Rear Diff??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HDFD10, Jan 16, 2010.
  1. Jan 16, 2010 at 9:17 AM
    HDFD10
    HDFD10 [OP] Well-Known Member
    Hey guys. The book says it holds 2.5 quarts ( i read it after the fact). Drained diff and was filling it up, figured you just filled it up till it started to run out of fill hole or is this incorrect? I just put 3 quarts into but the book says 2.5. At 3 its still not running out of fill hole yet but its close. Did i mess up?? Please help, its sittin in garage now, Thanks!
  2. Jan 16, 2010 at 9:21 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
  3. Jan 16, 2010 at 9:26 AM
    HDFD10
    So do i want to keep filling till it comes out of the fill hole?
  4. Jan 16, 2010 at 9:34 AM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    I didn't. I think I put more in than what came out a (coffe can amount)
    When I was filling it. Some would come out and go back in to the tube so then I would wait for the oil to go down the length of the axle then I just started again.
  5. Jan 16, 2010 at 9:46 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Do you have a 4x4/Prerunner, or a 5 lug?
  6. Jan 16, 2010 at 9:47 AM
    Chester
    Chester Well-Known Member
    Nor Cal
    07 Access Cab TRD-OR M-V6 4x4
    Rear Spring TSB,Locker Mod,In bed cargo lights,Fully de-badged,TRD Seat Covers,Trailer Harness Relocation,Painted wheels,Extra tie-downs,5100's,Biceman lighting,09 stereo with sirius & isimple ipod interface,Rear diff breather mod,K&N Air Filter
    Fill till it starts to spill out have the plug ready give it a few extra pumps and cap it off.Good to go;)And i hope your the truck is level!
  7. Jan 16, 2010 at 9:49 AM
    HDFD10
    Its an 06 4 door TRD off road. And i guess i am going to just fill it till it spills out. Also is there a write up on how to get to the front?
  8. Jan 16, 2010 at 9:52 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Use only 3 quarts. Thats what the book says. Over filling can cause the oil to cavitate, and it will not lube propperly. The front is similar to the rear, just with a 10mm hex nut, instead of a standard nut.
  9. Jan 16, 2010 at 9:56 AM
    HDFD10
    So just leave it with what i have in it now? You dont fill it till it poors out?:confused:. Thsi toyota is going to kill me. Unlike any truck i have owned or worked on before. And to get to the front do you need to drop the skid?? Also how much does the front hold?
  10. Jan 16, 2010 at 10:00 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its easier if you drop the skid. It holds between 1.5 and 1.7 quarts.
  11. Jan 16, 2010 at 10:09 AM
    HDFD10
    And i am assuming you dont fill the front till it poors out either huh? Feels weird to me to not fill it till it comes out, but i wont
  12. Jan 16, 2010 at 10:49 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Use the 1.5 to 1.7 quarts the book say to.
  13. Jan 16, 2010 at 11:08 AM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    doesn't the book say 3.57Q for the rear?
    I just put a TRD OR rear on mine and it took 3.5, but it got drained and the axles were taken out so it drained even more.
  14. Jan 16, 2010 at 11:16 AM
    HDFD10
    Good question? Still not sure if i want to leave it at 3 or take it till it comes out. Thinkin from the looks of how full it is 3.5 would fill it all the way. And on the front. I took the skid off and is it the hex bolt on the driver side half way up? So the front you got to pump out then right??
  15. Jan 16, 2010 at 11:43 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The 5 lugger axels take 3.55 quarts. The 4x4 and Prerunners take 3.01 MAX. As I mentioned, over filling can cause the oil to cavitate. If it does this, bye bye gears. Your choice.
  16. Jan 17, 2010 at 10:18 AM
    HDFD10
    What do i have? A 5 lug which takes 3.5 or does mine just take 3? Think i put just over 3 quarts into it
  17. Jan 17, 2010 at 10:44 AM
    4low2go
    4low2go Well-Known Member
    Coatesville, PA
    10 RC 4x4 5sp MGM
    Curt hitch, OBX Shift
    How many lug nuts per wheel? 5 = 5 lugger.
  18. Jan 17, 2010 at 12:54 PM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    My owner's manual says 3.0 quarts if I remember correctly. When I did mine, I had three quarts plus the 8 oz tube of LSD additive. I figured that would be plenty. I put in all of that, and it still wasn't coming out the fill hole. I looked in with a flashlight and saw it was very close, so I figured that was good enough.
    One note though, and someone already said it, make sure you give it time to flow down the axles. Mine did run out at first, then I let it sit for maybe ten minutes or so, and I was able to put more in.
