Rear differential bolt replacements
Discussion in 'Technical Chat' started by Isreal, Jun 24, 2020.
  1. Jun 24, 2020 at 11:51 PM
    Isreal
    Isreal [OP] Member
    96 xtra-cab 4wd 4x4
    Bilstein 5100 series 1.5 in wheel spacers
    I wanted to change the rear different fluid in my truck since I saw the previous owner never did. I noticed that the draining bolt was badly shaved and I could barely even grip it with my 24 mm socket. If I can get it off, is there any way to buy the same exact bolt to replace the shaved one ?
  2. Jun 25, 2020 at 12:00 AM
    scocar
    scocar hypotenoper
    Yes, any toyota parts department.
    DO NOT try to take off the bottom drain plug unless you can get the top fill plug first, or you'll not be able to drive it.
    If you have an impact gun, use A 6 point impact socket on it. But be prepared to have someone weld another bolt head to head on top of that so you can get a real bite on it with a breaker bar.
    Clearwater Bill and Isreal[OP] like this.
  3. Jun 25, 2020 at 12:02 AM
    scocar
    scocar hypotenoper
    the other common approaches are penetrating fluid or using a torch to heat it. But neither will help if you can't get a good bite on it.
    Isreal[OP] likes this.
  4. Jun 25, 2020 at 9:35 AM
    Isreal
    Isreal [OP] Member
    96 xtra-cab 4wd 4x4
    Thank you, I really appreciate the help !
    scocar[QUOTED] likes this.
  5. Jun 25, 2020 at 9:39 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I mangled my rear diff bolt by dragging it over one too many rocks, I was able to remove it by using my Dremel to sort of reshape it back into the proper hex shape so I could fit my socket over it. I just ordered a new one online from some dealership, they aren't very expensive.
    Also don't forget to pick up more crush washers too. Technically every time you remove the drain/fill plugs you should put a new crush washer on
    scocar likes this.
  6. Jun 25, 2020 at 11:12 AM
    scocar
    scocar hypotenoper
    That's what we do! And I miss my 1st gen.
  7. Jun 25, 2020 at 11:19 AM
    scocar
    scocar hypotenoper
    Good stuff. Could also possibly use an angle grinder on it to just create some decent flats to get a pipe wrench on it.
    And about the crush washer, OP, the come in steel or aluminum. Steel to steel (diffs) and aluminum to aluminum (transfer case plugs, I think tyranny, too) to avoid galvanic corrosion and future seized plugs.
