusion could be a factor since it never, ever, ever rains here anymore.
    Clearly I will have to learn about this locker better if I keep the truck.
    Might be time for that mid-life crisis vette.
    Thank you as well TnShooter for your insight.
    TnShooter likes this.
  2. Nov 24, 2020 at 12:31 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    A question you can ask your self is “Do you need the Differential Lock?”
    If you never plan to use it, you could manually disengage it.
    Then just never use the Diff Lock button. Unless you want to risk this happening again?
    Since you say the truck is with a Mechanic, and he is a friend.
    Maybe he can just get it unlocked, that is if you choose this option?
    This link below is for the earlier year Tacoma’s, but the basics operate the same exact way.
    sonnfish[QUOTED][OP] likes this.
  3. Nov 24, 2020 at 12:54 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Whatever you do, OP, do not let your BF or his brother off the hook. They are responsible.
    If the mechanic and BF are tight, then I would suspect the diagnosis and extent of the repair. Suggest to find a mechanic independent of the BF connection.
    whatstcp and sonnfish[OP] like this.
  4. Nov 24, 2020 at 12:58 PM
    TnShooter
    Deogee
    STOCK
    I’m not taking sides.
    But how does one know something is or isn’t broken if it is never used?
    With the history of these actuators, it’s very possible it would have happened if SHE were the one to use the Locker.
    Again, I’m not siding with anyone.
    If anything, I’m saying “Don’t borrow other people’s stuff”
    Things can happen.
    sonnfish[OP] likes this.
  5. Nov 24, 2020 at 1:09 PM
    Knute
    You bring up an interesting point. But it is of no consequence, since the truck was being used be the BF.
    Pulling stumps with a truck is NOT appropriate use of the truck, especially when it was borrowed under the pretense of moving.
    An item used or not in the owner's possession is not disputable. This is 100% on the BF and his brother.
    Reality, she did not use the locker. The BF and his Brother used the locker when it was broken. The truck was in their possession.
  6. Nov 24, 2020 at 1:13 PM
    sonnfish
    sonnfish
    06 Tacoma TRD 4x4
    lifted
    So will the rear diff lock come on while going down the freeway? That seems highly unlikely.
    Just trying to ferret out the truth.....
  7. Nov 24, 2020 at 1:14 PM
    reg0928
    reg0928 Well-Known Member
    Ross
    Crestone, Colorado
    05 TRD OR Access Cab
    3"OME, 255/85R16
    No. The truck myst be in 4LO for the locker to work
  8. Nov 24, 2020 at 1:20 PM
    sonnfish
    sonnfish
    06 Tacoma TRD 4x4
    lifted
    So the comment "better it happened to us instead of you on the freeway where you could have been killed" is grossly inaccurate?
    (peeling the layers)
  9. Nov 24, 2020 at 1:26 PM
    Knute
    Yes, completely inaccurate.
    That statement is an attempt to capitalize on your ignorance about how the locker works. The purpose of the statement is to put fear into you so you will be compelled to pay for the repair. Shouldering the responsibility because of fear for your safety.
    Don't swallow that nonsense. Dig into your Owner's Manual. I suspect it has clear details about the operation of the Diff Locker. Stick that Section under the BF and his brother's nose.
  10. Nov 24, 2020 at 1:34 PM
    sonnfish
    sonnfish
    06 Tacoma TRD 4x4
    lifted
    I'm actually thinking I won't stuck it under and it won't be the nose.
  11. Nov 24, 2020 at 1:36 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Pop off the motor, put a big pry bar on the rack gear in the 3rd member, and manually unlock the diff. With the motor off, plug in the connector and actuate it from the dash. See if the motor and pinion gear spins and if your diff lock light works. If that's all good get it back to the unlocked state and reinstall. If the motor/actuator is struggling pull it apart and give it a clean and rebuild. See youtube. All done.
  12. Nov 24, 2020 at 2:08 PM
    sonnfish
    sonnfish
    06 Tacoma TRD 4x4
    lifted
    Probably beyond my skill set but I printed your instructions out. Thank you!
  13. Nov 24, 2020 at 2:25 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Might be time for a new boyfriend and another mechanic. Wait til they pay for the repairs and then adios.
  14. Nov 24, 2020 at 3:19 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Got a good laugh reading all the BS here.
    Using the e-locker was the correct approach for the pull (if roots cut off) as when the locker is engaged in 4Lo it turns off the ABS so does not fire on slipping and the engine management that ramps down the throttle as slip occurs. Its an 06 so its really not their fault the actuators do not work too well. Lots of info on how to analyze the problems and the fixes on this site.
    But first get in truck, start, look at lights telling you state of 4x4, put in neutral, shift 4Hi to 4Lo, if in 4Lo, depress the rear diff locker switch, put in drive, do slow S-turns and see if it unlocks, if not, stop, do the neutral thing again and switch locker off again. If it goes off good to go back into 4Hi then 2Hi. If not read the posts or have the mechanic resolve for you. These systems do have contact problems so nothing new here.
  15. Nov 24, 2020 at 3:59 PM
    #35
    sonnfish
    sonnfish
    06 Tacoma TRD 4x4
    lifted
    Wow. I did not find any BS.
    Have the mechanic resolve for me....stellar advice.
    Everything you mention was supposedly done.
    When I ever get my truck back I will try everything you said, but I guess the mechanic will do it, so maybe not.
    Just like you said......
  16. Nov 24, 2020 at 4:04 PM
    #36
    MattiveAmerican
    MattiveAmerican Well-Known Member
    2006 White ACLB
    BuiLt 4 OveRLanDiNg
    Wrong and wrong. Actuator gets installed and removed with diff LOCKED otherwise it won’t work right. And the dash light will not function as designed if you actuate the actuator outside of the differential because the sensor is on the diff. I.E. If the shift fork isn’t moved by the actuator (because the actuator is in your hand and you’re looking at it), then the shift fork can’t push against the sensor and activate the light. The sensor is a failsafe, it’s not there to tell you the actuator has turned, it’s there to tell you the shift fork has shifted the diff lock collar to engaged.
    OP, easiest way to tell for sure if locker is engaged is to jack up the rear end, spin one tire by hand, if the tires turn opposite directions, the locker is disengaged, if they turn the same way it is engaged.
    The actuator on these diffs has intricacies specific to Toyota’s where as other brands don’t work the same, so your boyfriends friend may not know how to work with them but there is a lot of info on this forum about how the e locker actuator functions.
  17. Nov 24, 2020 at 4:29 PM
    #37
    ShimStack
    Ben
    NC
    You can check the light by manually locking and unlocking the diff while checking the motor function and having it in the right state. You'll have to explain why removal must occur in the locked state. If the states match it should be happy.
    IDtrucks likes this.
  18. Nov 24, 2020 at 4:32 PM
    #38
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    :rofl: this thread
    The amount of abuse that get thrown at the rear end of these trucks while wheeling is way more than you can ever do pulling out a stump. I am confident that unless your bf put the truck in 4lo and activated the diff then just floored it (not allowing it to engage fully), it didnt cause the damage. These actuators are very prone to getting wet inside and corroding contacts that keep it from functioning right. I think your BF knew what he was doing, and did it correctly, its just a part that is known to fail on a 14 year old truck.
    You can drive around all you want with the rear diff locked on pavement, it'll just chirp and chew up your tires as they slip and break traction. as others have said, getting the diff to unlock can deff take some back and forth and tight turning in an s shape. I usually turn full lock one way and reverse a few feet, and that does the trick
    Im pretty sure you dont need the lock sensor to work the elocker (i put mine in after the fact and never even plugged in the lock sensor harness, so i know its not necessary). The lock sensor flashes while the motor waits for the the locker mechanism to line up for the pinion to slide the rack over. if this happens successfully, the motor/cog in the elocker actuator has made its full rotation and completes the circuit telling the lock sensor and dash light that the locker is engaged. you know your locker is engaged because you turn sharply on pavement, and the back chirps like a wounded dog. you can always jack up the rear of the truck, pull the motor off, and slide the rack to unlock or lock the diff. When you put the motor on, *i think* you just have to put them on with the motor and diff locked or unlocked so they are starting in the same place
    also, if the motor must be removed for servicing, and it wont lock, it would be pretty hard to remove the motor in a locked state
  19. Nov 24, 2020 at 4:41 PM
    #39
    MattiveAmerican
    2006 White ACLB
    BuiLt 4 OveRLanDiNg
    Well if you really want to get technical, you can remove it however you want, but have to install it locker locked and actuator locked.
  20. Nov 24, 2020 at 4:46 PM
    #40
    MattiveAmerican
    2006 White ACLB
    BuiLt 4 OveRLanDiNg
    I didn’t say you need the sensor installed the make the actuator work. I said the sensor will not function if the actuator is being tested outside of the vehicle. The sensor is sensing the shift fork (that is pushed by the actuator) being against it. If you slide the fork with a pry bar like you’re suggesting, the sensor will show it is locked, it has nothing to do with the actuator. As for reinstalling the actuator,
    You have to install the actuator in the locked position and the diff in the locked position.
