Rear diff
Discussion in 'New Members' started by olimac, Jan 27, 2021.
  1. Jan 27, 2021 at 6:14 PM
    olimac
    olimac [OP] New Member
    Camilo
    1997 Tacoma 2.7 4x4
    2” lift. 33” Mickey Thompson’s
    Hey guys, I’m very new to this, I have a 97 Tacoma 2.7 l. 4x4. My stick gearing is 3:58. I have a lot of play in my rear diff and I’m pretty sure it’s no good. Lots of chatter and some serious vibrations. My question is, what thirds can I use that are compatible? I’d like to go with higher gearing. Even 4:10 would be great. Any help would be great. Thanks.
  2. Jan 27, 2021 at 6:17 PM
    Poncate
    Poncate Well-Known Member
    PNW
    04 DCSB 4x4
    Welcome to TW!
    Something to consider with the 4x4 is if you change the gear ratio on the rear you have to change the front to match.
  3. Jan 27, 2021 at 6:18 PM
    eon_blue
    Azusa, CA
    Just remember if you change the gearing in the rear diff, you'll need to change it in the front diff as well otherwise when you engage 4wd it won't be pretty
  4. Jan 27, 2021 at 6:22 PM
    eon_blue
    Azusa, CA
    Someone correct me if I'm wrong, but any other 1st gen rear end should be compatible as long as it doesn't have an e-locker. The e-locker 3rds are a slightly different size. But if the gearing is different you'll have to swap the front too
    TnShooter and Black DOG Lila like this.
  5. Jan 27, 2021 at 6:29 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
  6. Jan 27, 2021 at 6:48 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    buckhuntin-tacoma and olimac[OP] like this.
  7. Jan 27, 2021 at 6:51 PM
    olimac
    Camilo
    1997 Tacoma 2.7 4x4
    Will change front and rear for sure. So basically I can do the swap with a set of diffs aslong as they match. Mine doesn’t have the diff lock. Could I use the thirds from a 3.4? And if so , would 96 to 03 work?
  8. Jan 27, 2021 at 6:55 PM
    olimac
    Camilo
    1997 Tacoma 2.7 4x4
    And also mine is a 5 speed, front axle has lock hubs. Is there a difference between diffs standard or automatic? Sorry for all the questions. I’m just in love with the truck and just want it to perform well
  9. Jan 27, 2021 at 7:00 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Why do you think it's the rear end? What kind of noise are you hearing? Have you checked U joints and drivetrain related parts or are you assuming it's the rear end? Did you remove the fill plug and check for gear oil and did you drain the axle and inspect the fluid for metal bits?
    How many miles are on the truck? Have you checked for play in the axle shaft bearings or looked to see if the seals are leaking?
    Nothing worse then going thru the effort and cost to replace diffs only to find the noise and vibration is still there. Don't assume because you didn't see any play in the U joints it has to be something else, sometimes you have to remove the driveshaft and check them to see they are free and have no slop while looking for rust seeping from each cross end.
    SR-71A and olimac[OP] like this.
  10. Jan 27, 2021 at 8:31 PM
    olimac
    Camilo
    1997 Tacoma 2.7 4x4
    I’m just assuming because of how loose rear diff has. Tons of play when in neautral and rotate drive shaft with my hand. I just had a wheel alignment done. I havnt checked the diff fluid though. And the shake i can feel in the steering wheel. Also if I roll back in the truck and press hard on brakes, there is a big clunk that sounds like it’s coming from the rear
  11. Jan 28, 2021 at 3:05 AM
    fxntime
    You need to do more checking before you pull the rear diff. There is always some play in a differential, where are you checking the play at?
  12. Jan 28, 2021 at 3:29 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    4:10 gears are LOWER gears than 3.58.
    If you truly need to replace the gears in the rear diff you will also need to change the ones in the front as well so they are the same ratio. There are some options for aftermarket gear swaps but it will cost you roughly $1000 per axle. The cheapest option would be to find a complete rear axle in a scrap yard that is 3.58 and simply do the swap in your driveway. It wouldn't be terribly hard with some jack stands, some basic tools, and someone to provide a little help.
    But I'd make sure of the real problem before proceeding.
  13. Jan 28, 2021 at 6:13 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  14. Jan 29, 2021 at 6:07 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
