Rear Differential-2014 Tacoma- 4.0 L 4WD Access Cab 6 speed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jwin, Mar 28, 2023.
  1. Mar 28, 2023 at 6:06 PM
    jwin
    jwin [OP] New Member
    Jerri
    2014 Tacoma Access Cab 4WD 6 speed
    Took out my rear differential. It is labeled 3.7. Which I’m assuming means it’s a 3.73 ratio. I see an ad for a differential that has the same ratio, but it’s for a 2WD 2nd Gen Tacoma. Neither has manual or electronic lock-in. Anyone know if this will fit?
  2. Mar 28, 2023 at 6:13 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Was the donor tacoma a 6 lug?
    If you have the diff out either count the teeth on both the pinion and ring gear, OR spin the pinion and count the rotations of the pinion until the ring gear takes a full rotation.
  3. Mar 29, 2023 at 5:38 AM
    jwin
    Jerri
    I'm certain I have a 3.7 differential. Its whether the other diff fits. I'll contact them and se if its a 6 lug.
