Rear differential backslash
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Owenhall, Jan 12, 2025.
  1. Jan 12, 2025 at 2:48 PM
    Owenhall
    Owenhall [OP] Well-Known Member
    Owen
    2009 Toyota Tacoma 4x4
    Lift 33s
    My truck has recently started clunking when accreting and when stoping slip yoke has play wondering if greasing it again would fix it I also don’t know if the backlash on my rear differential is acceptable?
  2. Jan 12, 2025 at 9:55 PM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    More like a confused statement. Is there a question here?
    Vitamins, 23MGM and ZColorado like this.
  3. Jan 13, 2025 at 5:21 AM
    Owenhall
    Owen
    Lift 33s
    Is a small amount of slip yoke play acceptable?
  4. Jan 13, 2025 at 7:45 AM
    1 Limited Toyota
    California
    08 XRunner
    Can you get some sort of a measurement? A dial indicator perhaps? There is movement and a greese fitting and it must have a tolerance to slid. How many miles? What kind of maintenance? What kind of use? What symptoms? But mostly what is the actual movement? Ive never seen it but there most likely is a wear measurement out there.
    I'd grease it and look seriously at the carrier bearing and ujoints first.
  5. Jan 13, 2025 at 7:58 AM
    Owenhall
    Owen
    Lift 33s
    The carrier bearings and u joints are new the slip yoke has play but when it’s greased it temporarily goes away do I just have to constantly grease the slip yoke to stop the clunk when stopping and accelerating .Truck has 196k has been maintained well is lifted.
  6. Jan 13, 2025 at 9:15 AM
    Pigpen
    Dan
    Northwest Montana
    Sounds like you've identified the problem. Constant greasing is a band-aid, not a solution. Find a low mileage drive shaft, or a new one.
    I would've guessed transmission if greasing didn't make it go away.
    b_r_o likes this.
  7. Jan 13, 2025 at 9:46 AM
    Owenhall
    Owen
    Lift 33s
    Doesn’t seem super lose don’t know if it needs to be replaced grease lasts a while new driveshaft is like 1700 from Toyota.
  8. Jan 13, 2025 at 8:02 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    The backlash for the 8.4 and elocker are both the same which is 0.13 to 0.18 mm (0.0051 to 0.0071 in.). Anything outside of that range might lead you to check the carrier bearings for wear and replace as required and adjust the preload if possible.
  9. Jan 14, 2025 at 5:31 AM
    Owenhall
    Owen
    Lift 33s
    I got under a friends truck while it was in neutral yesterday and wiggled the driveshaft back and forth and it seemed the same if not more play so ,I think I’m ok on the differental I’m going to grease the slip yoke today and see if that fixes the problem.
  10. Jan 14, 2025 at 6:34 PM
    Owenhall
    Owen
    Lift 33s
    How do I insert a video?
    Squirt likes this.
  11. Jan 14, 2025 at 6:36 PM
    Squirt
    Squirt Certified in forklifts and meme stealing =)
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can. AMP Powersteps
    You can't upload directly. Generally people post YouTube videos to get around it.
  12. Jan 14, 2025 at 6:39 PM
    Owenhall
    Owen
    Lift 33s
    The rear differential when the vehicle is in drive on jackstands makes some noise but not bad noise just a small wine I think that’s normal tho I have not heard the clunk since I greased it will update if it continues.
  13. Jan 14, 2025 at 6:57 PM
    Owenhall
    Owen
    Lift 33s
    The truck also has a low growl at highway speeds that isn’t very loud but is there seems to kinda be load and rpm specific around 2200rmp or 65-75.
  14. Jan 14, 2025 at 7:23 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The chances of a driveshaft issue are much greater than the chances of a differential issue.
    u-joints, center support bearing, slip yoke.. these things take a ton of abuse throughout the life of the vehicle. If greasing seemed to help at least temporarily sounds like your driveshaft is just plain worn out
  15. Jan 14, 2025 at 7:25 PM
    Owenhall
    Owen
    Lift 33s
  16. Jan 14, 2025 at 7:30 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Just be careful if it gets louder
    It's rare for a DS to completely fail and come apart but when they do, if you're moving at any significant speed it can beat the hell out of the underside of the truck when it flops around. Like smash brake lines or puncture the fuel tank
  17. Jan 14, 2025 at 8:20 PM
    Pigpen
    Dan
    Northwest Montana
    A driveline shop could probably build you a new rear half for a lot less money than buying a whole new drive shaft.
  18. Jan 14, 2025 at 8:37 PM
    Owenhall
    Owen
    Lift 33s
    That’s also an option I’m going to keep an eye on it I don’t think it’s so bad that it will come apart but I’m going to figure out how to replace it before it becomes a real issue.
  19. Jan 14, 2025 at 8:40 PM
    1 Limited Toyota
    California
    08 XRunner
    I kind of wonder about the vehicle as a whole. The op hasnt really stated the overall condition, the mileage, the past life under good or bad ownership, good or bad maintenance and repairs.
    Theres a multitude of issues that could be the cause, most have been speculated on here.
    Who's to say the globs of grease isn't just tempararily cushioning a bad carrier bearing, u joint(s), pinion to ring gap, transmission issue, broken engine or trans mount.... or maybe ALL of the above singing in harmony.
  20. Feb 12, 2025 at 9:00 PM
    Owenhall
    Owen
    Lift 33s
    Pretty shure it’s the slip yoke noise has came back after greasing it.
